Fingerprint question
- madmike89
Re: Fingerprint question
Hi was wondering if there is a way to copy the data from one fingerprint reader to another?
- Felix_Jochems
I finally got a reliable way to download, convert and upload templates to the sensor.
I'll update my post in a couple of days with a working library
- axelchita
"Felix_Jochems", do you have a solucion to download, convert and upload templates to the sensor???
Thank you, so much
Thank you, so much
- foobarjls
yes I also think its an overflow. so I did the following (removed Serial.prints, delays, yields, mySerial->reads, and instead used mySerial->readBytes) and it works.
I also compiled the code in Release mode. And Once I got the packets in a buffer then I processed the information as I needed.
uint8_t bytesReceived[973]; // 7 data packets of 139 uint8_t
memset(bytesReceived, 0xff, 973);
uint32_t starttime = millis();
int i = 0;
while (i < 973 && (millis() - starttime) < 2000) {
int n;
if (n = finger.mySerial->available()) {
finger.mySerial->readBytes(bytesReceived + i, n);
i += n;
- COLLINZ
Hello all,
i am working on a project and i am required to scan the fingerprints on the adafruit fingerprint module
and store them in the mysql because the module has a limited range of templates it can store,
i then have to write code to match a scanned fingerprint with the ones in mysql;
i have tried using SFG demo to scan and store in the database but it gets stuck on place your finger and does nothings,
i am now forced to write code that can extract the fingerprint in the buffer and send it to mysql, i will be glad if someone can give me help
on the part of matching, i am following DON Jerome's idea and here is the code, i would appreciate any help on the part of parsing the char file to mysl
- Attachments
- fingerprint_match_concept.rar
- here is the arduino code and mysql code
- (5 KiB) Downloaded 197 times
- luiscarlos1974
Felix_Jochems wrote:I finally got a reliable way to download, convert and upload templates to the sensor.
download sample please?
- axelchita
Felix_Jochems... can you post your code?????
- EEEEmdadulIslam
Hello Everyone,
I have been using dy50_main_v3 fingerprint module and adafruit fingerprint module since one month. There was no problem in enroll system. But from yesterday during enrollment the module is taking picture automatically thought there is no finger. it shows like the picture .
- Hanif_Izzudin_Rahman
Hello, I'm Hanif, a collage student in BANNED :D
I've learn this problem, maybe for 1 month and from now, i only get this
[ This is abaout upload templete from computer to Char Buffer (1/2) using DownChar (look at datasheet, this use 0x09) ]
[ SO, this i check i upload my finger templete to Char Buffer and i dwonload again and put out again in Serial Monitor, to check, is all right when i upload the templete? ]
in my header there is
and this is file library in .cpp
SO This is it... :))))
in file header there is
In Data Sheet, you can see, DownChar use code 09H
i get this from Don_Jeronimo and i copy it
in file library .cpp, there is
i use "uploadModel" when i coding in my arduino to Upload Templete
in here, use 0x02 to save upload templete in Char Buffer 2 (when you use 0x01, then will be save in Char Buffer 1
every packet, there is 32 code Hex Template (because i using modul ZFM60, which produce 512 code Hex)
and this is the my Source Code in Arduino
So, i explain in little :D
for upload templete that i save in library (.cpp) into Char Buffer in Module Fingerprint
for download again my templete that i save in Char Buffer and put out in my Serial Monitor
Oh ya, in my library there is
this mean 0x02 i acces Char Buffer 2 (0x01 for Char Buffer 1)
and in my header file there is
this mean 0x08 is code for UpChar (you see in Datasheet)
ANNDDDD, i havent find out, why i cannt upload my templete to Module
Sorry fulll ...:(
#ifndef ADAFRUIT_FINGERPRINT_H
#define ADAFRUIT_FINGERPRINT_H
This is a library for our optical Fingerprint sensor
Designed specifically to work with the Adafruit Fingerprint sensor
----> http://www.adafruit.com/products/751
These displays use TTL Serial to communicate, 2 pins are required to
interface
products from Adafruit!
