JOS and Adafruit_ILI9341 Touch shield v2 (touch not working)
adafruit_support_rick
Re: JOS and Adafruit_ILI9341 Touch shield v2 (touch not work
Oh, I see what it's doing. Never mind. It's OK.
How do you have it wired? The Adafruit_ILI9341 library doesn't support the 8-bit wiring. It's SPI-only.
For 8-bit mode, you need to use the Adafruit_TFTLCD library
https://learn.adafruit.com/adafruit-2-d ... ry-install
SafetyComp
Post by SafetyComp »
I included the new Libraries and here is what I am getting.
I am using the 2.8" Touchscreen Breakout with a Mega.
I feel like I am so close too.
Any help would be greatly appreciated.
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Build options changed, rebuilding all
JOS-Touch_2016.ino: In function 'void setup()':
JOS-Touch_2016:128: error: 'ts' was not declared in this scope
JOS-Touch_2016.ino: In function 'void loop()':
JOS-Touch_2016:269: error: 'TS_Point' was not declared in this scope
JOS-Touch_2016:269: error: expected ';' before 'p'
JOS-Touch_2016:270: error: 'ts' was not declared in this scope
JOS-Touch_2016:271: error: 'p' was not declared in this scope
JOS-Touch_2016:280: error: 'p' was not declared in this scope
JOS-Touch_2016:681: error: a function-definition is not allowed here before '{' token
JOS-Touch_2016:1318: error: expected '}' at end of input
enabled in File > Preferences.
JOS-Touch_2016.txt
(41.81 KiB) Downloaded 174 times
SafetyComp
Using the 8-bit wiring as well.
There was no constructor for the ts object. It had been deleted.
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
Also, the type name for the point object is TSPoint, not TS_Point.
There is no ts.begin function in the library. You have to get rid of that:
There is no ts.bufferEmpty function in the library. I had to get rid of that, too
Finally, you were missing a '}' at the end of void loop(), so all of your function declarations were inside of loop. That was leading to erros about functions not being defined in scope.
Here is the updated sketch:
   JOS TFT Touch Beta   version v2.1.0.3 3/07/2013
   Adafruit_TFTLCD.h and Adafruit_TouchScreen.h are from adafruit.com where you can also purchase a really nice 2.8" TFT with touchscreen :)
   Oringinal Sketch written by jeremy saglimbeni: www.thecustomgeek.com
   Updates for uno/mega nathan sobieck: www.sobisource.com
       backlight = pin 10 uno / pin 35 mega
       Must use libraries included / which are Adafruit's current Adafruit_GFX, Adafruit_TFTLCD and TouchScreen Libraries
       as of 3/07/13
       Note if you are using Adafruits TFTLCD Shield. Then you need to uncomment #define USE_ADAFRUIT_SHIELD_PINOUT
      in Adafruit_TFTLCD > Adafruit_TFTLCD.h
       However if you are using the shield Backlight PWM will not function unless you make a few simple hardware changes...
      Learn How Here....http://learn.adafruit.com/2-8-tft-touch-shield/controlling-the-backlight
#include <Adafruit_GFX.h>    // Core graphics library
#include <SPI.h>
#include <Wire.h>      // this is needed even tho we aren't using it
#include <Adafruit_TFTLCD.h>
#include <TouchScreen.h>
#include <EEPROM.h>
/* For the 8 data pins:
  Duemilanove/Diecimila/UNO/etc ('168 and '328 chips) microcontoller:
  D0 connects to digital 8
  D1 connects to digital 9
  D2 connects to digital 2
  D3 connects to digital 3
  D4 connects to digital 4
  D5 connects to digital 5
  D6 connects to digital 6
  D7 connects to digital 7
  For Mega's use pins 22 thru 29 (on the double header at the end)
#define YP A1  // must be an analog pin, use "An" notation!  A1 for shield
#define XM A2  // must be an analog pin, use "An" notation!  A2 for shield
#define YM 23   // can be a digital pin-----uno=9 mega=23      7 for shield
#define XP 22   // can be a digital pin-----uno=8 mega=22      6 for shield
#define TS_MINX 150
#define TS_MINY 130
#define TS_MAXX 3800
#define TS_MAXY 4000
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
// Color definitions - in 5:6:5
#define   BLACK           0x0000
#define   BLUE            0x001F
#define   RED             0xF800
#define   GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
#define TEST            0x1BF5
#define JJCOLOR         0x1CB6
