Micro USB B Jack to USB A Connector water protection questio
- travishunt
I am wondering if there was any Water resistant tests done on the "Micro USB B Jack to USB A Plug Round Panel Mount Adapter." Would it leak through the connection if sprayed with water?
- mikeysklar
Re: Micro USB B Jack to USB A Connector water protection que
There is no "weatherproof" statement or IP rating with the Adafruit "USB B Jack to USB A Jack Round Panel Mount Adapter" #4212. You can take that to mean that this device can be compromised with moisture exposure.
https://www.adafruit.com/product/4212
https://cdn-shop.adafruit.com/product-f ... SB_A_F.pdf
If being able to handle light moisture is important you could look into weatherproof enclosures. This PG-7 with cable glands is a good example #3931.
https://www.adafruit.com/product/3931