#include "Arduino.h"
#if defined(__AVR__) || defined(ESP8266)
#include <SoftwareSerial.h>
#elif defined(FREEDOM_E300_HIFIVE1)
#include <SoftwareSerial32.h>
#define SoftwareSerial SoftwareSerial32
#endif
#define FINGERPRINT_OK 0x00
#define FINGERPRINT_PACKETRECIEVEERR 0x01
#define FINGERPRINT_NOFINGER 0x02
#define FINGERPRINT_IMAGEFAIL 0x03
#define FINGERPRINT_IMAGEMESS 0x06
#define FINGERPRINT_FEATUREFAIL 0x07
#define FINGERPRINT_NOMATCH 0x08
#define FINGERPRINT_NOTFOUND 0x09
#define FINGERPRINT_ENROLLMISMATCH 0x0A
#define FINGERPRINT_BADLOCATION 0x0B
#define FINGERPRINT_DBRANGEFAIL 0x0C
#define FINGERPRINT_UPLOADFEATUREFAIL 0x0D
#define FINGERPRINT_PACKETRESPONSEFAIL 0x0E
#define FINGERPRINT_UPLOADFAIL 0x0F
#define FINGERPRINT_DELETEFAIL 0x10
#define FINGERPRINT_DBCLEARFAIL 0x11
#define FINGERPRINT_PASSFAIL 0x13
#define FINGERPRINT_INVALIDIMAGE 0x15
#define FINGERPRINT_FLASHERR 0x18
#define FINGERPRINT_INVALIDREG 0x1A
#define FINGERPRINT_ADDRCODE 0x20
#define FINGERPRINT_PASSVERIFY 0x21
#define FINGERPRINT_STARTCODE 0xEF01
#define FINGERPRINT_COMMANDPACKET 0x1
#define FINGERPRINT_DATAPACKET 0x2
#define FINGERPRINT_ACKPACKET 0x7
#define FINGERPRINT_ENDDATAPACKET 0x8
#define FINGERPRINT_TIMEOUT 0xFF
#define FINGERPRINT_BADPACKET 0xFE
#define FINGERPRINT_GETIMAGE 0x01
#define FINGERPRINT_IMAGE2TZ 0x02
#define FINGERPRINT_REGMODEL 0x05
#define FINGERPRINT_STORE 0x06
#define FINGERPRINT_LOAD 0x07
#define FINGERPRINT_UPLOAD 0x08
#define FINGERPRINT_DOWNLOAD 0x09
#define FINGERPRINT_MATCH 0x03
#define FINGERPRINT_DELETE 0x0C
#define FINGERPRINT_EMPTY 0x0D
#define FINGERPRINT_SETPASSWORD 0x12
#define FINGERPRINT_VERIFYPASSWORD 0x13
#define FINGERPRINT_HISPEEDSEARCH 0x1B
#define FINGERPRINT_TEMPLATECOUNT 0x1D
//#define FINGERPRINT_DEBUG
#define DEFAULTTIMEOUT 1000 ///< UART reading timeout in milliseconds
///! Helper class to craft UART packets
struct Adafruit_Fingerprint_Packet {
@brief Create a new UART-borne packet
@param type Command, data, ack type packet
@param length Size of payload
@param data Pointer to bytes of size length we will memcopy into the internal buffer
Adafruit_Fingerprint_Packet(uint8_t type, uint16_t length, uint8_t * data) {
this->start_code = FINGERPRINT_STARTCODE;
this->type = type;
this->length = length;
address[0] = 0xFF; address[1] = 0xFF;
address[2] = 0xFF; address[3] = 0xFF;
if(length<64)
memcpy(this->data, data, length);
else
memcpy(this->data, data, 64);
uint16_t start_code; ///< "Wakeup" code for packet detection
uint8_t address[4]; ///< 32-bit Fingerprint sensor address
uint8_t type; ///< Type of packet
uint16_t length; ///< Length of packet
uint8_t data[64]; ///< The raw buffer for packet payload
///! Helper class to communicate with and keep state for fingerprint sensors
class Adafruit_Fingerprint {
public:
#if defined(__AVR__) || defined(ESP8266) || defined(FREEDOM_E300_HIFIVE1)
Adafruit_Fingerprint(SoftwareSerial *ss, uint32_t password = 0x0);
#endif
Adafruit_Fingerprint(HardwareSerial *hs, uint32_t password = 0x0);
void begin(uint32_t baud);
boolean verifyPassword(void);
uint8_t getImage(void);
uint8_t image2Tz(uint8_t slot = 1);
uint8_t createModel(void);
uint8_t emptyDatabase(void);
uint8_t storeModel(uint16_t id);
uint8_t loadModel(uint16_t id);
uint8_t loadModeltwo(uint16_t id);
uint8_t getModel(void);
uint8_t getModel2(void);
uint8_t uploadModel(void);
uint8_t deleteModel(uint16_t id);
uint8_t fingerFastSearch(void);
uint8_t getTemplateCount(void);
void writePacket(uint32_t addr, uint8_t packettype, uint16_t len, uint8_t *packet);
uint8_t getReply(uint8_t packet[], uint16_t timeout=DEFAULTTIMEOUT);
uint8_t getMatch(void);
uint8_t setPassword(uint32_t password);
void writeStructuredPacket(const Adafruit_Fingerprint_Packet & p);
uint8_t getStructuredPacket(Adafruit_Fingerprint_Packet * p, uint16_t timeout=DEFAULTTIMEOUT);
/// The matching location that is set by fingerFastSearch()
uint16_t fingerID;
/// The confidence of the fingerFastSearch() match, higher numbers are more confidents
uint16_t confidence;
