https://www.adafruit.com/product/1381
Can this board be used to read mp3 encoded (or even raw PCM) sound from Mic/LineIn via SPI?
I need to stream the voice out of this device (via ESP32) to an external aggregator.
Just to be clear, I don't need the sound to be recorded on the SD card, I just need to stream it out from an ESP32 to a central device.
VS1053 Codec + MicroSD Breakout Board for real time streamin
- vrkiran
- mikeysklar
Re: VS1053 Codec + MicroSD Breakout Board for real time stre
@vrkiran,
We have a guide example which is ESP8266 based that uses the VS1053 based Music Maker as a WiFi Radio. The readForData() and playData() functions look the most relevant to your task.
https://learn.adafruit.com/adabox004/internet-radio
// Tested: ESP8266, ESP32, M0+WINC1500
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <ESP8266WiFi.h>
char* ssid = "your_ssid";
const char* password = "password";
// http://ice1.somafm.com/u80s-128-mp3
const char *host = "ice1.somafm.com";
const char *path = "/u80s-128-mp3";
//const char *path = "/doomed-128-mp3";
int httpPort = 80;
// These are the pins used
#define VS1053_RESET -1 // VS1053 reset pin (not used!)
#define VS1053_CS 16 // VS1053 chip select pin (output)
#define VS1053_DCS 15 // VS1053 Data/command select pin (output)
#define VS1053_DREQ 0 // VS1053 Data request, ideally an Interrupt pin
#define VOLUME_KNOB A0
#define ON_OFF_SWITCH 4
int lastvol = 30;
Adafruit_VS1053 musicPlayer = Adafruit_VS1053(VS1053_RESET, VS1053_CS, VS1053_DCS, VS1053_DREQ);
// Use WiFiClient class to create HTTP/TCP connection
WiFiClient client;
Serial.begin(115200);
Serial.println("\n\nAdafruit VS1053 Feather WiFi Radio");
/************************* INITIALIZE MP3 WING */
if (! musicPlayer.begin()) { // initialise the music player
Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
while (1) delay(10);
Serial.println(F("VS1053 found"));
musicPlayer.sineTest(0x44, 500); // Make a tone to indicate VS1053 is working
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(lastvol, lastvol);
// don't use an IRQ, we'll hand-feed
pinMode(ON_OFF_SWITCH, INPUT_PULLUP);
/************************* INITIALIZE WIFI */
Serial.print("Connecting to SSID "); Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("WiFi connected");
Serial.println("IP address: "); Serial.println(WiFi.localIP());
/************************* INITIALIZE STREAM */
Serial.print("connecting to "); Serial.println(host);
if (!client.connect(host, httpPort)) {
Serial.println("Connection failed");
return;
// We now create a URI for the request
Serial.print("Requesting URL: ");
Serial.println(path);
// This will send the request to the server
client.print(String("GET ") + path + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
// our little buffer of mp3 data
uint8_t mp3buff[32]; // vs1053 likes 32 bytes at a time
int loopcounter = 0;
if (! digitalRead(ON_OFF_SWITCH)) {
yield();
return;
loopcounter++;
// wait till mp3 wants more data
if (musicPlayer.readyForData()) {
//Serial.print("ready ");
//wants more data! check we have something available from the stream
if (client.available() > 0) {
//Serial.print("set ");
// yea! read up to 32 bytes
uint8_t bytesread = client.read(mp3buff, 32);
// push to mp3
musicPlayer.playData(mp3buff, bytesread);
//Serial.println("stream!");
} else {
if (loopcounter >= 1000) {
loopcounter = 0;
// adjust volume!
int vol = 0;
vol = analogRead(VOLUME_KNOB);
vol /= 10;
if (abs(vol - lastvol) > 3) {
Serial.println(vol);
lastvol = vol;
