er, see above. Can't do that either.
>>TeeOnArdu will not work above 1.0.5
>>Teensyduino will not recognise before 1.0.6.
I am new to this, but I got numerous errors with Teensyduino on 1.0.5
My guess is that the Teensyduino library/code/something has moved on in syntax/format/style/whatever & is no longer compatible with 1.0.5
Can you point me to a Teensyduino that works for you?
Thanks for you help.
It seems that this is mostly a arduino compatibility thing & not directly an adafruit issue.
Anyway - the box HELLA is a great looking thing - It went together as per plan & I can programme it as it is supposed to. It would be great to be able to post here a workable solution set of library versions to recreate the midi use-case for any who want to play with it.
TeeOnArdu - not showing up
Re: TeeOnArdu - not showing up
Teensyduino will recognize below IDE 1.0.6 if you use an earlier version of it. Adafruit should point this out in the instructions.
Version 1.21 works: https://www.pjrc.com/teensy/td_121/teensyduino.exe (I had to do some exploration to come up with that path ;)
- nanren888
Many thanks. I saw your other reply. Very thorough. Will attempt to verify/reproduce your solution.
Thanks - yes it did take some looking to find the earlier versions.
- SamWheating
I've just tried this (IDE 1.0.5, Teensyduino 1.21, Untztrument, Trellis and TeeOnArdu libraries installed) and The USB-type menu option is still greyed out. Can you elaborate on what setup worked for you in the end?acullen wrote:Teensyduino will recognize below IDE 1.0.6 if you use an earlier version of it. Adafruit should point this out in the instructions.
