What I'm seeing is that the temp is almost always slightly under the setpoint.
// Sous Vide Controller
// Bill Earl - for Adafruit Industries
// Based on the Arduino PID and PID AutoTune Libraries
// by Brett Beauregard
// PID Library
#include <PID_v1.h>
#include <PID_AutoTune_v0.h>
// Libraries for the Adafruit RGB/LCD Shield
#include <Wire.h>
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
// Libraries for the DS18B20 Temperature Sensor
#include <OneWire.h>
#include <DallasTemperature.h>
// So we can save and retrieve settings
#include <EEPROM.h>
// Pin definitions
// Output Relay
#define RelayPin 7
// One-Wire Temperature Sensor
// (Use GPIO pins for power/ground to simplify the wiring)
#define ONE_WIRE_BUS 2
#define ONE_WIRE_PWR 3
#define ONE_WIRE_GND 4
// PID Variables and constants
//Define Variables we'll be connecting to
double Setpoint;
double Input;
double Output;
volatile long onTime = 0;
// pid tuning parameters
double Kp;
double Ki;
double Kd;
// EEPROM addresses for persisted data
const int SpAddress = 0;
const int KpAddress = 8;
const int KiAddress = 16;
const int KdAddress = 24;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
// 10 second Time Proportional Output window
int WindowSize = 10000;
unsigned long windowStartTime;
// Auto Tune Variables and constants
byte ATuneModeRemember=2;
double aTuneStep=500;
double aTuneNoise=1;
unsigned int aTuneLookBack=20;
boolean tuning = false;
boolean preheat = false;
PID_ATune aTune(&Input, &Output);
// DiSplay Variables and constants
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
// These #defines make it easy to set the backlight color
#define RED 0x1
#define YELLOW 0x3
#define GREEN 0x2
#define TEAL 0x6
#define BLUE 0x4
#define VIOLET 0x5
#define WHITE 0x7
#define BUTTON_SHIFT BUTTON_SELECT
unsigned long lastInput = 0; // last button press
byte degree[8] = // define the degree symbol
B00110,
B01001,
B01001,
B00110,
B00000,
B00000,
B00000,
B00000
const int logInterval = 10000; // log every 10 seconds
long lastLogTime = 0;
// States for state machine
enum operatingState { OFF = 0, SETP, RUN, TUNE_P, TUNE_I, TUNE_D, AUTO};
operatingState opState = OFF;
// Sensor Variables and constants
// Data wire is plugged into port 2 on the Arduino
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device address
DeviceAddress tempSensor;
// Setup and diSplay initial screen
void setup()
Serial.begin(9600);
// Initialize Relay Control:
pinMode(RelayPin, OUTPUT); // Output mode to drive relay
digitalWrite(RelayPin, LOW); // make sure it is off to start
// Set up Ground & Power for the sensor from GPIO pins
pinMode(ONE_WIRE_GND, OUTPUT);
digitalWrite(ONE_WIRE_GND, LOW);
pinMode(ONE_WIRE_PWR, OUTPUT);
digitalWrite(ONE_WIRE_PWR, HIGH);
// Initialize LCD DiSplay
lcd.begin(16, 2);
lcd.createChar(1, degree); // create degree symbol from the binary
lcd.setBacklight(VIOLET);
lcd.print(F(" Adafruit"));
lcd.setCursor(0, 1);
lcd.print(F(" Sous Vide!"));
// Start up the DS18B20 One Wire Temperature Sensor
sensors.begin();
if (!sensors.getAddress(tempSensor, 0))
lcd.print(F("Sensor Error"));
sensors.setResolution(tempSensor, 12);
sensors.setWaitForConversion(false);
delay(3000); // Splash screen
// Initialize the PID and related variables
LoadParameters();
myPID.SetTunings(Kp,Ki,Kd);
myPID.SetSampleTime(1000);
myPID.SetOutputLimits(0, WindowSize);
// Run timer2 interrupt every 15 ms
TCCR2A = 0;
TCCR2B = 1<<CS22 | 1<<CS21 | 1<<CS20;
//Timer2 Overflow Interrupt Enable
TIMSK2 |= 1<<TOIE2;
// Timer Interrupt Handler
SIGNAL(TIMER2_OVF_vect)
if (opState == OFF)
digitalWrite(RelayPin, LOW); // make sure relay is off
else
DriveOutput();
// Main Control Loop
// All state changes pass through here
void loop()
// wait for button release before changing state
while(ReadButtons() != 0) {}
lcd.clear();
switch (opState)
case OFF:
Off();
break;
case SETP:
Adjust_Sp();
