Looking for any tips here, but I bought a an Adafruit Ultimate GPS breakout and I am unable to observe any output from the GPS via serial. I have tested two different cables and same behaviour is observed. To check for output, I am doing the following:
cat /dev/ttyUSB0
I'm certain of the device and one of the cables has been used with another project so I am certain it works.
In terms of checking resistance, should each of the four pinouts be completely isolated? Other ideas for debugging?
No serial output for AdaFruit Ultimate GPS breakout
- baude
- Franklin97355
Re: No serial output for AdaFruit Ultimate GPS breakout
How are you connecting the breakout to your computer? What are you using on the computer to receive the data?
- baude
I am using the USB to TTL serial cable -> https://www.adafruit.com/products/954
- baude
Any ideas? On the advice of a colleague, I checked the voltage in and it was in fact 5V.
- adafruit_support_mike
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
- baude
hey thanks,
do you want a picture with or without the usb>serial actually connected?
With the connections please. We need to see how you have it hooked up to see if there are any problems there.
- baude
So it looks like the "ring"--where you solder--of the TX connection is not present. I am not sure if it was that way or was damaged by me. But that clearly explains the issue. Advice on what to do?
- Franklin97355
You could try scraping off some of the solder mask and solder a wire to that or trace back to the nearest point you can access. Post a picture so we can see if there are other options.