#define JJORNG          0xFD03
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, 0);
int i = 0;
int page = 0;
int blv;
int sleep = 0;
int pulsev = 0;
int redflag = 0;
int greenflag = 0;
int redled = 12;
int greenled = 13;
int backlight = 3;  //pin-10 uno  pin-35 mega  pin-3 for shield if you have done the MOD   for PWM backlight
int battfill;
unsigned long sleeptime;
unsigned long battcheck = 10000; // the amount of time between voltage check and battery icon refresh
unsigned long prevbatt;
int battv;
int battold;
int battpercent;
int barv;
int prevpage;
int sleepnever;
int esleep;
int backlightbox;
int antpos = 278;
unsigned long awakeend;
unsigned long currenttime;
unsigned long ssitime;
char voltage[10];
char battpercenttxt [10];
int getBandgap(void) // Returns actual value of Vcc (x 100) 415 = 4.15v
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
  // For mega boards
  const long InternalReferenceVoltage = 1115L;  // Adjust this value to your boards specific internal BG voltage x1000
  // REFS1 REFS0          --> 0 1, AVcc internal ref. -Selects AVcc reference
  // MUX4 MUX3 MUX2 MUX1 MUX0  --> 11110 1.1V (VBG)         -Selects channel 30, bandgap voltage, to measure
  ADMUX = (0 << REFS1) | (1 << REFS0) | (0 << ADLAR) | (0 << MUX5) | (1 << MUX4) | (1 << MUX3) | (1 << MUX2) | (1 << MUX1) | (0 << MUX0);
#else
  // For 168/328 boards
  const long InternalReferenceVoltage = 1056L;  // Adjust this value to your boards specific internal BG voltage x1000
  // REFS1 REFS0          --> 0 1, AVcc internal ref. -Selects AVcc external reference
  // MUX3 MUX2 MUX1 MUX0  --> 1110 1.1V (VBG)         -Selects channel 14, bandgap voltage, to measure
  ADMUX = (0 << REFS1) | (1 << REFS0) | (0 << ADLAR) | (1 << MUX3) | (1 << MUX2) | (1 << MUX1) | (0 << MUX0);
#endif
  delay(50);  // Let mux settle a little to get a more stable A/D conversion
  // Start a conversion
  ADCSRA |= _BV( ADSC );
  // Wait for it to complete
  while ( ( (ADCSRA & (1 << ADSC)) != 0 ) );
  // Scale the value
  int results = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L; // calculates for straight line value
  return results;
void setup(void) {
  //     ts.begin();
  //       if (!ts.begin()) {
  //    Serial.println("Couldn't start touchscreen controller");
  //    while (1);
  Serial.println("Touchscreen started");
  pinMode(redled, OUTPUT);
  pinMode(greenled, OUTPUT);
  analogReference(5);
  //esleep = EEPROM.read(1);
  esleep = 1;
  blv = EEPROM.read(2);
  if (esleep == 0 && blv == 0) {  // if no previous saves then set sleep and backlight to default.
    EEPROM.write(1, 4);
    EEPROM.write(2, 200);
  if (esleep == 1) {
    sleeptime = 10000;
  if (esleep == 2) {
    sleeptime = 20000;
  if (esleep == 3) {
    sleeptime = 30000;
  if (esleep == 4) {
    sleeptime = 60000;
  if (esleep == 5) {
    sleeptime = 120000;
  if (esleep == 6) {
    sleeptime = 300000;
  if (esleep == 7) {
    sleeptime = 600000;
  if (esleep == 8) {
    sleeptime = 1200000;
  if (esleep == 9) {
    sleeptime = 1800000;
  if (esleep == 10) {
    sleeptime = 3600000;
  if (esleep == 11) {
    sleeptime = 14400000;
  if (esleep == 12) {
    sleepnever = 1;
  awakeend = sleeptime + 30000; // set the current sleep time based on what the saved settings in EEPROM were
  pinMode(backlight, OUTPUT);
  Serial.begin(9600);
  Serial.println("JOS");
  Serial.println("Jeremy Saglimbeni (c) 2011");
  //tft.reset();
  // All this idenifies which LCD driver chip your using and tells Ada's GFX LIB's
  /* uint16_t identifier = tft.readID();
    if(identifier == 0x9325) {
     progmemPrintln(PSTR("Found ILI9325 LCD driver"));
    } else if(identifier == 0x9328) {
     progmemPrintln(PSTR("Found ILI9328 LCD driver"));
      } else if(identifier == 0x9341) {
     progmemPrintln(PSTR("Found ILI9341 LCD driver"));
    } else if(identifier == 0x7575) {
     progmemPrintln(PSTR("Found HX8347G LCD driver"));
    } else {
     progmemPrint(PSTR("Unknown LCD driver chip: "));
     Serial.println(identifier, HEX);
     Serial.println(identifier);
     return;
    tft.begin(identifier);  // this returns the above results. below you can see how I replaced all this once i know which one I have...