/// The number of stored templates in the sensor, set by getTemplateCount()
uint16_t templateCount;
private:
uint8_t checkPassword(void);
uint32_t thePassword;
uint32_t theAddress;
uint8_t recvPacket[20];
Stream *mySerial;
SoftwareSerial *swSerial;
#endif
HardwareSerial *hwSerial;
#endif
interface
#include "Adafruit_Fingerprint.h"
#if ARDUINO >= 100
#define SERIAL_WRITE(...) mySerial->write(__VA_ARGS__)
#else
#define SERIAL_WRITE(...) mySerial->write(__VA_ARGS__, BYTE)
#endif
#define SERIAL_WRITE_U16(v) SERIAL_WRITE((uint8_t)(v>>8)); SERIAL_WRITE((uint8_t)(v & 0xFF));
#define GET_CMD_PACKET(...) \
uint8_t data[] = {__VA_ARGS__}; \
Adafruit_Fingerprint_Packet packet(FINGERPRINT_COMMANDPACKET, sizeof(data), data); \
writeStructuredPacket(packet); \
if (getStructuredPacket(&packet) != FINGERPRINT_OK) return FINGERPRINT_PACKETRECIEVEERR; \
if (packet.type != FINGERPRINT_ACKPACKET) return FINGERPRINT_PACKETRECIEVEERR;
#define SEND_CMD_PACKET(...) GET_CMD_PACKET(__VA_ARGS__); return packet.data[0];
PUBLIC FUNCTIONS
@brief Instantiates sensor with Software Serial
@param ss Pointer to SoftwareSerial object
@param password 32-bit integer password (default is 0)
Adafruit_Fingerprint::Adafruit_Fingerprint(SoftwareSerial *ss, uint32_t password) {
thePassword = password;
theAddress = 0xFFFFFFFF;
hwSerial = NULL;
swSerial = ss;
mySerial = swSerial;
#endif
@brief Instantiates sensor with Hardware Serial
@param hs Pointer to HardwareSerial object
Adafruit_Fingerprint::Adafruit_Fingerprint(HardwareSerial *hs, uint32_t password) {
swSerial = NULL;
#endif
hwSerial = hs;
mySerial = hwSerial;
@brief Initializes serial interface and baud rate
@param baudrate Sensor's UART baud rate (usually 57600, 9600 or 115200)
void Adafruit_Fingerprint::begin(uint32_t baudrate) {
delay(1000); // one second delay to let the sensor 'boot up'
if (hwSerial) hwSerial->begin(baudrate);
if (swSerial) swSerial->begin(baudrate);
#endif
@brief Verifies the sensors' access password (default password is 0x0000000). A good way to also check if the sensors is active and responding
@returns True if password is correct
boolean Adafruit_Fingerprint::verifyPassword(void) {
return checkPassword() == FINGERPRINT_OK;
uint8_t Adafruit_Fingerprint::checkPassword(void) {
GET_CMD_PACKET(FINGERPRINT_VERIFYPASSWORD,
(uint8_t)(thePassword >> 24), (uint8_t)(thePassword >> 16),
(uint8_t)(thePassword >> 8), (uint8_t)(thePassword & 0xFF));
if (packet.data[0] == FINGERPRINT_OK)
return FINGERPRINT_OK;
else
@brief Ask the sensor to take an image of the finger pressed on surface
@returns <code>FINGERPRINT_OK</code> on success
@returns <code>FINGERPRINT_NOFINGER</code> if no finger detected
@returns <code>FINGERPRINT_PACKETRECIEVEERR</code> on communication error
@returns <code>FINGERPRINT_IMAGEFAIL</code> on imaging error
uint8_t Adafruit_Fingerprint::getImage(void) {
SEND_CMD_PACKET(FINGERPRINT_GETIMAGE);
@brief Ask the sensor to convert image to feature template
@param slot Location to place feature template (put one in 1 and another in 2 for verification to create model)
@returns <code>FINGERPRINT_IMAGEMESS</code> if image is too messy
@returns <code>FINGERPRINT_FEATUREFAIL</code> on failure to identify fingerprint features
@returns <code>FINGERPRINT_INVALIDIMAGE</code> on failure to identify fingerprint features
uint8_t Adafruit_Fingerprint::image2Tz(uint8_t slot) {
SEND_CMD_PACKET(FINGERPRINT_IMAGE2TZ,slot);
@brief Ask the sensor to take two print feature template and create a model
@returns <code>FINGERPRINT_ENROLLMISMATCH</code> on mismatch of fingerprints
uint8_t Adafruit_Fingerprint::createModel(void) {
SEND_CMD_PACKET(FINGERPRINT_REGMODEL);
@brief Ask the sensor to store the calculated model for later matching
@param location The model location #
@returns <code>FINGERPRINT_BADLOCATION</code> if the location is invalid
@returns <code>FINGERPRINT_FLASHERR</code> if the model couldn't be written to flash memory
uint8_t Adafruit_Fingerprint::storeModel(uint16_t location) {
