I was able to get the 'blink' sketch to work as stated in the project but when I try to verify the animated eyes code I get this error:
Arduino: 1.6.5 (Windows 7), TD: 1.25, Board: "Teensy 3.2 / 3.1, Serial, 72 MHz optimized, US English"
uncannyEyes.ino:453:17: warning: extra tokens at end of #ifdef directive [enabled by default]
uncannyEyes.ino: In function 'void setup()':
uncannyEyes:99: error: 'INITR_144GREENTAB' was not declared in this scope
uncannyEyes.ino: In function 'void frame(uint16_t)':
uncannyEyes.ino:320:67: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
uncannyEyes.ino:397:33: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
Any ideas?
uncanny eyes with Teensy 3.1
Re: uncanny eyes with Teensy 3.1
From the errors, it looks like you have some garbage characters in the sketch.
Post the exact code you're using (between CODE tags please) and we'll see what we can find.
- rogerc2288
Thanks for the help. When trying to verify, the forth line is highlighted and I get the error message. I downloaded the code into the Arduino IDE (1.6.5) and ran it without making any changes.
// For some reason display #1 must init first, else jumbled. WTH?
for(uint8_t e=NUM_EYES; e--; ) { // Work last-to-first
#ifdef _ADAFRUIT_ST7735H_ // TFT
eye[e].display.initR(INITR_144GREENTAB);
#else // OLED
eye[e].display.begin();
#endif
if(eye[e].blink.pin >= 0) pinMode(eye[e].blink.pin, INPUT_PULLUP);
#ifdef BLINK_PIN
pinMode(BLINK_PIN, INPUT_PULLUP);
#endif
Last edited by adafruit_support_mike on Wed Sep 30, 2015 10:32 pm, edited 1 time in total.
Reason: added CODE tags to preserve formatting
Try downloading a new copy of the ST7735 library. It looks like you have a version that's missing a hardware identifier.
https://github.com/adafruit/Adafruit-ST7735-Library
- _chris_
I had the same issue. Turns out, like mike said, the libraries were at fault. I had originally installed the libraries with the teensyduino package (I'm on OS X), but that caused the compile error. I went in and removed those libraries (buried in /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries) and installed the ones from the arduino library manager and everything is up and running ...
- rogerc2288
Many thanks to both of you: Mike and Chris!! It looks like removing those libraries and re-installing them will do it. I don't have the hardware all completed yet but at least the code is verifying and uploading to the teensy.
- pmd2000
Thanks to all at Adafruit for writing the uncanny eyes. Just got my TFT's in and teensy up and running. Without the forum for a quick ref and fix woulda taken me a long time.
I plan to scare lots and lots of folks with these!!!
Thanks again Lady Ada and your fab staff!
- rbbtebo
Got mine working last night with OLED. These, along with my firewalker shoes are fantastic. Love Adafruit!
- Bwholt
Hi. I've downloaded the latest ST7735 TFT library from the Github repository but I still get compile errors as shown below. I've deleted all other references/locations of the ST7735 library files from my system and only the latest version exists in my Arduino library. I've restarted the IDE multiple times, checked the libraries and all looks as it should be but I can't get past this nebulous compile error. Please help!
Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI (1.0.x format)
Using library Adafruit GFX Library in folder: C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-GFX
Using library Adafruit ST7735 Library in folder: C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=125 -DARDUINO=10605 -DF_CPU=72000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-GFX -IC:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735 C:\Users\BWHOLT~1.NET\AppData\Local\Temp\build6694199665238610382.tmp\uncannyEyes.cpp -o C:\Users\BWHOLT~1.NET\AppData\Local\Temp\build6694199665238610382.tmp\uncannyEyes.cpp.o
uncannyEyes.ino:460:17: warning: extra tokens at end of #ifdef directive [enabled by default]
In file included from uncannyEyes.ino:21:0:
C:\Users\BWHOLT~1.NET\AppData\Local\Temp\build6694199665238610382.tmp\dragonEye.h:15637:66: warning: narrowing conversion of '-1' from 'int' to 'const uint16_t {aka const short unsigned int}' inside { } [-Wnarrowing]
0X007F, 0X007F, 0X007F, 0X007F, 0X007F, 0X007F, 0X007F, 0X007F };
In file included from uncannyEyes.ino:28:0:
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:175:12: error: 'RwReg' does not name a type
volatile RwReg *dataport, *clkport, *csport, *rsport;
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:176:16: error: redeclaration of 'uint32_t Adafruit_ST7735::_cs'
uint32_t _cs, _rs, _sid, _sclk,
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:169:12: note: previous declaration 'uint8_t Adafruit_ST7735::_cs'
uint8_t _cs, _rs, _rst, _sid, _sclk,
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:176:21: error: redeclaration of 'uint32_t Adafruit_ST7735::_rs'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:169:17: note: previous declaration 'uint8_t Adafruit_ST7735::_rs'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:176:27: error: redeclaration of 'uint32_t Adafruit_ST7735::_sid'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:169:28: note: previous declaration 'uint8_t Adafruit_ST7735::_sid'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:176:34: error: redeclaration of 'uint32_t Adafruit_ST7735::_sclk'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:169:34: note: previous declaration 'uint8_t Adafruit_ST7735::_sclk'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:177:24: error: redeclaration of 'uint32_t Adafruit_ST7735::datapinmask'
datapinmask, clkpinmask, cspinmask, rspinmask,
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:170:12: note: previous declaration 'uint8_t Adafruit_ST7735::datapinmask'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:177:36: error: redeclaration of 'uint32_t Adafruit_ST7735::clkpinmask'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:170:25: note: previous declaration 'uint8_t Adafruit_ST7735::clkpinmask'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:177:47: error: redeclaration of 'uint32_t Adafruit_ST7735::cspinmask'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:170:37: note: previous declaration 'uint8_t Adafruit_ST7735::cspinmask'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:177:58: error: redeclaration of 'uint32_t Adafruit_ST7735::rspinmask'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:170:48: note: previous declaration 'uint8_t Adafruit_ST7735::rspinmask'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:178:21: error: redeclaration of 'uint32_t Adafruit_ST7735::colstart'
colstart, rowstart; // some displays need this changed
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:171:12: note: previous declaration 'uint8_t Adafruit_ST7735::colstart'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:178:23: error: redeclaration of 'uint32_t Adafruit_ST7735::rowstart'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:171:22: note: previous declaration 'uint8_t Adafruit_ST7735::rowstart'
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:179:13: error: redeclaration of 'int32_t Adafruit_ST7735::_rst'
int32_t _rst; // Must use signed type since a -1 sentinel is assigned.
C:\Users\BLAH BLAH BLAH\Documents\Arduino\libraries\Adafruit-ST7735/Adafruit_ST7735.h:169:22: note: previous declaration 'uint8_t Adafruit_ST7735::_rst'
uncannyEyes.ino:327:67: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
uncannyEyes.ino:404:33: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
Error compiling.
Last edited by adafruit_support_mike on Wed Oct 14, 2015 1:07 am, edited 1 time in total.
It looks like there's some kind of unexpected character at the end of line 460 in the 'uncannyEyes.ino' sketch.
Post the exact sketch you have (between CODE tags please) and we'll see what we can find.
- Bwholt
I can post the sketch when I return home from work tonight; however, It was a completely unaltered version that was downloaded directly from your website with the exception of changing the display type from OLED to TFT.
Wayne
Wayne
- Bwholt
Mike,
Here's the code I'm trying to compile. Other things I have tried are using a fresh version of the code as downloaded from your website (which is what's below), I've deleted ANY references to the ST7735 library on my system and reinstalled a fresh version of the library from the Github site.
My Arduino IDE is configured for Teensy 3.1/3.2 board, Serial USB type, 72 Mhz optimized and programmer is Arduino as ISP.