  tft.begin();  //=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-==-=-=-=-=-==-=-=-=-=-=-=-=-=-=-=-=-=-==-=-=-=-=-=-=-=-=-=-=-==-
  tft.setRotation(1); //sets landscape mode
  tft.fillScreen(BLACK);
  tft.fillRect(71, 70, 50, 100, JJCOLOR);
  tft.fillRect(134, 70, 50, 100, JJCOLOR);
  tft.fillRect(197, 70, 50, 100, JJCOLOR);
  tft.drawRect(46, 45, 228, 150, WHITE);
  for (i = 0 ; i <= blv; i += 1) {
    analogWrite(backlight, i);
    delay(2);
  delay(250);
  tft.setTextSize(5);
  tft.setTextColor(WHITE);
  tft.setCursor(85, 100);
  tft.println("J");
  delay(250);
  tft.setCursor(147, 100);
  tft.println("O");
  delay(250);
  tft.setCursor(210, 100);
  tft.println("S");
  delay(500);
  tft.setTextSize(1);
  tft.setCursor(100, 210);
  tft.println("Jeremy Saglimbeni 2013");
  tft.setCursor(120, 230);
  tft.println("TheCustomGeek.com");
  delay(2000);//introscreen delay
  tft.fillRect(0, 0, 320, 10, JJCOLOR); // status bar
  drawhomeicon(); // draw the home icon
  tft.setCursor(1, 1);
  tft.println("Your status bar message here.    JOS 2.1 Beta");
  tft.drawRect(297, 1, 20, 8, WHITE); //battery body
  tft.fillRect(317, 3, 2, 4, WHITE); // battery tip
  tft.fillRect(298, 2, 18, 6, BLACK); // clear the center of the battery
  drawbatt();
  ant(); // draw the bas "antenna" line without the "signal waves"
  signal(); // draw the "signal waves" around the "antenna"
  homescr(); // draw the homescreen
  tft.drawRect(0, 200, 245, 40, WHITE); // message box
#define MINPRESSURE 1
#define MAXPRESSURE 1000
  currenttime = millis();
  unsigned long currentawake = millis();
  if ((currentawake > awakeend) && (sleepnever == 0)) {
    if (sleep == 0) {
      for (i = blv ; i >= 0; i -= 1) {
        delay(4);
      sleep = 1;
    TSPoint p;
    p = ts.getPoint();
    // if you're sharing pins, you'll need to fix the directions of the touchscreen pins!
    pinMode(XP, OUTPUT);
    pinMode(XM, OUTPUT);
    pinMode(YP, OUTPUT);
    pinMode(YM, OUTPUT);
    // we have some minimum pressure we consider 'valid'
    // pressure of 0 means no pressing!
    if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
      awakeend = currenttime + sleeptime; //set the sleep time when screen is pressed
      if (sleep == 1) { // if asleep, then fade the backlight up
          delay(1);
        sleep = 0; // change the sleep mode to "awake"
        return;
      // turn from 0->1023 to tft.width
      p.x = map(p.x, TS_MINX, TS_MAXX, 0, 240);//default is (240, 0) [default puts touch cord. 0=x/y upper right.
      p.y = map(p.y, TS_MINY, TS_MAXY, 0, 320);//default is (320, 0) [I change these cause i like 0=xy bottom left.
      Serial.print("p.y:"); // this code will help you get the y and x numbers for the touchscreen
      Serial.print(p.y);
      Serial.print("   p.x:");
      Serial.println(p.x);
      // area 1
      if (p.y > 1 && p.y < 141 && p.x > 175 && p.x < 222) { // if this area is pressed
        if (page == 5) { // and if page 5 is drawn on the screen
          m5b1action(); // do whatever this button is
          tft.setCursor(12, 213);
          tft.setTextColor(RED);
          tft.setTextSize(2);
          tft.println("Menu 5 B1"); // display the command in the "message box"
          yled(550); // flash the LED yellow for a bit - change the 550 value to change LED time on
          clearmessage(); // after the LED goes out, clear the message
        if (page == 4) {
          m4b1action();
          tft.setTextSize(2);
          tft.println("Menu 4 B1");
          yled(550);
          clearmessage();
        if (page == 3) {
          m3b1action();
          tft.setTextSize(2);
          tft.println("Menu 3 B1");
          yled(550);
          clearmessage();
        if (page == 2) {
          m2b1action();
          tft.setTextSize(2);
          tft.println("Menu 2 B1");
          yled(550);
          clearmessage();
        if (page == 1) {
          m1b1action();
          tft.setTextSize(2);
          tft.println("Menu 1 B1");
          yled(550);
          clearmessage();
        if (page == 0) { // if you are on the "home" page (0)
          page = 1; // then you just went to the first page
          redraw(); // redraw the screen with the page value 1, giving you the page 1 menu
      // area 2
      if (p.y > 165 && p.y < 315 && p.x > 176 && p.x < 222) {
        if (page == 5) {
          m5b2action();
          tft.setTextSize(2);
          tft.println("Menu 5 B2");
          yled(550);
          clearmessage();
        if (page == 4) {
          m4b2action();
          tft.setTextSize(2);
          tft.println("Menu 4 B2");
          yled(550);
          clearmessage();
        if (page == 3) {
          m3b2action();
          tft.setTextSize(2);
          tft.println("Menu 3 B2");
          yled(550);
          clearmessage();
        if (page == 2) {
          m2b2action(); tft.setCursor(12, 213);
          tft.setTextSize(2);
          tft.println("Menu 2 B2");
          yled(550);