SEND_CMD_PACKET(FINGERPRINT_STORE, 0x01, (uint8_t)(location >> 8), (uint8_t)(location & 0xFF));
@brief Ask the sensor to load a fingerprint model from flash into buffer 1
//read a fingerprint template from flash into Char Buffer 1
uint8_t Adafruit_Fingerprint::loadModel(uint16_t location) {
SEND_CMD_PACKET(FINGERPRINT_LOAD, 0x01, (uint8_t)(location >> 8), (uint8_t)(location & 0xFF));
@brief Ask the sensor to transfer 256-byte fingerprint template from the buffer to the UART
@returns <code>FINGE(RPRINT_OK</code> on success
//read a fingerprint template from flash into Char Buffer 2
uint8_t Adafruit_Fingerprint::loadModeltwo(uint16_t location) {
SEND_CMD_PACKET(FINGERPRINT_LOAD, 0x02, (uint8_t)(location >> 8), (uint8_t)(location & 0xFF));
//transfer a fingerprint template from Char Buffer 1 to host computer
uint8_t Adafruit_Fingerprint::getModel(void) {
SEND_CMD_PACKET(FINGERPRINT_UPLOAD, 0x01);
uint8_t Adafruit_Fingerprint::getModel2(void) {
SEND_CMD_PACKET(FINGERPRINT_UPLOAD, 0x02);
@brief Ask the sensor to delete a model in memory
uint8_t Adafruit_Fingerprint::deleteModel(uint16_t location) {
SEND_CMD_PACKET(FINGERPRINT_DELETE, (uint8_t)(location >> 8), (uint8_t)(location & 0xFF), 0x00, 0x01);
@brief Ask the sensor to delete ALL models in memory
uint8_t Adafruit_Fingerprint::emptyDatabase(void) {
SEND_CMD_PACKET(FINGERPRINT_EMPTY);
@brief Ask the sensor to search the current slot 1 fingerprint features to match saved templates. The matching location is stored in <b>fingerID</b> and the matching confidence in <b>confidence</b>
@returns <code>FINGERPRINT_OK</code> on fingerprint match success
@returns <code>FINGERPRINT_NOTFOUND</code> no match made
// high speed search of slot #1 starting at page 0x0000 and page #0x00A3
uint8_t Adafruit_Fingerprint::fingerFastSearch(void) {
GET_CMD_PACKET(FINGERPRINT_HISPEEDSEARCH, 0x01, 0x00, 0x00, 0x00, 0xA3);
fingerID = 0xFFFF;
confidence = 0xFFFF;
fingerID = packet.data[1];
fingerID <<= 8;
fingerID |= packet.data[2];
confidence = packet.data[3];
confidence <<= 8;
confidence |= packet.data[4];
//transfer a fingerprint template from host computer to Char Buffer 2
uint8_t Adafruit_Fingerprint::uploadModel(void) {
uint8_t packet[] = {FINGERPRINT_DOWNLOAD, 0x02};
// ID = 1 [ JEMPOL KIRI]
uint8_t packet2[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x01, 0x55, 0x21, 0x7C, 0x00, 0xC0, 0x0E, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
uint8_t packet3[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x4D};
uint8_t packet4[] = {0x07, 0x19, 0x5E, 0x23, 0x8A, 0xD5, 0x3E, 0x5E, 0x8B, 0x5B, 0x1E, 0x43, 0x15, 0x97, 0xBE, 0x3A, 0x1B, 0x56, 0x9E, 0x16, 0x22, 0xCF, 0xBE, 0x21, 0xAE, 0x8C, 0x9E, 0x2B, 0x2F, 0xCB, 0xFE, 0x13} ;
uint8_t packet5[] = {0x30, 0x0B, 0xBE, 0x73, 0x3A, 0x9A, 0x3E, 0x35, 0x3D, 0x08, 0x3E, 0x6F, 0xBF, 0x59, 0x1E, 0x64, 0x15, 0x84, 0xDF, 0x5D, 0x18, 0xDB, 0x3F, 0x2C, 0x1B, 0x93, 0x1F, 0x25, 0x20, 0x6A, 0x9F, 0x46} ;
uint8_t packet6[] = {0xA1, 0x17, 0xDF, 0x3A, 0xA8, 0x11, 0xFF, 0x1D, 0x7D, 0xEF, 0x01, 0xFF, 0xFF, 0xFF, 0xFF, 0x02, 0x00, 0x82, 0x50, 0xAA, 0xDA, 0x9F, 0x5F, 0xB1, 0xDA, 0xDF, 0x20, 0x35, 0xE3, 0x3F, 0x6B, 0xB6} ;
uint8_t packet7[] = {0x1B, 0xFF, 0x5F, 0xBE, 0xD9, 0x3F, 0x27, 0x41, 0x47, 0xDF, 0x48, 0x2A, 0x55, 0xDC, 0x45, 0x25, 0xD7, 0x3D, 0x44, 0x2E, 0x16, 0x9D, 0x63, 0x28, 0xC6, 0xDA, 0x63, 0x2B, 0xDD, 0x5A, 0x3D, 0x37} ;
uint8_t packet8[] = {0x86, 0x18, 0x3B, 0x2C, 0x80, 0xB9, 0x4B, 0xB4, 0xC3, 0xF9, 0x3C, 0x32, 0xAC, 0x91, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00} ;
uint8_t packet9[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00} ;
uint8_t packet10[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x83, 0xEF, 0x01, 0xFF, 0xFF, 0xFF, 0xFF, 0x02, 0x00, 0x82, 0x03, 0x01, 0x53};
uint8_t packet11[] = {0x22, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
uint8_t packet12[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x4F, 0x84, 0x59, 0x1E, 0x27, 0x09, 0x54, 0x9E, 0x40, 0x18, 0xD6};