break;
case RUN:
Run();
break;
case TUNE_P:
TuneP();
break;
case TUNE_I:
TuneI();
break;
case TUNE_D:
TuneD();
break;
// Initial State - press RIGHT to start
void Off()
myPID.SetMode(MANUAL);
lcd.setBacklight(0);
uint8_t buttons = 0;
while(!(buttons & (BUTTON_RIGHT)))
buttons = ReadButtons();
// Prepare to transition to the RUN state
sensors.requestTemperatures(); // Start an asynchronous temperature reading
//turn the PID on
myPID.SetMode(AUTOMATIC);
windowStartTime = millis();
opState = RUN; // start control
// Setpoint Entry State
// UP/DOWN to change setpoint
// RIGHT for tuning parameters
// LEFT for OFF
// SHIFT for 10x tuning
void Adjust_Sp()
lcd.setBacklight(TEAL);
lcd.print(F("Set Temperature:"));
while(true)
float increment = 0.1;
if (buttons & BUTTON_SHIFT)
increment *= 10;
if (buttons & BUTTON_LEFT)
opState = RUN;
return;
if (buttons & BUTTON_RIGHT)
opState = TUNE_P;
return;
if (buttons & BUTTON_UP)
Setpoint += increment;
delay(200);
if (buttons & BUTTON_DOWN)
Setpoint -= increment;
delay(200);
if ((millis() - lastInput) > 3000) // return to RUN after 3 seconds idle
opState = RUN;
return;
lcd.setCursor(0,1);
lcd.print(Setpoint);
lcd.print(" ");
DoControl();
// Proportional Tuning State
// UP/DOWN to change Kp
// RIGHT for Ki
// LEFT for setpoint
void TuneP()
lcd.print(F("Set Kp"));
while(true)
float increment = 1.0;
increment *= 10;
opState = SETP;
return;
opState = TUNE_I;
return;
Kp += increment;
delay(200);
Kp -= increment;
delay(200);
opState = RUN;
return;
lcd.setCursor(0,1);
lcd.print(Kp);
lcd.print(" ");
DoControl();
// Integral Tuning State
// UP/DOWN to change Ki
// RIGHT for Kd
// LEFT for Kp
void TuneI()
lcd.print(F("Set Ki"));
while(true)
float increment = 0.01;
increment *= 10;
opState = TUNE_P;
return;
opState = TUNE_D;
return;
Ki += increment;
delay(200);
Ki -= increment;
delay(200);
opState = RUN;
return;
lcd.setCursor(0,1);
lcd.print(Ki);
lcd.print(" ");
DoControl();
// Derivative Tuning State
// UP/DOWN to change Kd
// RIGHT for setpoint
// LEFT for Ki
void TuneD()
lcd.print(F("Set Kd"));
while(true)
increment *= 10;
opState = TUNE_I;
return;
opState = RUN;
return;
Kd += increment;
delay(200);
Kd -= increment;
delay(200);
opState = RUN;
return;
lcd.setCursor(0,1);
lcd.print(Kd);
lcd.print(" ");
DoControl();
// PID COntrol State
// SHIFT and RIGHT for autotune
// RIGHT - Setpoint
// LEFT - OFF
void Run()
// set up the LCD's number of rows and columns:
lcd.print(F("Sp: "));
lcd.write(1);
lcd.print(F("C : "));
SaveParameters();
while(true)
setBacklight(); // set backlight based on state
if ((buttons & BUTTON_SHIFT)
&& (buttons & BUTTON_RIGHT)
&& (abs(Input - Setpoint) < 0.5)) // Should be at steady-state
StartAutoTune();
else if (buttons & BUTTON_RIGHT)
opState = SETP;
return;
else if (buttons & BUTTON_LEFT)
opState = OFF;
return;
DoControl();
lcd.setCursor(0,1);
lcd.print(Input);
lcd.write(1);
float pct = map(Output, 0, WindowSize, 0, 1000);
lcd.setCursor(10,1);
lcd.print(F(" "));
lcd.print(pct/10);
//lcd.print(Output);
lcd.print("%");
lcd.setCursor(15,0);
if (preheat)
lcd.print("P");
else if (tuning)
lcd.print("T");
else
lcd.print(" ");
// periodically log to serial port in csv format
if (millis() - lastLogTime > logInterval)
Serial.print(Input);
Serial.print(",");
Serial.println(Output);
delay(100);
// Execute the control loop
void DoControl()
// Read the input:
if (sensors.isConversionAvailable(0))
Input = sensors.getTempC(tempSensor);
sensors.requestTemperatures(); // prime the pump for the next one - but don't wait
if (tuning) // run the auto-tuner
if (aTune.Runtime()) // returns 'true' when done
FinishAutoTune();
else // Execute control algorithm
if (Setpoint - Input > 3)
preheat = true; // suppress control until within range
Output = WindowSize;
else
preheat = false;
myPID.Compute();
// Time Proportional relay state is updated regularly via timer interrupt.