          clearmessage();
        if (page == 1) {
          m1b2action();
          tft.setTextSize(2);
          tft.println("Menu 1 B2");
          yled(550);
          clearmessage();
        if (page == 0) {
          page = 2;
          redraw();
      // area 3
      if (p.y > 1 && p.y < 141 && p.x > 115 && p.x < 163) {
        if (page == 5) {
          m5b3action();
          tft.setTextSize(2);
          tft.println("Menu 5 B3");
          yled(550);
          clearmessage();
        if (page == 4) {
          m4b3action();
          tft.setTextSize(2);
          tft.println("Menu 4 B3");
          yled(550);
          clearmessage();
        if (page == 3) {
          m3b3action();
          tft.setTextSize(2);
          tft.println("Menu 3 B3");
          yled(550);
          clearmessage();
        if (page == 2) {
          m2b3action();
          tft.setTextSize(2);
          tft.println("Menu 2 B3");
          yled(550);
          clearmessage();
        if (page == 1) {
          m1b3action();
          tft.setTextSize(2);
          tft.println("Menu 1 B3");
          yled(550);
          clearmessage();
        if (page == 0) {
          page = 3;
          redraw();
      // area 4
      if (p.y > 165 && p.y < 315 && p.x > 115 && p.x < 163) {
        if (page == 5) {
          m5b4action();
          tft.setTextSize(2);
          tft.println("Menu 5 B4");
          yled(550);
          clearmessage();
        if (page == 4) {
          m4b4action();
          tft.setTextSize(2);
          tft.println("Menu 4 B4");
          yled(550);
          clearmessage();
        if (page == 3) {
          m3b4action();
          tft.setTextSize(2);
          tft.println("Menu 3 B4");
          yled(550);
          clearmessage();
        if (page == 2) {
          m2b4action();
          tft.setTextSize(2);
          tft.println("Menu 2 B4");
          yled(550);
          clearmessage();
        if (page == 1) {
          m1b4action();
          tft.setTextSize(2);
          tft.println("Menu 1 B4");
          yled(550);
          clearmessage();
        if (page == 0) {
          page = 4;
          redraw();
      // area 5
      if (p.y > 1 && p.y < 141 && p.x > 57 && p.x < 101) {
        if (page == 5) {
          m5b5action();
          tft.setTextSize(2);
          tft.println("Menu 5 B5");
          yled(550);
          clearmessage();
        if (page == 4) {
          m4b5action();
          tft.setTextSize(2);
          tft.println("Menu 4 B5");
          yled(550);
          clearmessage();
        if (page == 3) {
          m3b5action();
          tft.setTextSize(2);
          tft.println("Menu 3 B5");
          yled(550);
          clearmessage();
        if (page == 2) {
          m2b5action();
          tft.setTextSize(2);
          tft.println("Menu 2 B5");
          yled(550);
          clearmessage();
        if (page == 1) {
          m1b5action();
          tft.setTextSize(2);
          tft.println("Menu 1 B5");
          yled(550);
          clearmessage();
        if (page == 0) {
          page = 5;
          redraw();
      // area 6
      if (p.y > 165 && p.y < 315 && p.x > 57 && p.x < 101) {
        if (page == 5) {
          m5b6action();
          tft.setTextSize(2);
          tft.println("Menu 5 B6");
          yled(550);
          clearmessage();
        if (page == 4) {
          m4b6action();
          tft.setTextSize(2);
          tft.println("Menu 4 B6");
          yled(550);
          clearmessage();
        if (page == 3) {
          m3b6action();
          tft.setTextSize(2);
          tft.println("Menu 3 B6");
          yled(550);
          clearmessage();
        if (page == 2) {
          m2b6action();
          tft.setTextSize(2);
          tft.println("Menu 2 B6");
          yled(550);
          clearmessage();
        if (page == 1) {
          m1b6action();
          tft.setTextSize(2);
          tft.println("Menu 1 B6");
          yled(550);
          clearmessage();
        if (page == 0) {
          page = 6;
          redraw();
      // home
      if (p.y > 269 && p.y < 320 && p.x > 1 && p.x < 47) { // if the home icon is pressed
        if (page == 6) { // if you are leaving the settings page
          clearmessage(); // clear the battery voltage out of the message box
          tft.setTextSize(2);
          tft.println("Settings Saved"); // display settings saved in message box
          EEPROM.write(1, esleep); // write the sleep value to EEPROM, so it will not lose settings without power
          EEPROM.write(2, blv); // write the backlight value to EEPROM, so it will not lose settings without power
          clearsettings(); // erase all the drawings on the settings page
        if (page == 0) { // if you are already on the home page
          drawhomeiconred(); // draw the home icon red
          delay(250); // wait a bit
          drawhomeicon(); // draw the home icon back to white
          return; // if you were on the home page, stop.
