Adafruit MPRLS Ported Pressure Sensor Breakout - Code error
twobitebrownies
Post by twobitebrownies »
I am trying to use the Adafruit MPRLS Ported Pressure Sensor Breakout with an Arduino Uno. Following the Adafruit setup instructions (https://learn.adafruit.com/adafruit-mpr ... duino-test), I ran the simpletest file from the Adafruit MPRLS Library. However, when looking at the serial monitor, it only prints the line "MPRLS Simple Test" two times. It does not even print "Failed to communicate with MPRLS sensor, check wiring?" or "MPRLS Sensor Found". which means it is getting stuck in the if statement of the code. However, I am not sure why this is. Does anyone have any insight?
A picture of the serial output is attached.
For reference, here is the code from mprls_simpletest:
 * @file mprls_simpletest.ino
 * A basic test of the sensor with default settings
 * Designed specifically to work with the MPRLS sensor from Adafruit
 * ----> https://www.adafruit.com/products/3965
 * These sensors use I2C to communicate, 2 pins (SCL+SDA) are required
 * to interface with the breakout.
 * Adafruit invests time and resources providing this open source code,
 * please support Adafruit and open-source hardware by purchasing
 * products from Adafruit!
 * Written by Limor Fried/Ladyada for Adafruit Industries.
 * MIT license, all text here must be included in any redistribution.
#include <Wire.h>
#include "Adafruit_MPRLS.h"
// You dont *need* a reset and EOC pin for most uses, so we set to -1 and don't connect
#define RESET_PIN  -1  // set to any GPIO pin # to hard-reset on begin()
#define EOC_PIN    -1  // set to any GPIO pin to read end-of-conversion by pin
Adafruit_MPRLS mpr = Adafruit_MPRLS(RESET_PIN, EOC_PIN);
  Serial.begin(115200);
  Serial.println("MPRLS Simple Test");
  if (! mpr.begin()) {
    Serial.println("Failed to communicate with MPRLS sensor, check wiring?");
    while (1) {
      delay(10);
  Serial.println("Found MPRLS sensor");
  float pressure_hPa = mpr.readPressure();
  Serial.print("Pressure (hPa): "); Serial.println(pressure_hPa);
  Serial.print("Pressure (PSI): "); Serial.println(pressure_hPa / 68.947572932);
  delay(1000);
Thanks all.
Re: Adafruit MPRLS Ported Pressure Sensor Breakout - Code er
Please post a photo showing your soldering and connections.
Return to “Other Arduino products from Adafruit”