Wayne
Wayne
// Uncanny eyes for PJRC Teensy 3.1 with Adafruit 1.5" OLED (product #1431)
// or 1.44" TFT LCD (#2088). This uses Teensy-3.1-specific features and
// WILL NOT work on normal Arduino or other boards! Use 72 MHz (Optimized)
// board speed -- OLED does not work at 96 MHz.
// Adafruit invests time and resources providing this open source code,
// please support Adafruit and open-source hardware by purchasing products
// from Adafruit!
// Written by Phil Burgess / Paint Your Dragon for Adafruit Industries.
// MIT license. SPI FIFO insight from Paul Stoffregen's ILI9341_t3 library.
// Inspired by David Boccabella's (Marcwolf) hybrid servo/OLED eye concept.
#include <SPI.h>
#include <Adafruit_GFX.h> // Core graphics lib for Adafruit displays
// Enable ONE of these #includes -- HUGE graphics tables for various eyes:
#include "defaultEye.h" // Standard human-ish hazel eye
//#include "noScleraEye.h" // Large iris, no sclera
//#include "dragonEye.h" // Slit pupil fiery dragon/demon eye
//#include "goatEye.h" // Horizontal pupil /Krampus eye
// Then tweak settings below, e.g. change IRIS_MIN/MAX or disable TRACKING.
// DISPLAY HARDWARE CONFIG -------------------------------------------------
//#include <Adafruit_SSD1351.h> // OLED display library -OR-
#include <Adafruit_ST7735.h> // TFT display library (enable one only)
typedef Adafruit_ST7735 displayType; // Using TFT display(s)
#else
typedef Adafruit_SSD1351 displayType; // Using OLED display(s)
#endif
#define DISPLAY_DC 7 // Data/command pin for BOTH displays
#define DISPLAY_RESET 8 // Reset pin for BOTH displays
#define SELECT_L_PIN 9 // LEFT eye chip select pin
#define SELECT_R_PIN 10 // RIGHT eye chip select pin
// INPUT CONFIG (for eye motion -- enable or comment out as needed) --------
//#define JOYSTICK_X_PIN A0 // Analog pin for eye horiz pos (else auto)
//#define JOYSTICK_Y_PIN A1 // Analog pin for eye vert position (")
//#define JOYSTICK_X_FLIP // If set, reverse stick X axis
//#define JOYSTICK_Y_FLIP // If set, reverse stick Y axis
#define TRACKING // If enabled, eyelid tracks pupil
#define IRIS_PIN A2 // Photocell or potentiometer (else auto iris)
//#define IRIS_PIN_FLIP // If set, reverse reading from dial/photocell
#define IRIS_SMOOTH // If enabled, filter input from IRIS_PIN
#define IRIS_MIN 120 // Clip lower analogRead() range from IRIS_PIN
#define IRIS_MAX 720 // Clip upper "
#define WINK_L_PIN 0 // Pin for LEFT eye wink button
#define BLINK_PIN 1 // Pin for blink button (BOTH eyes)
#define WINK_R_PIN 2 // Pin for RIGHT eye wink button
#define AUTOBLINK // If enabled, eyes blink autonomously
// Probably don't need to edit any config below this line, -----------------
// unless building a single-eye project (pendant, etc.), in which case one
// of the two elements in the eye[] array further down can be commented out.
// Eye blinks are a tiny 3-state machine. Per-eye allows winks + blinks.
