Adafruit Touchscreen Breakout does not detect nothing
adafruit_support_carter
Re: Adafruit Touchscreen Breakout does not detect nothing
Cool, glad it's working. So at least problem is understood and solved.
For fixing the docs - Looks like maybe there are two different examples with two different wirings.
The guide wiring here:
https://learn.adafruit.com/adafruit-2-8 ... -906193-10
matches the library example linked from the same guide, which is from the TouchScreen library:
https://github.com/adafruit/Adafruit_To ... endemo.ino
#define YP A2  // must be an analog pin, use "An" notation!
#define XM A3  // must be an analog pin, use "An" notation!
#define YM 8   // can be a digital pin
#define XP 9   // can be a digital pin
But the breakouttouchpaint.ino example from the ILI9341 library uses slightly different wiring:
https://github.com/adafruit/Adafruit_IL ... hpaint.ino
#define YM 9   // can be any digital pin
#define XP 8   // can be any digital pin
How did you end up at the breakouttouchpaint.ino example from the ILI9341 library? That'll help us figure out how best to update the documentation.
Amidala
Post by Amidala »
I followed this tutorial:
https://learn.adafruit.com/adafruit-2-8 ... ode-906193
Which says "Load up the breakoutTouchPaint example from the Adafruit_ILI9341 library and try drawing with your fingernail!"
And also says : "Wire the additional 4 pins as follows:
Y+ to Arduino A2
X+ to Arduino D9 (Same as D/C)
Y- to Arduino D8
X- to Arduino A3"
Thanks. That does look mis-matched. I submitted a guide feedback for that so the guide author will eventually get a notice to take a look. It's a pretty old guide, so something probably changed and got out of sync.
Sorry for the confusion.
Amidala
Post by Amidala »
Thank you. Have a nice day.
