MagTag has unwanted black border in Grayscale4 mode
TheRealElbadoo
Post by TheRealElbadoo »
I'm writing code in the Arduino IDE for my newly-purchased (11/2021) MagTag and I'm getting borders I don't expect to see.
Initializing the display in the THINKINK_GRAYSCALE4 mode leaves me with an unwanted black border around the display area. I had wanted to use the display for a graph, but I'm going to have to move the axes several pixels away to avoid losing them in the border box. The only way I can avoid the appearance of the border is if I use an all-black background.
I didn't include photos, but the THINKINK_MONO mode sets a white border. This could be an issue if I planned on writing white text/plot axes on a black background. I guess I'm not as worried about that, but it's odd that it's different from the Grayscale border.
I've attached a small demo program which shows the border in action. My code sets a background with some text and draws single-pixel 'pips' at the min/max coordinates of the display to show that the border is outside the addressable area. You'll likely need a magnifier to see the pips.
So: Is there a way to control/customize the appearance of the border?
  products from Adafruit!
  MIT license, all text above must be included in any redistribution
#include "Adafruit_ThinkInk.h"
#define EPD_DC      7  // can be any pin, but required!
#define EPD_CS      8  // can be any pin, but required!
#define EPD_BUSY    5  // can set to -1 to not use a pin (will wait a fixed delay)
#define SRAM_CS     -1 // can set to -1 to not use a pin (uses a lot of RAM!)
#define EPD_RESET   6  // can set to -1 and share with chip Reset (can't deep sleep)
// 2.9" Grayscale Featherwing or Breakout:
ThinkInk_290_Grayscale4_T5 display(EPD_DC, EPD_RESET, EPD_CS, SRAM_CS, EPD_BUSY);
const int BUTTON_PIN = 0;
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  Serial.println();
  Serial.println();
  display.begin(THINKINK_GRAYSCALE4);
  display.clearBuffer();
  display.fillScreen(EPD_LIGHT);
  display.setTextSize(4);
  display.setTextColor(EPD_BLACK);
  display.setCursor(0, 0);
  display.print("Greyscale4\n\n Button 0\n for next");
  drawPips();;
  display.display();
  waitForButton();
  display.setTextColor(EPD_WHITE);
  display.print("Greyscale4\n\n Button0\n for next");
  drawPips();
  display.display();
  waitForButton();
  display.begin(THINKINK_MONO);
  //display.fillScreen(EPD_WHITE);        // Don't do this in Monochrome.
  //display.setTextColor(EPD_BLACK);      // Doesn't do anything in Monochrome?
  display.print("Monochrome\n\n Button 0\n for next");
  drawPips();
  display.display();
  waitForButton();
  // Counterintuitively - for me - I can't do a fillScreen(EPD_BLACK) and
  // a setTextColor(EPD_WHITE) to get white text on a black background. I have to
  // do some sort of invert thing with setBlackBuffer() and setColorBuffer().
  display.setBlackBuffer(1, false);
  display.setColorBuffer(1, false);
  display.print("Mono/invert\n\n Button 0\n to restart");
  drawPips();
  display.display();
  waitForButton();
void drawPips() {
  int displayHeight=display.height();
  int displayWidth=display.width();
  display.drawPixel(0,displayHeight/2,EPD_BLACK);
  display.drawPixel(displayWidth-1,displayHeight/2,EPD_BLACK);
  display.drawPixel(displayWidth/2,0,EPD_BLACK);
  display.drawPixel(displayWidth/2,displayHeight-1,EPD_BLACK);
void waitForButton() {
  while (digitalRead(BUTTON_PIN) == HIGH) {delay(1);}
  while (digitalRead(BUTTON_PIN) == LOW) {delay(1);}
adafruit_support_carter
Re: MagTag has unwanted black border in Grayscale4 mode
Recreated and opened a new issue for this here:
https://github.com/adafruit/Adafruit_EPD/issues/55
Checkout the issue thread for more details. This appears to be a feature of the display.
TheRealElbadoo
At least it’s reproducible and somewhat explainable. And yes, there is at least one other posting out there that talks about it also happening in Circuit Python.
If the border can’t be turned off, is there any way it can be set to one of the other options (i.e., Light Gray)? For some applications (like the weather app shown in the Github thread) a dark frame makes sense, but for others it’s kind of intrusive. It would be good to have a choice.