uint8_t packet13[] = {0x1E, 0x0D, 0x1A, 0x8F, 0x9E, 0x2C, 0x9D, 0xAA, 0x1E, 0x1D, 0x21, 0x8F, 0x5E, 0x08, 0x2A, 0x64, 0xBE, 0x2A, 0xAC, 0x0C, 0x1E, 0x34, 0x2D, 0xCB, 0xBE, 0x08, 0x3F, 0x88, 0xBE, 0x61, 0x09, 0x1A};
uint8_t packet14[] = {0xDF, 0x68, 0x92, 0x04, 0xBF, 0x49, 0x13, 0x97, 0x3F, 0x62, 0x15, 0x1A, 0xDF, 0x32, 0x99, 0x92, 0xDF, 0x43, 0x25, 0x51, 0xDF, 0x58, 0xA7, 0x99, 0xFF, 0x1A, 0xAE, 0x4B, 0x9F, 0x1C, 0xE8, 0xEF};
uint8_t packet15[] = {0x01, 0xFF, 0xFF, 0xFF, 0xFF, 0x08, 0x00, 0x82, 0x68, 0xAE, 0x9A, 0xBF, 0x73, 0xB2, 0x9C, 0x1F, 0x2A, 0x34, 0x62, 0x7F, 0x68, 0xBC, 0x19, 0x7F, 0x30, 0xBF, 0x47, 0xBF, 0x46, 0x41, 0x85, 0x5F};
uint8_t packet16[] = {0x6A, 0xA5, 0x86, 0xDC, 0x50, 0x27, 0x55, 0x9C, 0x4D, 0x1E, 0x17, 0x7D, 0x54, 0xB1, 0xC3, 0xDD, 0x4B, 0x21, 0x96, 0x5A, 0x42, 0x3A, 0xC6, 0x7A, 0x6A, 0x29, 0x5C, 0xFB, 0x4D, 0x2B, 0x15, 0x59};
uint8_t packet17[] = {0x45, 0x2A, 0xC0, 0x10, 0x4A, 0x34, 0xC5, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x25};
writePacket(theAddress, FINGERPRINT_COMMANDPACKET, sizeof(packet), packet);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet2), packet2);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet3), packet3);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet4), packet4);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet5), packet5);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet6), packet6);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet7), packet7);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet8), packet8);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet9), packet9);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet10), packet10);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet11), packet11);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet12), packet12);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet13), packet13);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet14), packet14);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet15), packet15);
delay(10);
writePacket(theAddress, FINGERPRINT_DATAPACKET, sizeof(packet16), packet16);
delay(10);
writePacket(theAddress, FINGERPRINT_ENDDATAPACKET, sizeof(packet17), packet17);
uint8_t len = getReply(packet17);
if ((len != 1) && (packet[0] != FINGERPRINT_ACKPACKET))
return -1;
return packet17[1];
uint8_t Adafruit_Fingerprint::getMatch(void)
// matching
uint8_t packet[] = {FINGERPRINT_MATCH, 0x01};
writePacket(theAddress, FINGERPRINT_COMMANDPACKET, sizeof(packet)+2, packet);
uint8_t len = getReply(packet);
return -1;
confidence = packet[2];
confidence <<= 8;
confidence |= packet[3];
return packet[1];
@brief Ask the sensor for the number of templates stored in memory. The number is stored in <b>templateCount</b> on success.
uint8_t Adafruit_Fingerprint::getTemplateCount(void) {
GET_CMD_PACKET(FINGERPRINT_TEMPLATECOUNT);
templateCount = packet.data[1];
templateCount <<= 8;
templateCount |= packet.data[2];
@brief Set the password on the sensor (future communication will require password verification so don't forget it!!!)
@param password 32-bit password code
uint8_t Adafruit_Fingerprint::setPassword(uint32_t password) {
SEND_CMD_PACKET(FINGERPRINT_SETPASSWORD, (password >> 24), (password >> 16), (password >> 8), password);
@brief Helper function to process a packet and send it over UART to the sensor
@param packet A structure containing the bytes to transmit
void Adafruit_Fingerprint::writeStructuredPacket(const Adafruit_Fingerprint_Packet & packet) {
SERIAL_WRITE_U16(packet.start_code);
SERIAL_WRITE(packet.address[0]);
SERIAL_WRITE(packet.address[1]);
SERIAL_WRITE(packet.address[2]);
SERIAL_WRITE(packet.address[3]);
SERIAL_WRITE(packet.type);
uint16_t wire_length = packet.length + 2;
SERIAL_WRITE_U16(wire_length);
uint16_t sum = ((wire_length)>>8) + ((wire_length)&0xFF) + packet.type;
for (uint8_t i=0; i< packet.length; i++) {
SERIAL_WRITE(packet.data[i]);
sum += packet.data[i];
SERIAL_WRITE_U16(sum);
return;
void Adafruit_Fingerprint::writePacket(uint32_t addr, uint8_t packettype,
uint16_t len, uint8_t *packet) {
#ifdef FINGERPRINT_DEBUG
Serial.print("---> 0x");
