Tv-B-Gone with atmega328 @ 8mhz
dpeters
Post by dpeters »
Hey, I've been trying for a while to run the tv-b-gone sketch with an arduino pro mini (atmega328 @ 8mhz). Adafruit has a modified version that works with the flora, and since both boards run at 8mhz I figured the code would be the same. The IR led is hooked up exactly as in the flora tv-b-gone guide. Does anyone know the software changes I need to make for this to work?
dpeters
Re: Tv-B-Gone with atmega328 @ 8mhz
Post by dpeters »
Bump. Still haven't been able to figure this out.
ghpk
Post by ghpk »
it would work fine.
Before I got hold of ATTINY85, I made a couple of based on Arduino Pro-mini itself.
I used on 328 and 168, both work excellent.
Best would be to use instructions from "http://www.righto.com/2010/11/improved- ... -gone.html"
Return to “TV-B-Gone Kit”