        else { // if you are not on the settings, home, or keyboard page
          page = prevpage; // a value to keep track of what WAS on the screen to redraw/erase only what needs to be
          page = 0; // make the current page home
          redraw(); // redraw the page
      // message area
      if (p.y > 1 && p.y < 240 && p.x > 1 && p.x < 44) {
        clearmessage(); // erase the message
      // backlight buttons
      if (p.y > 1 && p.y < 50 && p.x > 175 && p.x < 222) {  //-
        if (page == 6) {
          blightdown();
      if (p.y > 259 && p.y < 315 && p.x > 175 && p.x < 222) {  //+
        if (page == 6) {
          blightup();
      // sleep buttons
      if (p.y > 1 && p.y < 50 && p.x > 115 && p.x < 163) {
        if (page == 6) {
          sleepdec();
      if (p.y > 259 && p.y < 315 && p.x > 115 && p.x < 163) {
        if (page == 6) {
          sleepinc();
        // optional buttons
        if (p.y > 1 && p.y < 50 && p.x > 52 && p.x < 100) {
        if (page == 6) {
        option3down();
        if (p.y > 259 && p.y < 315 && p.x > 52 && p.x < 100) {
        if (page == 6) {
        option3up();
    if (currenttime - prevbatt > battcheck) {
      drawbatt();
      prevbatt = currenttime;
  void yled(int xled) { // "flashes" the "yellow" LED
    for (i = xled ; i >= 0; i -= 1) {
      digitalWrite(greenled, LOW);
      digitalWrite(redled, HIGH);
      delay(1);
      digitalWrite(greenled, HIGH);
      digitalWrite(redled, LOW);
      delay(1);
    if (greenflag == 1) {
    if (redflag == 1) {
  void redraw() { // redraw the page
    if ((prevpage != 6) || (page != 7)) {
      clearcenter();
    if (page == 0) {
      homescr();
    if (page == 1) {
      menu1();
    if (page == 2) {
      menu2();
    if (page == 3) {
      menu3();
    if (page == 4) {
      menu4();
    if (page == 5) {
      menu5();
    if (page == 6) {
      settingsscr();
  void clearcenter() { // the reason for so many small "boxes" is that it's faster than filling the whole thing
    tft.drawRect(0, 20, 150, 50, BLACK);
    tft.drawRect(170, 20, 150, 50, BLACK);
    tft.drawRect(0, 80, 150, 50, BLACK);
    tft.drawRect(170, 80, 150, 50, BLACK);
    tft.drawRect(0, 140, 150, 50, BLACK);
    tft.drawRect(170, 140, 150, 50, BLACK);
    tft.fillRect(22, 37, 106, 16, BLACK);
    tft.fillRect(192, 37, 106, 16, BLACK);
    tft.fillRect(22, 97, 106, 16, BLACK);
    tft.fillRect(192, 97, 106, 16, BLACK);
    tft.fillRect(22, 157, 106, 16, BLACK);
    tft.fillRect(192, 157, 106, 16, BLACK);
  void clearsettings() { // this is used to erase the extra drawings when exiting the settings page
    tft.fillRect(0, 20, 320, 110, BLACK);
    delay(500);
    clearmessage();
  void homescr() {
    boxes();
    tft.setTextSize(2);
    tft.setCursor(41, 37);
    tft.println("Menu 1");
    tft.setCursor(210, 37);
    tft.println("Menu 2");
    tft.setCursor(41, 97);
    tft.println("Menu 3");
    tft.setCursor(210, 97);
    tft.println("Menu 4");
    tft.setCursor(41, 157);
    tft.println("Menu 5");
    tft.setCursor(200, 157);
    tft.println("Settings");
  void menu1() {
    boxes();
    tft.setTextSize(2);
    tft.setCursor(22, 37);
    tft.setCursor(192, 37);
    tft.setCursor(22, 97);
    tft.setCursor(192, 97);
    tft.setCursor(22, 157);
    tft.setCursor(192, 157);
  void menu2() {
    boxes();
    tft.setTextSize(2);
  void menu3() {
    boxes();
    tft.setTextSize(2);
  void menu4() {
    boxes();
    tft.setTextSize(2);
  void menu5() {
    boxes();
    tft.setTextSize(2);
  void settingsscr() {
    // backlight level
    tft.fillRect(0, 20, 60, 50, RED);
    tft.drawRect(0, 20, 60, 50, WHITE);
    tft.drawRect(80, 20, 160, 50, JJCOLOR);
    tft.fillRect(260, 20, 60, 50, GREEN);
    tft.drawRect(260, 20, 60, 50, WHITE);
    tft.setTextSize(3);
    tft.setCursor(22, 33);
