Atmega32u4 Breakout+ digital and analog I/O
apefive
Post by apefive »
hello,
how many analog and digital I/O the Atmega32u4 Breakout+ have?
it seems 6 analog and 19 digital. it is right?
teensy have 12 analog and 13 digital.
thanks! :)
Re: Atmega32u4 Breakout+ digital and analog I/O
These two breakout boards have the same processor and same I/O pins - just arranged a little differently.
apefive
Post by apefive »
oh wow. so it has 12 analog too... could you tell me where?
i know that F0 F1 F4 F5 F6 F7 are analog.
where is the other 6 analog ones?
thanks.
The full pinout of the 32U4 is here: http://www.atmel.com/Images/doc7766.pdf
apefive
Post by apefive »
thanks! very useful!
B4 B5 B6 D4 D6 and D7 ! ;)
platypus
Re: Atmega32u4 Breakout - ICSP pin1
Post by platypus »
Where is Pin1 on the 32U4 board ICSP header - it looks unmarked?
The silkscreen is marked for a keyed connector:
platypus
Post by platypus »
Thanks, but I haven't seen an ICSP connector that has a key. I use an Atmel AVRISP Mkii which only has a small arrow on pin 1.
Might be best to place the usual dot or line on pin 1 on the PCB.
platypus
Post by platypus »
However, nice job placing the ICSP Pin1 (MISO) to enable a programmer like the AVRISP Mkii to connect from the edge of the board instead of running across the board.
Do you have a table of all Analog pins and Digital/PWM's - compatible with Arduino, not the Atmel datasheet which is not compatible with Arduino pinouts.
platypus
Re: Atmega32u4 Breakout+ 32U4 pinout map
Post by platypus »
Don't worry, I found the pinouts mapped as Atmel vs Arduino and posted it under this - 32U4 breakout and Leonardo- Atmel & Arduino Pinouts
Return to “Other Arduino products from Adafruit”
