When I try ti compile the code for the BME 280, I get this compile error:
Arduino: 1.6.7 (Mac OS X), Board: "Arduino/Genuino Uno"
Warning: platform.txt from core 'Arduino AVR Boards' contains deprecated recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.macros.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}", automatically converted to recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.macros.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{preprocessed_file_path}". Consider upgrading this core.
/Users/"ME"/Documents/Arduino/libraries/Adafruit_BME280_Library/examples/bme280test/bme280test.ino:20:29: fatal error: Adafruit_Sensor.h: No such file or directory
#include <Adafruit_Sensor.h>
compilation terminated.
exit status 1
Error compiling.
I installed the BME280 library using the Arduino IDE "Manage Libraries" option.
/r
Alex
BME280 Compile Error
- Franklin97355
Re: BME280 Compile Error
You need to install the Adafruit_sensor library also.
- AJJ1
Franklin97335,
That worked. Thank you.