    tft.println("-");
    tft.setTextSize(1);
    tft.setCursor(120, 31);
    tft.println("Backlight Level");
    tft.setTextSize(3);
    tft.setCursor(282, 33);
    tft.println("+");
    tft.drawRect(110, 48, 100, 10, WHITE);
    blbar();
    // sleep time
    tft.fillRect(0, 80, 60, 50, RED);
    tft.drawRect(0, 80, 60, 50, WHITE);
    tft.drawRect(80, 80, 160, 50, JJCOLOR);
    tft.fillRect(260, 80, 60, 50, GREEN);
    tft.drawRect(260, 80, 60, 50, WHITE);
    tft.setTextSize(3);
    tft.setCursor(22, 93);
    tft.println("-");
    tft.setTextSize(2);
    tft.setCursor(100, 91);
    tft.println("Sleep Time");
    tft.setTextSize(3);
    tft.setCursor(282, 93);
    tft.println("+");
    showsleep();
    //?? uncomment this if you want a third adjustable option
      tft.fillRect(0, 140, 60, 50, RED);
      tft.drawRect(0, 140, 60, 50, WHITE);
      tft.drawRect(80, 140, 160, 50, JJCOLOR);
      tft.fillRect(260, 140, 60, 50, GREEN);
      tft.drawRect(260, 140, 60, 50, WHITE);
            tft.setTextSize(3);
            tft.setCursor(22, 153);
      tft.println("-");
           tft.setTextSize(1);
           tft.setCursor(130, 151);
      tft.println("Thing #3");
           tft.setTextSize(3);
           tft.setCursor(282, 153);
      tft.drawString("+");
      tft.drawRect(110, 168, 100, 10, WHITE);
    battv = getBandgap(); // read the voltage getBandgap
    itoa (battv, voltage, 10); // converts integer to string
    decimate(voltage, 2); // converts string to decimal point
    tft.setTextColor(YELLOW);
    tft.setTextSize(2);
    tft.setCursor(25, 213);
    tft.println(voltage);
    tft.setTextSize(2);
    tft.setCursor(13, 213);
    tft.println("V");
    battpercent = (battv / 480) * 100, 2;  // if using battery set 480(4.80v) to fresh charge value
    battpercent = constrain(battpercent, 1, 100);  // battery percent between 1% and 100%
    itoa (battpercent, battpercenttxt, 10);
    tft.setTextSize(2);
    tft.setCursor(130, 213);
    tft.println(battpercenttxt);
    tft.setTextSize(2);
    tft.setCursor(115, 213);
    tft.println("%");
  void decimate(char test[], int dec) { // creates decimal function  decimate(string containing integer, number of decimal places)
    int i = 0;
    int length = strlen(test);
    char msg[10] = "";
    strcpy(msg, test);
    if (length <= dec) {
      for (i = dec; i > (dec - length); i--)  msg[i] = msg[i - (dec - length + 1)];
      for (i = 0; i < (dec + 1 - length); i++)  msg[i] = '0';
      length = strlen(msg);
    for (i = length; i > (length - dec); i--)  msg[i] = msg[i - 1];
    msg[length - dec] = '.';
    strcpy(test, msg);
  void sleepinc() { // sleep increese adjustment
    if (sleeptime == 14400000) {
      sleepnever = 1;
      esleep = 12;
      sleeptime = 11111111;
      showsleep();
    if (sleeptime == 3600000) {
      esleep = 11;
      showsleep();
    if (sleeptime == 1800000) {
      esleep = 10;
      showsleep();
    if (sleeptime == 1200000) {
      esleep = 9;
      showsleep();
    if (sleeptime == 600000) {
      esleep = 8;
      showsleep();
    if (sleeptime == 300000) {
      sleeptime = 600000;
      esleep = 7;
      showsleep();
    if (sleeptime == 120000) {
      sleeptime = 300000;
      esleep = 6;
      showsleep();
    if (sleeptime == 60000) {
      sleeptime = 120000;
      esleep = 5;
      showsleep();
    if (sleeptime == 30000) {
      sleeptime = 60000;
      esleep = 4;
      showsleep();
    if (sleeptime == 20000) {
      sleeptime = 30000;
      esleep = 3;
      showsleep();
    if (sleeptime == 10000) {
      sleeptime = 20000;
      esleep = 2;
      showsleep();
    delay(350);
  void sleepdec() { // sleep decreese adjustment
      sleeptime = 10000;
      esleep = 1;
      showsleep();
      sleeptime = 20000;
      esleep = 2;
      showsleep();
      sleeptime = 30000;
