How to use the applyPatch() function in the Adafruit VS1053
jtlechem
Post by jtlechem »
Is there any example code out there for using the applyPatch() function?
I'm using the VS1053 codec breakout with my Arduino Uno.
(https://www.adafruit.com/product/1381)
And using the Adafruit VS1053 Library for Arduino.
(https://github.com/adafruit/Adafruit_VS1053_Library)
The maker of the VS1053 chip has some patch files for added functionality (https://www.vlsi.fi/en/support/software ... tches.html) I need to use the pitch/tempo shifter patch, which is sort of explained in this document from VLSI, page 19: https://www.vlsi.fi/fileadmin/software/ ... atches.pdf
So to the makers of the Adafruit VS1053 Library, I'm wondering how do you use the applyPatch() function? I'm not sure what to write for the two input variables.
I tried attaching here the patch/plugin file, but won't let me. It's called "vs1053b-patches-pitch.plg" from the patches folder found in the link above.
It has the necessary plugin array but also has a lot of the same code as the applyPatch() function, so I'm confused how that works, what to write in my arduino script, what not to write in the arduino script, etc.
Here is the applyPatch() function from github (also linked above):
void Adafruit_VS1053::applyPatch(const uint16_t *patch, uint16_t patchsize) {
  uint16_t i = 0;
  // Serial.print("Patch size: "); Serial.println(patchsize);
  while (i < patchsize) {
    uint16_t addr, n, val;
    addr = pgm_read_word(patch++);
    n = pgm_read_word(patch++);
    i += 2;
    // Serial.println(addr, HEX);
    if (n & 0x8000U) { // RLE run, replicate n samples
      n &= 0x7FFF;
      val = pgm_read_word(patch++);
      i++;
      while (n--) {
        sciWrite(addr, val);
    } else { // Copy run, copy n samples
      while (n--) {
        i++;
jtlechem
Re: How to use the applyPatch() function in the Adafruit VS1
Post by jtlechem »
*small title typo: How to use the applyPatch() function from the Adafruit VS1053 Library
Return to “Other Arduino products from Adafruit”