#define NOBLINK 0 // Not currently engaged in a blink
#define ENBLINK 1 // Eyelid is currently closing
#define DEBLINK 2 // Eyelid is currently opening
typedef struct {
int8_t pin; // Optional button here for indiv. wink
uint8_t state; // NOBLINK/ENBLINK/DEBLINK
int32_t duration; // Duration of blink state (micros)
uint32_t startTime; // Time (micros) of last state change
} eyeBlink;
struct {
displayType display; // OLED/TFT object
uint8_t cs; // Chip select pin
eyeBlink blink; // Current blink state
} eye[] = { // OK to comment out one of these for single-eye display:
displayType(SELECT_L_PIN,DISPLAY_DC,0),SELECT_L_PIN,{WINK_L_PIN,NOBLINK},
displayType(SELECT_R_PIN,DISPLAY_DC,0),SELECT_R_PIN,{WINK_R_PIN,NOBLINK},
#define NUM_EYES (sizeof(eye) / sizeof(eye[0]))
// INITIALIZATION -- runs once at startup ----------------------------------
void setup(void) {
uint8_t e;
Serial.begin(115200);
randomSeed(analogRead(A3)); // Seed random() from floating analog input
// Both displays share a common reset line; 0 is passed to display
// constructor (so no reset in begin()) -- must reset manually here:
pinMode(DISPLAY_RESET, OUTPUT);
digitalWrite(DISPLAY_RESET, LOW); delay(1);
digitalWrite(DISPLAY_RESET, HIGH); delay(50);
for(e=0; e<NUM_EYES; e++) { // Deselect all
pinMode(eye[e].cs, OUTPUT);
digitalWrite(eye[e].cs, HIGH);
digitalWrite(eye[e].cs, LOW); // Select one eye for init
#else // OLED
#endif
digitalWrite(eye[e].cs, HIGH); // Deselect
#ifdef BLINK_PIN
#endif
// One of the displays is configured to mirror on the X axis. Simplifies
// eyelid handling in the drawEye() function -- no need for distinct
// L-to-R or R-to-L inner loops. Just the X coordinate of the iris is
// then reversed when drawing this eye, so they move the same. Magic!
digitalWrite(eye[0].cs , LOW);
digitalWrite(DISPLAY_DC, LOW);
SPI.transfer(ST7735_MADCTL);
digitalWrite(DISPLAY_DC, HIGH);
SPI.transfer(0x88); // MADCTL_MY | MADCTL_BGR
digitalWrite(eye[0].cs , HIGH);
#else // OLED
eye[0].display.writeCommand(SSD1351_CMD_SETREMAP);
eye[0].display.writeData(0x76);
#endif
// EYE-RENDERING FUNCTION --------------------------------------------------
SPISettings settings(24000000, MSBFIRST, SPI_MODE3); // Teensy 3.1 max SPI
void drawEye( // Renders one eye. Inputs must be pre-clipped & valid.
uint8_t e, // Eye array index; 0 or 1 for left/right
uint32_t iScale, // Scale factor for iris
uint8_t scleraX, // First pixel X offset into sclera image
uint8_t scleraY, // First pixel Y offset into sclera image
uint8_t uT, // Upper eyelid threshold value
uint8_t lT) { // Lower eyelid threshold value
uint8_t screenX, screenY, scleraXsave;
int16_t irisX, irisY;
uint16_t p, a;
uint32_t d;
// Set up raw pixel dump to entire screen. Although such writes can wrap
// around automatically from end of rect back to beginning, the region is
// reset on each frame here in case of an SPI glitch.
SPI.beginTransaction(settings);
eye[e].display.setAddrWindow(0, 0, 127, 127);
#else // OLED
eye[e].display.writeCommand(SSD1351_CMD_SETROW); // Y range
eye[e].display.writeData(0); eye[e].display.writeData(SCREEN_HEIGHT - 1);
eye[e].display.writeCommand(SSD1351_CMD_SETCOLUMN); // X range
eye[e].display.writeData(0); eye[e].display.writeData(SCREEN_WIDTH - 1);
eye[e].display.writeCommand(SSD1351_CMD_WRITERAM); // Begin write
#endif
digitalWrite(eye[e].cs, LOW); // Chip select
digitalWrite(DISPLAY_DC, HIGH); // Data mode
// Now just issue raw 16-bit values for every pixel...
scleraXsave = scleraX; // Save initial X value to reset on each line
irisY = scleraY - (SCLERA_HEIGHT - IRIS_HEIGHT) / 2;
for(screenY=0; screenY<SCREEN_HEIGHT; screenY++, scleraY++, irisY++) {
scleraX = scleraXsave;
irisX = scleraXsave - (SCLERA_WIDTH - IRIS_WIDTH) / 2;
for(screenX=0; screenX<SCREEN_WIDTH; screenX++, scleraX++, irisX++) {
if((lower[screenY][screenX] <= lT) ||
(upper[screenY][screenX] <= uT)) { // Covered by eyelid
p = 0;
} else if((irisY < 0) || (irisY >= IRIS_HEIGHT) ||
(irisX < 0) || (irisX >= IRIS_WIDTH)) { // In sclera
p = sclera[scleraY][scleraX];
} else { // Maybe iris...
