I just got a 9 volt battery holder with switch for Adafruit. It did not work with a Diecimila arduino. The plug does not seem to fit properly. There is 9 volts on the plug, but the arduino does not turn on.
Has this problem happened before?
I need my $3.95 back.
Ken
9 volt box did not work with arduino
- adafruit_support_carter
Re: 9 volt box did not work with arduino
Just to check, this is the battery holder you are using?
https://www.adafruit.com/product/67
Can you elaborate on what did not fit in terms of the barrel plug. Did it not go into the Arduino board at all? Or did, but is loose?
- arduinouser11
Yes it is box 67.
The plug did not fit all the way into the female jack. There was a tiny gap (maybe a few millimeters). The plug is not loose,, but it does not go all the way in.
Now please answer my original question. Has this happened before? (I suspect it is a manufacturing error.)
I need a refund for a defective product.
Thank you,
Ken Kornstett
Thank you,
Ken Kornstett
- adafruit2
thats not unusual for there to be some gap. these battery holders are pretty reliable
what if you measure the voltage on the battery holder with a multimeter? check the switch and that the battery is 9V too
- arduinouser11
I measured the voltage with a VOM. The battery was 9 volts and the switch switches the voltage on and off. I put the VOM probes in the connector and it is 9 volts.
I did that the first thing.
Ken
Ken
- adafruit2
huh well the box is working fine then it seems
and if you power the arduino from another 9V power supply it works OK?
- arduinouser11
I have only used the USB to power the Arduino. I wanted to have a remote Arduino, so I bought a 9 volt Box.
- adafruit2
well, right now you have a box that gives 9V out, so it could be the arduino?
- arduinouser11
I suppose it could be the Arduino, but the fact that it has a gap of 1/8 inch seems too large to me.
See the enclosed picture of the large gap.
Ken
Ken
- box plug to arduino.JPG (35.34 KiB) Viewed 454 times
- adafruit2
did you set the arduino jumper to DC power?
- arduinouser11
No. I moved the power jumper and my Arduino now works. The battery box is OK.
Thanks for helping me,
Ken
Ken