Serial.print((uint8_t)(FINGERPRINT_STARTCODE >> 8), HEX);
Serial.print(" 0x");
Serial.print((uint8_t)FINGERPRINT_STARTCODE, HEX);
Serial.print((uint8_t)(addr >> 24), HEX);
Serial.print((uint8_t)(addr >> 16), HEX);
Serial.print((uint8_t)(addr >> 8), HEX);
Serial.print((uint8_t)(addr), HEX);
Serial.print((uint8_t)packettype, HEX);
Serial.print((uint8_t)(len >> 8), HEX);
Serial.print((uint8_t)(len), HEX);
#endif
#if ARDUINO >= 100
mySerial->write((uint8_t)(FINGERPRINT_STARTCODE >> 8));
mySerial->write((uint8_t)FINGERPRINT_STARTCODE);
mySerial->write((uint8_t)(addr >> 24));
mySerial->write((uint8_t)(addr >> 16));
mySerial->write((uint8_t)(addr >> 8));
mySerial->write((uint8_t)(addr));
mySerial->write((uint8_t)packettype);
mySerial->write((uint8_t)(len >> 8));
mySerial->write((uint8_t)(len));
#else
mySerial->print((uint8_t)(FINGERPRINT_STARTCODE >> 8), BYTE);
mySerial->print((uint8_t)FINGERPRINT_STARTCODE, BYTE);
mySerial->print((uint8_t)(addr >> 24), BYTE);
mySerial->print((uint8_t)(addr >> 16), BYTE);
mySerial->print((uint8_t)(addr >> 8), BYTE);
mySerial->print((uint8_t)(addr), BYTE);
mySerial->print((uint8_t)packettype, BYTE);
mySerial->print((uint8_t)(len >> 8), BYTE);
mySerial->print((uint8_t)(len), BYTE);
#endif
uint16_t sum = (len>>8) + (len&0xFF) + packettype;
for (uint8_t i=0; i< len-2; i++) {
#if ARDUINO >= 100
mySerial->write((uint8_t)(packet[i]));
#else
mySerial->print((uint8_t)(packet[i]), BYTE);
#endif
Serial.print(" 0x"); Serial.print(packet[i], HEX);
#endif
sum += packet[i];
//Serial.print("Checksum = 0x"); Serial.println(sum);
Serial.print(" 0x"); Serial.print((uint8_t)(sum>>8), HEX);
Serial.print(" 0x"); Serial.println((uint8_t)(sum), HEX);
#endif
#if ARDUINO >= 100
mySerial->write((uint8_t)(sum>>8));
mySerial->write((uint8_t)sum);
#else
mySerial->print((uint8_t)(sum>>8), BYTE);
mySerial->print((uint8_t)sum, BYTE);
#endif
uint8_t Adafruit_Fingerprint::getReply(uint8_t packet[], uint16_t timeout)
uint8_t reply[20], idx;
uint16_t timer=0;
idx = 0;
Serial.print("<--- ");
#endif
while(true)
while (!mySerial->available())
delay(1);
timer++;
if (timer >= timeout) return FINGERPRINT_TIMEOUT;
// something to read!
reply[idx] = mySerial->read();
Serial.print(" 0x"); Serial.print(reply[idx], HEX);
#endif
if ((idx == 0) && (reply[0] != (FINGERPRINT_STARTCODE >> 8)))
continue;
idx++;
// check packet!
if (idx >= 9) {
if ((reply[0] != (FINGERPRINT_STARTCODE >> 8)) ||
(reply[1] != (FINGERPRINT_STARTCODE & 0xFF)))
return FINGERPRINT_BADPACKET;
uint8_t packettype = reply[6];
//Serial.print("Packet type"); Serial.println(packettype);
uint16_t len = reply[7];
len <<= 8;
len |= reply[8];
len -= 2;
//Serial.print("Packet len"); Serial.println(len);
if (idx <= (len+10)) continue;
packet[0] = packettype;
for (uint8_t i=0; i<len; i++) {
packet[1+i] = reply[9+i];
Serial.println();
#endif
return len;
@brief Helper function to receive data over UART from the sensor and process it into a packet
@param packet A structure containing the bytes received
@param timeout how many milliseconds we're willing to wait
@returns <code>FINGERPRINT_TIMEOUT</code> or <code>FINGERPRINT_BADPACKET</code> on failure
uint8_t Adafruit_Fingerprint::getStructuredPacket(Adafruit_Fingerprint_Packet * packet, uint16_t timeout) {
uint8_t byte;
uint16_t idx=0, timer=0;
while(true) {
while(!mySerial->available()) {
delay(1);
timer++;
if( timer >= timeout) {
Serial.println("Timed out");
#endif
byte = mySerial->read();
Serial.print("<- 0x"); Serial.println(byte, HEX);
#endif
switch (idx) {
case 0:
if (byte != (FINGERPRINT_STARTCODE >> 8))
continue;
packet->start_code = (uint16_t)byte << 8;
break;
case 1:
packet->start_code |= byte;
if (packet->start_code != FINGERPRINT_STARTCODE)
break;
case 2:
case 3:
case 4:
case 5:
packet->address[idx-2] = byte;
break;
case 6:
packet->type = byte;
break;
case 7:
packet->length = (uint16_t)byte << 8;
break;
case 8:
packet->length |= byte;
break;
default:
packet->data[idx-9] = byte;
if((idx-8) == packet->length)
break;
idx++;
// Shouldn't get here so...