p = polar[irisY][irisX]; // Polar angle/dist
d = (iScale * (p & 0x7F)) / 128; // Distance (Y)
if(d < IRIS_MAP_HEIGHT) { // Within iris area
a = (IRIS_MAP_WIDTH * (p >> 7)) / 512; // Angle (X)
p = iris[d][a]; // Pixel = iris
} else { // Not in iris
p = sclera[scleraY][scleraX]; // Pixel = sclera
// SPI FIFO technique from Paul Stoffregen's ILI9341_t3 library:
while(KINETISK_SPI0.SR & 0xC000); // Wait for space in FIFO
KINETISK_SPI0.PUSHR = p | SPI_PUSHR_CTAS(1) | SPI_PUSHR_CONT;
KINETISK_SPI0.SR |= SPI_SR_TCF; // Clear transfer flag
while((KINETISK_SPI0.SR & 0xF000) || // Wait for SPI FIFO to drain
!(KINETISK_SPI0.SR & SPI_SR_TCF)); // Wait for last bit out
SPI.endTransaction();
// EYE ANIMATION -----------------------------------------------------------
const uint8_t ease[] = { // Ease in/out curve for eye movements 3*t^2-2*t^3
0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 2, 2, 2, 3, // T
3, 3, 4, 4, 4, 5, 5, 6, 6, 7, 7, 8, 9, 9, 10, 10, // h
11, 12, 12, 13, 14, 15, 15, 16, 17, 18, 18, 19, 20, 21, 22, 23, // x
24, 25, 26, 27, 27, 28, 29, 30, 31, 33, 34, 35, 36, 37, 38, 39, // 2
40, 41, 42, 44, 45, 46, 47, 48, 50, 51, 52, 53, 54, 56, 57, 58, // A
60, 61, 62, 63, 65, 66, 67, 69, 70, 72, 73, 74, 76, 77, 78, 80, // l
81, 83, 84, 85, 87, 88, 90, 91, 93, 94, 96, 97, 98,100,101,103, // e
104,106,107,109,110,112,113,115,116,118,119,121,122,124,125,127, // c
128,130,131,133,134,136,137,139,140,142,143,145,146,148,149,151, // J
152,154,155,157,158,159,161,162,164,165,167,168,170,171,172,174, // a
175,177,178,179,181,182,183,185,186,188,189,190,192,193,194,195, // c
197,198,199,201,202,203,204,205,207,208,209,210,211,213,214,215, // o
216,217,218,219,220,221,222,224,225,226,227,228,228,229,230,231, // b
232,233,234,235,236,237,237,238,239,240,240,241,242,243,243,244, // s
245,245,246,246,247,248,248,249,249,250,250,251,251,251,252,252, // o
252,253,253,253,254,254,254,254,254,255,255,255,255,255,255,255 }; // n
#ifdef AUTOBLINK
uint32_t timeOfLastBlink = 0L, timeToNextBlink = 0L;
#endif
void frame( // Process motion for a single frame of left or right eye
uint16_t iScale) { // Iris scale (0-1023) passed in
static uint32_t frames = 0; // Used in frame rate calculation
static uint8_t eyeIndex = 0; // eye[] array counter
int16_t eyeX, eyeY;
uint32_t t = micros(); // Time at start of function
Serial.println((++frames * 1000) / millis()); // Show frame rate
if(++eyeIndex >= NUM_EYES) eyeIndex = 0; // Cycle through eyes, 1 per call
// X/Y movement
#if defined(JOYSTICK_X_PIN) && (JOYSTICK_X_PIN >= 0) && \
defined(JOYSTICK_Y_PIN) && (JOYSTICK_Y_PIN >= 0)
// Read X/Y from joystick, constrain to circle
int16_t dx, dy;
int32_t d;
eyeX = analogRead(JOYSTICK_X_PIN); // Raw (unclipped) X/Y reading
eyeY = analogRead(JOYSTICK_Y_PIN);
#ifdef JOYSTICK_X_FLIP
eyeX = 1023 - eyeX;
#endif
#ifdef JOYSTICK_Y_FLIP
eyeY = 1023 - eyeY;
#endif
dx = (eyeX * 2) - 1023; // A/D exact center is at 511.5. Scale coords
dy = (eyeY * 2) - 1023; // X2 so range is -1023 to +1023 w/center at 0.
