Atmega32u4 Breakout Board/avrdudue Failure
christopher stanton
Post by christopher stanton »
I received an Atmega32u4 breakout board on Friday (7/26/2013) and I believe it is defective.
Linux localhost.localdomain 3.9.8-300.fc19.x86_64 #1 SMP Thu Jun 27 19:24:23 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
The docs on the adafruit page (http://ladyada.net/products/atmega32u4breakout/) and a forum post (http://forums.adafruit.com/viewtopic.php?f=24&t=23266) show the boot LED as green and the power LED as red and they are reversed on my board. And although that is a little odd but not a functional problem (green for power is on makes more sense to me anyway :D ), avrdude is failing on its board check. A couple example run outputs are below:
[2252340.658474] usb 4-4.3: new full-speed USB device number 9 using ohci_hcd
[2252340.759682] usb 4-4.3: New USB device found, idVendor=239a, idProduct=0001
[2252340.759690] usb 4-4.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[2252340.759695] usb 4-4.3: Product: AVR CDC Bootloader
[2252340.761734] cdc_acm 4-4.3:1.0: ttyACM0: USB ACM device
[cstanton@localhost a02]$ sudo avrdude -v -p m32u4 -P /dev/ttyACM0 -c avr109
avrdude: Version 5.11.1, compiled on Jun 18 2013 at 10:33:15
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/etc/avrdude/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : avr109
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 1024 8 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "LUFACDC"; type =
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 3.84s
avrdude: Device signature = 0x3f0d0d
avrdude: Expected signature for ATmega32U4 is 1E 95 87
Double check chip, or use -F to override this check.
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Found programmer: Id = "LUFACDC"; type = S
Device code: 0x44
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587
avrdude: safemode: lfuse reads as FC
avrdude: safemode: hfuse reads as D0
avrdude: safemode: efuse reads as C3
avrdude: safemode: Verify error - unable to read hfuse properly. Programmer may not be reliable.
avrdude: safemode: Fuses OK
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Device code: 0x44
avrdude: safemode: Verify error - unable to read efuse properly. Programmer may not be reliable.
avrdude: safemode: To protect your AVR the programming will be aborted
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Device code: 0x44
Device code: 0x3f
Device code: 0x3f
Device code: 0x0d
Device code: 0x3f
Device code: 0x0d
Device code: 0x0d
Device code: 0x3f
Device code: 0x0d
Device code: 0x3f
Device code: 0x0d
Device code: 0x0d
Device code: 0x3f
Device code: 0x0d
Device code: 0x3f
Device code: 0x0d
Device code: 0x0d
Device code: 0x3f
avrdude: butterfly_recv(): programmer is not responding
adafruit_support_rick
Re: Atmega32u4 Breakout Board/avrdudue Failure
Post by adafruit_support_rick »
It looks to me as if the board is working, but the data it's returning is being corrupted. The likeliest culprit would be the USB cable. Can you try using a different one?
If that doesn't help, try a different USB port on your computer.
christopher stanton
You are correct. The board is working and the data stream was being corrupted.
After some additional digging last night I found that avrdude wasn't the only thing trying to access the tty interface.
For some reason Fedora 19 installs ModemManager and enables modem-manager by default. That "service" was attaching to the ttyACM0 interface when it detected the device as well and competing with avrdude. Once I disabled and removed it from the system I was able to access the board with out issue.
Thanks! That's good to know :D
Return to “Other Arduino products from Adafruit”
