Have you tried different cables between the printer and power supply?
It could also simply be that the printer has failed.
Mini Thermal Receipt Printer Issues
- adafruit_support_rick
- vishal_jogi
Re: Mini Thermal Receipt Printer Issues
Hi Team,
Before logging this case with you, I checked all the possibility w.r.t connection :) the only thing which I never tested earlier was main power supply.
When you say failed, does it mean it is dead :( then what other alternative I have ??
Regards,
Vishal
Regards,
Vishal
- vishal_jogi
Hi Team,
Kindly help fix the problem I am facing.
Their must be some way to fix this right? may be by updating firmware etc. If you have any instruction then let me know and I can try updating it.
Please keep in mind that its urgent for me to fix this issue on priority. Hoping to get quick resolution.
Regards,
Vishal
Regards,
Vishal
I don't know of any repair that you can make. The only we information we have on the "CP437" problem is that is appears to be a power issue. The printing samples you have posted also point to a power issue. If the power is good, then the only other possibility is that the printer itself has failed.
- vishal_jogi
Hi Team,
Can you replace this printer? as I said earlier, it hardly worked for me and now I am stuck!
Regards,
Vishal
Regards,
Vishal
Our warranty period is 30 days. You have had this printer for over a year.
- vishal_jogi
Hello Team,
OK got it, I was very late in reporting this issue to you. But as I said I hardly used it. Anyway thanks for the help!
I had seen many You tube videos and the printer works very cool for many people and hence I bought it, but it never worked for me that way and hence very disappointed. Kind a bitter experience with the purchase.
Regards,
Vishal
Regards,
Vishal
- nearengine
I wasn't able to get mine to print more than a couple lines with any of my cheap 2A adapters. While the product page recommends 2A, I've found a 4-10A switching power supply is the only way to get this thing working.vishal_jogi wrote:Hello Team,
Regards,
Vishal
- gadix
Hi guys
Some idea for re-flash CSN a2 T? i have v2.2 Firmware and not support CODEPAGES!
A lot of thanks
A lot of thanks
- ryantan
Hi, just received my printer yesterday, but it's not printing the test. I am using the following products:
https://www.adafruit.com/products/276
https://www.adafruit.com/products/368
https://www.adafruit.com/product/597
And following this guide:
https://learn.adafruit.com/mini-thermal ... first-test
When i turn on the power, the green led flashes. When I press the button, the paper rolls out for about 10mm, then stops, no printing.
I have attached a photo of the front of the printer, is the black stains normal?
- Photo 14-5-16 5 26 23 pm.jpg (188.5 KiB) Viewed 1467 times
Have you got the paper installed the right way around, like this?
The paper isn't binding at all, is it?
- ryantan
Yep, in fact if I press the button repeatedly, it emits the paper without any issue. Expended about 2 feet of paper while trying this.
Please email [email protected] with a link to this thread for a replacement printer
- misadeks
Hi, i have found a solution for this problem. I`ve contacted the manufacturer and they have sent me the older firmware version. The firmware and the upload tool are in the attachment. You will need a USB FTDI cable or breakout to upload it. You can also change the baud rate and the character page on your printer.
- update firmware.zip
- (432.06 KiB) Downloaded 201 times
- adafruit2
huh thx, we'll add to the tutorial page!