if((d = (dx * dx + dy * dy)) > (1023 * 1023)) { // Outside circle
d = (int32_t)sqrt((float)d); // Distance from center
eyeX = ((dx * 1023 / d) + 1023) / 2; // Clip to circle edge,
eyeY = ((dy * 1023 / d) + 1023) / 2; // scale back to 0-1023
#else // Autonomous X/Y eye motion
// Periodically initiates motion to a new random point, random speed,
// holds there for random period until next motion.
static boolean eyeInMotion = false;
static int16_t eyeOldX=512, eyeOldY=512, eyeNewX=512, eyeNewY=512;
static uint32_t eyeMoveStartTime = 0L;
static int32_t eyeMoveDuration = 0L;
int32_t dt = t - eyeMoveStartTime; // uS elapsed since last eye event
if(eyeInMotion) { // Currently moving?
if(dt >= eyeMoveDuration) { // Time up? Destination reached.
eyeInMotion = false; // Stop moving
eyeMoveDuration = random(3000000); // 0-3 sec stop
eyeMoveStartTime = t; // Save initial time of stop
eyeX = eyeOldX = eyeNewX; // Save position
eyeY = eyeOldY = eyeNewY;
} else { // Move time's not yet fully elapsed -- interpolate position
int16_t e = ease[255 * dt / eyeMoveDuration] + 1; // Ease curve
eyeX = eyeOldX + (((eyeNewX - eyeOldX) * e) / 256); // Interp X
eyeY = eyeOldY + (((eyeNewY - eyeOldY) * e) / 256); // and Y
} else { // Eye stopped
eyeX = eyeOldX;
eyeY = eyeOldY;
if(dt > eyeMoveDuration) { // Time up? Begin new move.
int16_t dx, dy;
uint32_t d;
do { // Pick new dest in circle
eyeNewX = random(1024);
eyeNewY = random(1024);
dx = (eyeNewX * 2) - 1023;
dy = (eyeNewY * 2) - 1023;
} while((d = (dx * dx + dy * dy)) > (1023 * 1023)); // Keep trying
eyeMoveDuration = random(72000, 144000); // ~1/14 - ~1/7 sec
eyeMoveStartTime = t; // Save initial time of move
eyeInMotion = true; // Start move on next frame
#endif // JOYSTICK_X_PIN etc.
// Blinking
#ifdef AUTOBLINK
// Similar to the autonomous eye movement above -- blink start times
// and durations are random (within ranges).
if((t - timeOfLastBlink) >= timeToNextBlink) { // Start new blink?
timeOfLastBlink = t;
uint32_t blinkDuration = random(36000, 72000); // ~1/28 - ~1/14 sec
// Set up durations for both eyes (if not already winking)
for(uint8_t e=0; e<NUM_EYES; e++) {
if(eye[e].blink.state == NOBLINK) {
eye[e].blink.state = ENBLINK;
eye[e].blink.startTime = t;
eye[e].blink.duration = blinkDuration;
timeToNextBlink = blinkDuration * 3 + random(4000000);
#endif
if(eye[eyeIndex].blink.state) { // Eye currently blinking?
// Check if current blink state time has elapsed
if((t - eye[eyeIndex].blink.startTime) >= eye[eyeIndex].blink.duration) {
// Yes -- increment blink state, unless...
if((eye[eyeIndex].blink.state == ENBLINK) && // Enblinking and...
