Fingerprint question
Re: Fingerprint question
by elcio on Fri Nov 18, 2016 9:00 am
Hello, I need a help, I used the speed change using the setSysParaBaud function, I put the number 8 and sent it to the module, now I can no longer communicate with it, is there any way to get back to the initial state, or damage the firmware, Grateful
elcio
by adafruit_support_rick on Fri Nov 18, 2016 9:17 am
Set the baud rate for the fingerprint reader in your sketch to 76800
by elcio on Fri Nov 18, 2016 12:25 pm
Fiz as alterações indicada por vocês para 7800, más não obtive sucesso, teriam mais alguma solução, muito grtato
elcio
by elcio on Fri Nov 18, 2016 12:26 pm
I made the changes indicated by you for 7800, but I did not succeed, they would have some more solution, very much
Sorry, the previous question I put in Portuguese
elcio
by elcio on Fri Nov 18, 2016 12:31 pm
Confirming 76800
elcio
by adafruit_support_rick on Fri Nov 18, 2016 10:08 pm
Does it reset to 9600 if you disconnect power?
If you sent 8 in the setSysParaBaud function, then the baud rate should be 9600*8 = 76800. Are you using hardware serial or software serial to talk with it?
by elcio on Wed Nov 30, 2016 10:44 am
As my friends go, I would like to know and there is the possibility of storing the templates on an SD card, I tried to deploy to save the template from the buffer to the card, but when I put the card library the reader to create the templates, help out? Grateful
elcio
by adafruit_support_rick on Wed Nov 30, 2016 1:01 pm
This is a difficult problem. User Don Jeronimo has developed some code to do it:
viewtopic.php?f=22&t=33229&hilit=template&start=60#p359231
by elcio on Wed Nov 30, 2016 1:23 pm
THE DEVELOPED CODE SEEMS TO BE GOOD, BUT THE GREAT PROBLEM THAT YOU FIND IS TO OPERATE TWO LIBRARIES TOGETHER, THE BIOMETRY AND SDCARD, IT SEEMS THAT THE ARDUIN DOES NOT COMPOSE THE TWO JOINTS, HAVE THIS PROBLEM COME?
elcio
by adafruit_support_rick on Thu Dec 01, 2016 11:15 am
I don't think there is a conflict between the two libraries. If you post your code, I can look for a problem.
by elcio on Thu Dec 01, 2016 11:57 am
I am sending the code, for knowledge, I was able to write closing the communication scenario with the sensor mySerial.end (); , I record the information in the sdcard and after recording I start again, but I do not know if this is correct.
elcio
by adafruit_support_rick on Fri Dec 02, 2016 11:28 am
I don't think there is any need to call mySerial.end().
I would have to see your code.
by adafruit_support_rick on Fri Dec 02, 2016 11:29 am
by elcio on Fri Dec 02, 2016 11:48 am
I sent attachment in the last message
elcio
by adafruit_support_rick on Fri Dec 02, 2016 12:05 pm
there was no attachment in your last message.
