Servo Shield and RC Transmitter via Arduino Uno
- headbyte
Re: Servo Shield and RC Transmitter via Arduino Uno
I have some "hardware" chops. I've been an electronic & computer tech for over 20 yrs. But my coding sucks. :/
Nice looking tank!
And you can declare some handy constants for use in the code:
You can eliminate your include of the Servo.h and your declarations of the Servo objects and the servo attach statements, since they are no longer needed.
In your setup, you will need to add the following lines to initialize the shield.
And this code:
can be replaced by:
First, you need to include the library and declare your shield. Since you altered the default address, you will need to specify that in the constructor.So how do I get this code . . . To work with the Servo Shield?
#include <Adafruit_PWMServoDriver.h>
Adafruit_PWMServoDriver servos = Adafruit_PWMServoDriver(0x41);
#define SERVOMIN 150 // This is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX 600 // This is the 'maximum' pulse length count (out of 4096)
servos.begin();
servos.setOscillatorFrequency(27000000);
servos.setPWMFreq(50); // Analog servos run at ~50 Hz updates
servo1.write(map(ch4, -100, 100, 0, 180));
servo2.write(map(ch3, -100, 100, 0, 180));
servos.setPWM(0, 0, map(ch4, -100, 100, SERVOMIN , SERVOMAX)); // for servo connected to shield channel 0
servos.setPWM(1, 0, map(ch3, -100, 100, SERVOMIN , SERVOMAX)); // for servo connected to shield channel 1
- headbyte
Thank you so much for your reply! This is great! I truly appreciate it.