      esleep = 3;
      showsleep();
      sleeptime = 60000;
      esleep = 4;
      showsleep();
      sleeptime = 120000;
      esleep = 5;
      showsleep();
      sleeptime = 300000;
      esleep = 6;
      showsleep();
      sleeptime = 600000;
      esleep = 7;
      showsleep();
      esleep = 8;
      showsleep();
      esleep = 9;
      showsleep();
      esleep = 10;
      showsleep();
    if (sleepnever == 1) {
      sleepnever = 0;
      esleep = 11;
      showsleep();
    delay(350);
  void showsleep() { // shows the sleep time on the settings page
    tft.fillRect(110, 108, 80, 10, BLACK);
    tft.setTextSize(1);
      tft.setCursor(130, 108);
      tft.println("10 Seconds");
      tft.println("20 Seconds");
      tft.println("30 Seconds");
      tft.setCursor(136, 108);
      tft.println("1 Minute");
      tft.setCursor(133, 108);
      tft.println("2 Minutes");
      tft.println("5 Minutes");
      tft.println("10 Minutes");
      tft.println("20 Minutes");
      tft.println("30 Minutes");
      tft.setCursor(142, 108);
      tft.println("1 Hour");
      tft.setCursor(139, 108);
      tft.println("4 Hours");
      tft.println("Always On");
  void option3down() { // adjust option 3 down in the settings screen
  void option3up() { // adjust option 3 up in the settings screen
  //custom defined actions - this is where you put your button functions
  void m1b1action() {
    signal();
  void m1b2action() {
    signalact();
  void m1b3action() {
  void m1b4action() {
  void m1b5action() {
  void m1b6action() {
  void m2b1action() {
  void m2b2action() {
  void m2b3action() {
  void m2b4action() {
  void m2b5action() {
  void m2b6action() {
  void m3b1action() {
  void m3b2action() {
  void m3b3action() {
  void m3b4action() {
  void m3b5action() {
  void m3b6action() {
  void m4b1action() {
  void m4b2action() {
  void m4b3action() {
  void m4b4action() {
  void m4b5action() {
  void m4b6action() {
  void m5b1action() {
  void m5b2action() {
  void m5b3action() {
  void m5b4action() {
  void m5b5action() {
  void m5b6action() {
  void blightup() { // increase the backlight brightness
    blv = blv + 5;
    if (blv >= 255) {
      blv = 255;
    analogWrite(10, blv);
    blbar();
  void blightdown() { // decrease the backlight brightness
    blv = blv - 5;
    if (blv <= 5) {
      blv = 5;
    blbar();
  void blbar() { // this function fills the yellow bar in the backlight brightness adjustment
    if (blv < barv) {
      tft.fillRect(111, 49, 98, 8, BLACK);
    backlightbox = map(blv, 1, 255, 0, 98);
    tft.fillRect(111, 49, backlightbox, 8, YELLOW);
    barv = blv;
    delay(25);
  void ant() {
    tft.fillRect((antpos + 5), 4, 1, 6, WHITE); // draws the "antenna" for the signal indicator
  void boxes() { // redraw the button outline boxes
    tft.drawRect(0, 20, 150, 50, JJCOLOR);
    tft.drawRect(170, 20, 150, 50, JJCOLOR);
    tft.drawRect(0, 80, 150, 50, JJCOLOR);
    tft.drawRect(170, 80, 150, 50, JJCOLOR);
    tft.drawRect(0, 140, 150, 50, JJCOLOR);
    tft.drawRect(170, 140, 150, 50, JJCOLOR);
  void signal() { // draws a whit 'signal indicator'
    tft.drawLine((antpos + 4), 4, (antpos + 4), 5, WHITE);
    tft.drawPixel((antpos + 3), 2, WHITE);
    tft.drawPixel((antpos + 3), 7, WHITE);
    tft.drawPixel((antpos + 2), 0, WHITE);
    tft.drawLine((antpos + 2), 3, (antpos + 2), 6, WHITE);
    tft.drawPixel((antpos + 2), 9, WHITE);
    tft.drawPixel((antpos + 1), 1, WHITE);
    tft.drawPixel((antpos + 1), 8, WHITE);
    tft.drawLine(antpos, 2, antpos, 7, WHITE);
    tft.drawLine((antpos + 6), 4, (antpos + 6), 5, WHITE);
    tft.drawPixel((antpos + 7), 2, WHITE);
    tft.drawPixel((antpos + 7), 7, WHITE);
    tft.drawPixel((antpos + 8), 0, WHITE);
    tft.drawLine((antpos + 8), 3, (antpos + 8), 6, WHITE);
    tft.drawPixel((antpos + 8), 9, WHITE);
