AM2315 Digital temperature and humidity sensor
Kimdongmin
Post by Kimdongmin »
Excuse me
Can i ask you a question about the AM2315 product?
Several AM2315 products were measured at the same time, same space, but the temperature was differentt
The temperature is 2~3℃ different
Is there a way to initialize the setting value or match the two product temperatures
mikeysklar
Re: AM2315 Digital temperature and humidity sensor
Post by mikeysklar »
Are you using our AM2315 product id# 1293
https://www.adafruit.com/product/1293
Can you post a photo of how you have it wired up and the code that is running?
What happens when you let it run for 20 minutes is there still a significant difference?
The accuracy in the -20-80C range should be +/-0.1 C.
rpiloverbd
Post by rpiloverbd »
Sounds weird. Are you using the pull up resistors.
Return to “Other Arduino products from Adafruit”
