Can you please tell me the dimensions for the mounting holes on the backpack?
I tried to measure but can only approximate 2mm diameter holes spaced 36mm on center one way and 28mm on center the other way.
Thanks.
1.2" 8x8 LED Matrix w/I2C Backpack
Re: 1.2" 8x8 LED Matrix w/I2C Backpack
Our standard mounting hole is 0.081" (2.1mm).
The hole spacing on mine is 1.1" (just under 28mm) OC along the short axis and 1.45" (36.8mm) OC on the long axis.
- danzeman
Is there a cad model or a drawing with dimensions for the 1.2 and 0.8" 8x8 LED Matrix w/I2C Backpack? It would realy help for doing mechanical layout in CAD.