onTime = Output;
// Called by ISR every 15ms to drive the output
void DriveOutput()
long now = millis();
// Set the output
// "on time" is proportional to the PID output
if(now - windowStartTime>WindowSize)
{ //time to shift the Relay Window
windowStartTime += WindowSize;
if((onTime > 100) && (onTime > (now - windowStartTime)))
digitalWrite(RelayPin,HIGH);
else
digitalWrite(RelayPin,LOW);
// Set Backlight based on the state of control
void setBacklight()
if (tuning)
lcd.setBacklight(VIOLET); // Tuning Mode
else if (abs(Input - Setpoint) > 1.0)
lcd.setBacklight(RED); // High Alarm - off by more than 1 degree
else if (abs(Input - Setpoint) > 0.2)
lcd.setBacklight(YELLOW); // Low Alarm - off by more than 0.2 degrees
else
lcd.setBacklight(WHITE); // We're on target!
// Start the Auto-Tuning cycle
void StartAutoTune()
// REmember the mode we were in
ATuneModeRemember = myPID.GetMode();
// set up the auto-tune parameters
aTune.SetNoiseBand(aTuneNoise);
aTune.SetOutputStep(aTuneStep);
aTune.SetLookbackSec((int)aTuneLookBack);
tuning = true;
// Return to normal control
void FinishAutoTune()
tuning = false;
// Extract the auto-tune calculated parameters
Kp = aTune.GetKp();
Ki = aTune.GetKi();
Kd = aTune.GetKd();
// Re-tune the PID and revert to normal control mode
myPID.SetMode(ATuneModeRemember);
// Persist any changed parameters to EEPROM
SaveParameters();
// Check buttons and time-stamp the last press
uint8_t ReadButtons()
uint8_t buttons = lcd.readButtons();
if (buttons != 0)
lastInput = millis();
return buttons;
// Save any parameter changes to EEPROM
void SaveParameters()
if (Setpoint != EEPROM_readDouble(SpAddress))
EEPROM_writeDouble(SpAddress, Setpoint);
if (Kp != EEPROM_readDouble(KpAddress))
EEPROM_writeDouble(KpAddress, Kp);
if (Ki != EEPROM_readDouble(KiAddress))
EEPROM_writeDouble(KiAddress, Ki);
if (Kd != EEPROM_readDouble(KdAddress))
EEPROM_writeDouble(KdAddress, Kd);
// Load parameters from EEPROM
void LoadParameters()
// Load from EEPROM
Setpoint = EEPROM_readDouble(SpAddress);
Kp = EEPROM_readDouble(KpAddress);
Ki = EEPROM_readDouble(KiAddress);
Kd = EEPROM_readDouble(KdAddress);
// Use defaults if EEPROM values are invalid
if (isnan(Setpoint))
Setpoint = 60;
if (isnan(Kp))
Kp = 850;
if (isnan(Ki))
Ki = 0.5;
if (isnan(Kd))
Kd = 0.1;
// Write floating point values to EEPROM
void EEPROM_writeDouble(int address, double value)
byte* p = (byte*)(void*)&value;
for (int i = 0; i < sizeof(value); i++)
EEPROM.write(address++, *p++);
// Read floating point values from EEPROM
double EEPROM_readDouble(int address)
double value = 0.0;
*p++ = EEPROM.read(address++);
return value;
