--GPS MT3339 pa6h Low speed moving
lios
Post by lios »
hello i have some MT3339 pa6h gps modules
i have place in a small car robot that moviing with low speed!!!
and my problem is that if i stand still for some sec and then start moving the gps start to uptate the nmea coordinates if the car move more than 5 meter
in the BANNED list
https://www.adafruit.com/datashe...
is a command that set Speed threshold
but i have confirm that is 0 m/S
if anyone have any ides please tellme
thanks
Re: --GPS MT3339 pa6h Low speed moving
GPS resolution is only accurate to within a couple of meters. When moving at slow speeds, the speed calculation is not going to be accurate. This is a limitation of GPS technology.
lios
Post by lios »
thanks, because i want to confirm that gps is enter to a geofence, with slow speed
i made a trick
i get the current point and after 8 sec i get one more point and i check the distance of this 2 points and if lower than 1 meter i triger the reset of gps
then the gps when starts gets the current point with accuracy
Sounds like a goods approach. Is it working well for you?
lios
Post by lios »
Yes but I still testing to find the best settings for time and distance to triger the reset
Some times when GPS start send me 2-3 meters fallse for 1sec and then return to corect position
