Bluefruit LE SPI Friend - Cant Factory Reset
- xerlium1987
Re: Bluefruit LE SPI Friend - Cant Factory Reset
Hi i just bought a new Bluefruit LE Shield, it is currently stacked in between the Arduino Uno Rev 3 and Adafruit FONA 808 - Mini Cellular GSM + GPS Breakout (In the middle). After i powered up the cards, if the Bluefruit LE Shield completely have no lights blinking at all, does it mean that my Bluefruit LE Shield has already damage or spoiled?
- Bluefruit LE Shield completely have no lights blinking. Isit Spoiled?
- Bluefruit LE Shield no blink.png (379.13 KiB) Viewed 717 times
- chelnik
as per the fellow who said you have to change to the software serial it is a matter of uncommenting
the following,,,
// USE THIS FOR THE FRIEND >>>>>>>>>>>
SoftwareSerial bluefruitSS = SoftwareSerial(BLUEFRUIT_SWUART_TXD_PIN, BLUEFRUIT_SWUART_RXD_PIN);
Adafruit_BluefruitLE_UART ble(bluefruitSS, BLUEFRUIT_UART_MODE_PIN,
BLUEFRUIT_UART_CTS_PIN, BLUEFRUIT_UART_RTS_PIN);
then commenting out the serial
this is all in the code at the top of the ino file
(Yes indeed a bit frustrating adafruit did not provide the info for the friend.) Regards Marc
the following,,,
- distractivity
Thank you, chelnik, your suggestion solved my problem!
