Also I am trying to figure out how to flip the encoder so that turning right causes a positive return from the encoder and I am a bit stumped.
#include <Adafruit_seesaw.h>
#include <seesaw_neopixel.h>
#include <AccelStepper.h>
#include <MultiStepper.h>
#include <Bounce2.h>
#define SS_SWITCH 24
#define SS_NEOPIX 6
#define NUM_OF_ENC 2
#define BUTTON_PIN 52
#define X_STEP_PIN 11
#define X_DIR_PIN 12
#define X_ENA_PIN 13
#define X_SPEED_MULTIPLIER 100
#define X_MAX_CONSTRAINT 20
#define Y_STEP_PIN 8
#define Y_DIR_PIN 9
#define Y_ENA_PIN 10
#define SEESAW_BASE_ADDR 0x36
Adafruit_seesaw Xencoder;
Adafruit_seesaw Yencoder;
seesaw_NeoPixel Xpixel(1, SS_NEOPIX, NEO_GRB + NEO_KHZ800);
seesaw_NeoPixel Ypixel(1, SS_NEOPIX, NEO_GRB + NEO_KHZ800);
uint32_t Xencoder_position = 0;
uint32_t Yencoder_position = 0;
Bounce2::Button limit_switch = Bounce2::Button();
AccelStepper Xstepper(1, X_STEP_PIN, X_DIR_PIN);
AccelStepper Ystepper(1, Y_STEP_PIN, Y_DIR_PIN);
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if (WheelPos < 85) {
return seesaw_NeoPixel::Color(255 - WheelPos * 3, 0, WheelPos * 3);
if (WheelPos < 170) {
WheelPos -= 85;
return seesaw_NeoPixel::Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return seesaw_NeoPixel::Color(WheelPos * 3, 255 - WheelPos * 3, 0);
void setup()
Serial.begin(115200);
limit_switch.attach( BUTTON_PIN, INPUT_PULLUP );
limit_switch.interval(5);
limit_switch.setPressedState(LOW);
Xstepper.setMaxSpeed(X_SPEED_MULTIPLIER * X_MAX_CONSTRAINT);
Xstepper.setSpeed(0);
Ystepper.setMaxSpeed(1000);
Serial.println("Setting up Adafruit SeeSaw X rotary encorder");
if (! Xencoder.begin(SEESAW_BASE_ADDR) || ! Xpixel.begin(SEESAW_BASE_ADDR)) {
Serial.println("Couldn't find X seesaw on default address");
while (1) delay(10);
Serial.println("Setting up Adafruit SeeSaw Y rotary encorder");
if (! Yencoder.begin(SEESAW_BASE_ADDR + 1) || ! Ypixel.begin(SEESAW_BASE_ADDR + 1)) {
Serial.println("Couldn't find Y seesaw on default address");
Xencoder.pinMode(SS_SWITCH, INPUT_PULLUP);
Xencoder_position = Xencoder.getEncoderPosition();
Xencoder.setGPIOInterrupts((uint32_t)1 << SS_SWITCH, 1);
Xencoder.enableEncoderInterrupt();
Xpixel.setBrightness(30);
Xpixel.show();
Yencoder.pinMode(SS_SWITCH, INPUT_PULLUP);
Yencoder_position = Yencoder.getEncoderPosition();
Yencoder.setGPIOInterrupts((uint32_t)1 << SS_SWITCH, 1);
Yencoder.enableEncoderInterrupt();
Ypixel.setBrightness(30);
Ypixel.show();
void loop()
limit_switch.update();
int16_t currSpeed = Xstepper.speed();
int32_t new_position = Xencoder.getEncoderPosition();
uint8_t constrained_position = constrain(new_position, 0, X_MAX_CONSTRAINT);
if (Xencoder_position != constrained_position) {
Xencoder_position = constrained_position;
Xpixel.setPixelColor(0, Wheel((constrained_position * 4) & 0xFF));
Xpixel.show();
if (currSpeed < 0) {
Xstepper.setSpeed(-constrained_position * X_SPEED_MULTIPLIER);
} else {
Xstepper.setSpeed(constrained_position * X_SPEED_MULTIPLIER);
Serial.println(currSpeed);
Xencoder.setEncoderPosition(constrained_position);
if (limit_switch.pressed() ) {
Serial.println("The limit_switch is pressed");
Xstepper.stop();
Xstepper.setSpeed(-currSpeed);
delay(500);
Xstepper.runSpeed();