((digitalRead(BLINK_PIN) == LOW) || // blink or wink held...
digitalRead(eye[eyeIndex].blink.pin) == LOW)) {
// Don't advance state yet -- eye is held closed instead
} else { // No buttons, or other state...
if(++eye[eyeIndex].blink.state > DEBLINK) { // Deblinking finished?
eye[eyeIndex].blink.state = NOBLINK; // No longer blinking
} else { // Advancing from ENBLINK to DEBLINK mode
eye[eyeIndex].blink.duration *= 2; // DEBLINK is 1/2 ENBLINK speed
eye[eyeIndex].blink.startTime = t;
} else { // Not currently blinking...check buttons!
if(digitalRead(BLINK_PIN) == LOW) {
// Manually-initiated blinks have random durations like auto-blink
} else if(digitalRead(eye[eyeIndex].blink.pin) == LOW) { // Wink!
eye[eyeIndex].blink.state = ENBLINK;
eye[eyeIndex].blink.duration = random(45000, 90000);
// Process motion, blinking and iris scale into renderable values
// Iris scaling: remap from 0-1023 input to iris map height pixel units
iScale = ((IRIS_MAP_HEIGHT + 1) * 1024) /
(1024 - (iScale * (IRIS_MAP_HEIGHT - 1) / IRIS_MAP_HEIGHT));
// Scale eye X/Y positions (0-1023) to pixel units used by drawEye()
eyeX = map(eyeX, 0, 1023, 0, SCLERA_WIDTH - 128);
eyeY = map(eyeY, 0, 1023, 0, SCLERA_HEIGHT - 128);
if(eyeIndex == 1) eyeX = (SCLERA_WIDTH - 128) - eyeX; // Mirrored display
// Horizontal position is offset so that eyes are very slightly crossed
// to appear fixated (converged) at a conversational distance. Number
// here was extracted from my posterior and not mathematically based.
// I suppose one could get all clever with a range sensor, but for now...
eyeX += 4;
if(eyeX > (SCLERA_WIDTH - 128)) eyeX = (SCLERA_WIDTH - 128);
// Eyelids are rendered using a brightness threshold image. This same
// map can be used to simplify another problem: making the upper eyelid
// track the pupil (eyes tend to open only as much as needed -- e.g. look
// down and the upper eyelid drops). Just sample a point in the upper
// lid map slightly above the pupil to determine the rendering threshold.
static uint8_t uThreshold = 128;
uint8_t lThreshold, n;
#ifdef TRACKING
int16_t sampleX = SCLERA_WIDTH / 2 - (eyeX / 2), // Reduce X influence
sampleY = SCLERA_HEIGHT / 2 - (eyeY + IRIS_HEIGHT / 4);
// Eyelid is slightly asymmetrical, so two readings are taken, averaged
if(sampleY < 0) n = 0;
else n = (upper[sampleY][sampleX] +
upper[sampleY][SCREEN_WIDTH - 1 - sampleX]) / 2;
uThreshold = (uThreshold * 3 + n) / 4; // Filter/soften motion
// Lower eyelid doesn't track the same way, but seems to be pulled upward
// by tension from the upper lid.
lThreshold = 254 - uThreshold;
#else // No tracking -- eyelids full open unless blink modifies them
uThreshold = lThreshold = 0;
#endif
// The upper/lower thresholds are then scaled relative to the current
// blink position so that blinks work together with pupil tracking.
uint32_t s = (t - eye[eyeIndex].blink.startTime);
if(s >= eye[eyeIndex].blink.duration) s = 255; // At or past blink end
else s = 255 * s / eye[eyeIndex].blink.duration; // Mid-blink
s = (eye[eyeIndex].blink.state == DEBLINK) ? 1 + s : 256 - s;
n = (uThreshold * s + 254 * (257 - s)) / 256;
lThreshold = (lThreshold * s + 254 * (257 - s)) / 256;
} else {
n = uThreshold;
// Pass all the derived values to the eye-rendering function:
drawEye(eyeIndex, iScale, eyeX, eyeY, n, lThreshold);
// AUTONOMOUS IRIS SCALING (if no photocell or dial) -----------------------
#if !defined(IRIS_PIN) || (IRIS_PIN < 0)
// Autonomous iris motion uses a fractal behavior to similate both the major
// reaction of the eye plus the continuous smaller adjustments that occur.