    tft.drawPixel((antpos + 9), 1, WHITE);
    tft.drawPixel((antpos + 9), 8, WHITE);
    tft.drawLine((antpos + 10), 2, (antpos + 10), 7, WHITE);
  void signalact() { // draws a red'signal indicator'
    tft.drawLine((antpos + 4), 4, (antpos + 4), 5, RED);
    tft.drawPixel((antpos + 3), 2, RED);
    tft.drawPixel((antpos + 3), 7, RED);
    tft.drawPixel((antpos + 2), 0, RED);
    tft.drawLine((antpos + 2), 3, (antpos + 2), 6, RED);
    tft.drawPixel((antpos + 2), 9, RED);
    tft.drawPixel((antpos + 1), 1, RED);
    tft.drawPixel((antpos + 1), 8, RED);
    tft.drawLine(antpos, 2, antpos, 7, RED);
    tft.drawLine((antpos + 6), 4, (antpos + 6), 5, RED);
    tft.drawPixel((antpos + 7), 2, RED);
    tft.drawPixel((antpos + 7), 7, RED);
    tft.drawPixel((antpos + 8), 0, RED);
    tft.drawLine((antpos + 8), 3, (antpos + 8), 6, RED);
    tft.drawPixel((antpos + 8), 9, RED);
    tft.drawPixel((antpos + 9), 1, RED);
    tft.drawPixel((antpos + 9), 8, RED);
    tft.drawLine((antpos + 10), 2, (antpos + 10), 7, RED);
  void drawhomeicon() { // draws a white home icon
    tft.drawLine(280, 219, 299, 200, WHITE);
    tft.drawLine(300, 200, 304, 204, WHITE);
    tft.drawLine(304, 203, 304, 200, WHITE);
    tft.drawLine(305, 200, 307, 200, WHITE);
    tft.drawLine(308, 200, 308, 208, WHITE);
    tft.drawLine(309, 209, 319, 219, WHITE);
    tft.drawLine(281, 219, 283, 219, WHITE);
    tft.drawLine(316, 219, 318, 219, WHITE);
    tft.drawRect(284, 219, 32, 21, WHITE);
    tft.drawRect(295, 225, 10, 15, WHITE);
  void drawhomeiconred() { // draws a red home icon
    tft.drawLine(280, 219, 299, 200, RED);
    tft.drawLine(300, 200, 304, 204, RED);
    tft.drawLine(304, 203, 304, 200, RED);
    tft.drawLine(305, 200, 307, 200, RED);
    tft.drawLine(308, 200, 308, 208, RED);
    tft.drawLine(309, 209, 319, 219, RED);
    tft.drawLine(281, 219, 283, 219, RED);
    tft.drawLine(316, 219, 318, 219, RED);
    tft.drawRect(284, 219, 32, 21, RED);
    tft.drawRect(295, 225, 10, 15, RED);
  void clearmessage() {
    tft.fillRect(12, 213, 226, 16, BLACK); // black out the inside of the message box
  void drawbatt() {
    if (battv < battold) { // if the voltage goes down, erase the inside of the battery
    battfill = map(battv, 300, 415, 2, 18); // map the battery voltage 300 is the low, 415 is the high
    battfill = constrain(battfill, 2, 18); // constrains batt display limits
    if (battfill > 7) { // if the battfill value is between 8 and 18, fill with green
      tft.fillRect(298, 2, battfill, 6, GREEN);
    else { // if the battfill value is below 8, fill with red
      tft.fillRect(298, 2, battfill, 6, RED);
    battold = battv; // this helps determine if redrawing the battfill area is necessary
  // Only used for identifier is this case. if your not using comment out save some space....
  // Copy string from flash to serial port
  // Source string MUST be inside a PSTR() declaration!
  void progmemPrint(const char *str) {
    char c;
    while (c = pgm_read_byte(str++)) Serial.print(c);
  // Same as above, with trailing newline
  void progmemPrintln(const char *str) {
    progmemPrint(str);
    Serial.println();
  void setRotation(uint8_t rotation);
SafetyComp
Thank you sooo much. The support here is awesome!
I finally got this up and running and with your help now have a project that I can see the light at the end of the tunnel.
They say "A picture is worth a thousand words."
Thanks again!
cool!
ricejl2
Post by ricejl2 »
I am using the adafruit 2.8" tft the mounts directly to the Uno. With it and your sketch I don't have to include this section of code correct?
#define YM 7 // can be a digital pin-----uno=9 mega=23 7 for shield
#define XP 6 // can be a digital pin-----uno=8 mega=22 6 for shield
Correct. The shield has an on-board touch chip, so you don't need to use the analog inputs.