uint8_t packet2[] = {....}
uint8_t packet17[] = {....}
#include <Adafruit_Fingerprint.h>
This is an example sketch for our optical Fingerprint sensor
int getFingerprintIDez();
// pin #11 is IN from sensor (GREEN wire)
// pin #10 is OUT from arduino (WHITE wire)
SoftwareSerial mySerial(11, 10);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
//Adafruit_Fingerprint finger = Adafruit_Fingerprint(&Serial1);
void setup()
while(!Serial);
Serial.begin(9600);
Serial.println("Fingerprint template extractor");
// set the data rate for the sensor serial port
finger.begin(9600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
} else {
Serial.println("Did not find fingerprint sensor :(");
while (1);
// Try to get the templates for fingers 1 through 10
for (int finger = 1; finger < 5; finger++) {
downloadFingerprintTemplate(finger);
uint8_t downloadFingerprintTemplate(uint16_t id)
uint8_t p;
Serial.println("------------------------------------");
p = finger.uploadModel();
switch (p) {
case FINGERPRINT_OK:
Serial.print("upload "); Serial.print(id); Serial.println(" loaded");Serial.println(p);
Serial.read();
break;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_BADPACKET:
Serial.println("Bad packet");
return p;
default:
Serial.println("Unknown error "); Serial.println(p);
//return p;
Serial.print("Attempting to load #"); Serial.println(id);
p = finger.loadModeltwo(id); // FP_LOAD 0x07 -loadModel() for Char Buffer 1 and loadModeltwo() for Char Buffer 2-
switch (p) {
Serial.print("Template "); Serial.print(id); Serial.println(" loaded");
break;
return p;
default:
Serial.print("Unknown error "); Serial.println(p);
return p;
// OK success!
Serial.print("Attempting to get #"); Serial.println(id);
p = finger.getModel2(); // FP_UPLOAD = UPCHAR 0x08 -getModel() for Char Buffer 1 and getModel2() for Char Buffer 2-
switch (p) {
Serial.print("Template "); Serial.print(id); Serial.println(" transferring:");
break;
default:
return p;
// one data packet is 267 bytes. in one data packet, 11 bytes are 'usesless' :D
uint8_t bytesReceived[534]; // 2 data packets
memset(bytesReceived, 0xff, 534);
int i = 0;
while (i < 534 && (millis() - starttime) < 30000) {
if (mySerial.available()) {
bytesReceived[i++] = mySerial.read();
Serial.print(i); Serial.println(" bytes read.");
Serial.println("Decoding packet...");
uint8_t fingerTemplate[512]; // the real template
memset(fingerTemplate, 0xff, 512);
// filtering only the data packets
int uindx = 9, index = 0;
uint32_t full = 0, halo = 0;
while (index < 534) {
while (index < uindx) ++index;
uindx += 256;
while (index < uindx) {
fingerTemplate[index++] = bytesReceived[index];
uindx += 2;
uindx = index + 9;
for (int i = 1; i <= 512; ++i) {
//Serial.print("a"); Serial.print(id); Serial.print("["); Serial.print(i);Serial.print("] = ");
Serial.print("0x"); printHex(fingerTemplate[i] , 2); Serial.print(", ");//Serial.print("/");
//Serial.print(fingerTemplate[i]); Serial.print(", ");//halo = (i+1)*fingerTemplate[i]; Serial.print("/"); Serial.print(halo);
full += halo;
if(i%32 == 0)
Serial.println();
//Serial.print(", ");
// Serial.print("uint8_t packet[] = {");
Serial.print("\t FULL = "); Serial.println(full);
Serial.println("\ndone.");
uint8_t templateBuffer[256];
memset(templateBuffer, 0xff, 256); //zero out template buffer
int index=0;
while ((index < 256) && ((millis() - starttime) < 1000))
templateBuffer[index] = mySerial.read();
index++;
Serial.print(index); Serial.println(" bytes read");
//dump entire templateBuffer. This prints out 16 lines of 16 bytes
for (int count= 0; count < 16; count++)
for (int i = 0; i < 16; i++)
Serial.print("0x");
Serial.print(templateBuffer[count*16+i], HEX);
Serial.print(", ");
Serial.println();
void printHex(int num, int precision) {
char tmp[16];
char format[128];
sprintf(format, "%%.%dX", precision);
sprintf(tmp, format, num);
Serial.print(tmp);
void loop()
finger.getModel2
Sorry fulll ...:(
- MacielDavid
Hello Ianna ! tks for the code.
This code works fine, but, i have one question about this.
Why you create a 'fake' serial, i understand the fingerprint sensor works with the different baud rate . But if a use the same baud rate for send the informations for the serial monitor and send BANNED for the sensor , has any problem ?
I make some tests but doesnt work fine, when i use the Serial.Write commands or Serial.Reads.
Only works fine when i use the name 'fake' to send the BANNED.
Tks in advanced.
Tks in advanced.
#include <SoftwareSerial.h> //Include the NewSoftSerial library to send serial commands to the cellular module.
#include <string.h>
SoftwareSerial myserial(2,3); //Create a 'fake' serial port. Pin 2 is the Rx verde pin, pin 3 is the Tx bianco pin.