uint16_t oldIris = (IRIS_MIN + IRIS_MAX) / 2, newIris;
void split( // Subdivides motion path into two sub-paths w/randimization
int16_t startValue, // Iris scale value (IRIS_MIN to IRIS_MAX) at start
int16_t endValue, // Iris scale value at end
uint32_t startTime, // micros() at start
int32_t duration, // Start-to-end time, in microseconds
int16_t range) { // Allowable scale value variance when subdividing
if(range >= 8) { // Limit subdvision count, because recursion
range /= 2; // Split range & time in half for subdivision,
duration /= 2; // then pick random center point within range:
int16_t midValue = (startValue + endValue - range) / 2 + random(range);
uint32_t midTime = startTime + duration;
split(startValue, midValue, startTime, duration, range); // First half
split(midValue , endValue, midTime , duration, range); // Second half
} else { // No more subdivisons, do iris motion...
int32_t dt; // Time (micros) since start of motion
int16_t v; // Interim value
while((dt = (micros() - startTime)) < duration) {
v = startValue + (((endValue - startValue) * dt) / duration);
if(v < IRIS_MIN) v = IRIS_MIN; // Clip just in case
else if(v > IRIS_MAX) v = IRIS_MAX;
frame(v); // Draw frame w/interim iris scale value
#endif // !IRIS_PIN
// MAIN LOOP -- runs continuously after setup() ----------------------------
#ifdef IRIS_PIN && (IRIS_PIN >= 0) // Interactive iris
uint16_t v = analogRead(IRIS_PIN); // Raw dial/photocell reading
#ifdef IRIS_PIN_FLIP
v = 1023 - v;
#endif
v = map(v, 0, 1023, IRIS_MIN, IRIS_MAX); // Scale to iris range
#ifdef IRIS_SMOOTH // Filter input (gradual motion)
static uint16_t irisValue = (IRIS_MIN + IRIS_MAX) / 2;
irisValue = ((irisValue * 15) + v) / 16;
frame(irisValue);
#else // Unfiltered (immediate motion)
frame(v);
#endif // IRIS_SMOOTH
#else // Autonomous iris scaling -- invoke recursive function
newIris = random(IRIS_MIN, IRIS_MAX);
split(oldIris, newIris, micros(), 10000000L, IRIS_MAX - IRIS_MIN);
oldIris = newIris;
#endif // IRIS_PIN
- Bwholt
ADDENDUM TO PREVIOUS POST
I have installed all necessary files on another PC and the code still will not compile. I made absolutely sure that I had the latest Adafruit_GFX, Adafruit_ST7735 and SPI libraries. I have no duplicate libraries. I am running the latest version of the Arduino IDE 1.6.5 r5 on both machines. The code will compile with the OLED device engaged in the code. It will not compile with the TFT device engaged in the code. When I say "engaged", I mean I comment or uncomment the appropriate library references on code lines 28 & 29.
I don't know what else I can do here. Two different machines running different versions of Windows (i.e. 7 & 8). Fresh libraries. Unmodified code from the Adafruit website (actually the Github site). There's gotta be something hokey in the as-distributed code or the ST7735 library!
Wayne
Wayne
Okay, I'm able to duplicate the error.
It looks like the ST7735 library uses a data structure that's defined for the Arduino but not for the Teensy. I'll need to check with the developers and see what they suggest.
- pburgess
Please download the latest ST7735 from Github. Install this manually in Documents/Arduino/Libraries, not through the IDE's library manager (it hasn't picked up this changed release yet).
Seems I was building against a version of that library that wasn't yet committed to Github. That should be fixed now, please let me know. Very sorry for the nuisance.