/*----------external commands----------*/
char receive_command[20]={};
char VfyPwd[10]="VfyPwd "; //Verify password
char GenImg[10]="GenImg "; //Record fingerprint image
char UpImg[10]="UpImg "; //Upload image
char DownImg[10]="DownImg "; //Download image
char Img1Tz[10]="Img1Tz "; //Geneated features saved to CharBuffer1
char Img2Tz[10]="Img2Tz "; //Generated features saved to CharBuffer2
char RegMode1[10]="RegMode1 "; //Template of geature combiation
char UpChar[10]="UpChar "; //Upload featues or template
char DownChar[10]="DownChar "; //Download features or template
char Store[10]="Store "; //store template
char LoadChar[10]="LoadChar "; //Read template
char DeletChar[11]="DeletChar "; //delete template
char Empty[10]="Empty "; //clean out fingerprint library
char cnt;
unsigned int Templete_Num;
unsigned int ACK_Sum;
volatile unsigned char UART1_FINGERPRINT_RECEVICE_BUFFER[24];
unsigned char receive_ACK[24];
/*----------FINGERPRINT protocol definition -----------*/
unsigned char FP_Delet_All_Model[6]={0x01,0x0,0x03,0x0d,0x00,0x11};
//delete specified template
unsigned char FP_Pack_Head [6] = {0xEF, 0x01, 0xFF, 0xFF, 0xFF, 0xFF};
/*----------inilization-----------*/
void setup()
Serial.begin(9600); // open serial port, and set the baud rate to 9600 bps
myserial.begin(9600);
/*----------main loop-----------*/
void loop()
Empty_Finger();
void FINGERPRINT_Cmd_Delete_All_Model(void)
unsigned char b;
for(b=0;b<6;b++)
myserial.write(FP_Pack_Head[b]);
for(b=0;b<6;b++)
myserial.write(FP_Delet_All_Model[b]);
void Empty_Finger(void)
FINGERPRINT_Cmd_Delete_All_Model();
for(unsigned char b=0;b<12;b++)
receive_ACK[b]= myserial.read();
if(receive_ACK[9]==0x00)
Serial.println("Empty_OK");
else
Serial.println("Empty_ERROReee");
Serial.println(receive_ACK[9]);
delay(1000);
ianna wrote:here is the solution if it can help someone:Code: Select all
#include <SoftwareSerial.h> //Include the NewSoftSerial library to send serial commands to the cellular module. #include <string.h> SoftwareSerial FPM10A(2,3); //Create a 'fake' serial port. Pin 2 is the Rx verde pin, pin 3 is the Tx bianco pin. /*----------external commands----------*/ char receive_command[20]={}; char VfyPwd[10]="VfyPwd "; //Verify password char GenImg[10]="GenImg "; //Record fingerprint image char UpImg[10]="UpImg "; //Upload image char DownImg[10]="DownImg "; //Download image char Img1Tz[10]="Img1Tz "; //Geneated features saved to CharBuffer1 char Img2Tz[10]="Img2Tz "; //Generated features saved to CharBuffer2 char RegMode1[10]="RegMode1 "; //Template of geature combiation char UpChar[10]="UpChar "; //Upload featues or template char DownChar[10]="DownChar "; //Download features or template char Store[10]="Store "; //store template char LoadChar[10]="LoadChar "; //Read template char DeletChar[11]="DeletChar "; //delete template char Empty[10]="Empty "; //clean out fingerprint library char cnt; unsigned int Templete_Num; unsigned int ACK_Sum; volatile unsigned char UART1_FINGERPRINT_RECEVICE_BUFFER[24]; unsigned char receive_ACK[24]; /*----------FINGERPRINT protocol definition -----------*/ unsigned char FP_Delet_All_Model[6]={0x01,0x0,0x03,0x0d,0x00,0x11}; //delete specified template /*----------inilization-----------*/ void setup() { Serial.begin(9600); // open serial port, and set the baud rate to 9600 bps FPM10A.begin(57600); } /*----------main loop-----------*/ void loop() { Empty_Finger(); } void FINGERPRINT_Cmd_Delete_All_Model(void) { unsigned char b; for(b=0;b<6;b++) FPM10A.write(FP_Pack_Head[b]); for(b=0;b<6;b++) FPM10A.write(FP_Delet_All_Model[b]); } void Empty_Finger(void) { FINGERPRINT_Cmd_Delete_All_Model(); for(unsigned char b=0;b<12;b++) { receive_ACK[b]= FPM10A.read(); } if(receive_ACK[9]==0x00) { Serial.println("Empty_OK"); } else { Serial.println("Empty_ERROReee"); Serial.println(receive_ACK[9]); } delay(1000); }
Hello, everybody. combback with me... :D
Alhamdulillah, i have finished our Project for Research and Development for Fingerprint Module (with ZFM20 or DY50/FPM10A)
This is include file C for Arduino and surely the libraries
Enroll + Match + Upload Template + Show Template + Delete & Empty + Show Image Template + SFG Demo
So, i uploaded in github, you can visit it in
https://github.com/BANNED/M ... Y50-FPM10A
- Attachments
- Fingerprint Module.png (455.95 KiB) Viewed 1282 times
