TV B Gone not working
by anthonyjohnson on Mon Oct 03, 2016 12:40 pm
I recently assembled my TV-B-Gone kit, and once I tried the green light test, it flashed around two or three times and didn't flash again. I have checked soldering several times, I have tried new batteries, I also tried the whole kit and none of the LEDS work when trying with a camera no light is showing
Please let me know what details are needed
http://imgur.com/a/NFYCb
anthonyjohnson
Re: TV B Gone not working
by adafruit_support_rick on Tue Oct 04, 2016 12:01 pm
Do you have a multimeter? Check to see if you have 3V between pins 4 and 6 on the chip:
Also, make sure you have the correct transistor installed at Q5
by anthonyjohnson on Tue Oct 04, 2016 1:25 pm
Hi I am waiting for my multi meter to arrive, I will be able to check this when it arrives and let you know.
For the Q5 I installed the one that was on its own not the 4 that were together is that correct ?
anthonyjohnson
by adafruit_support_rick on Tue Oct 04, 2016 1:41 pm
Yes that is correct. Q5 is the different one.
by AudreyA on Sat Dec 10, 2016 6:04 pm
My problem is the voltage between the 4th and 6th pin is 1V. What does this mean and how do I fix it? Thanks:)!
AudreyA
by adafruit_support_rick on Sun Dec 11, 2016 10:14 am
You may have a short circuit.
Please post clear, detailed pictures of both sides of the TV B Gone board.
by AudreyA on Sun Jan 01, 2017 2:35 am
adafruit_support_rick wrote:You may have a short circuit.
My photos are in the next post. Thank you for your help!
AudreyA
by AudreyA on Sun Jan 01, 2017 9:18 pm
This is the back of my tv b gone
This is the front of my tv b gone.
AudreyA
by AudreyA on Sun Jan 01, 2017 9:21 pm
Please scroll down on both pictures to see the complete picture. Thanks for the help!
AudreyA
by AudreyA on Sun Jan 01, 2017 9:23 pm
Also, I checked and the transistor pins aren't soldered together. Thanks!
AudreyA
by adafruit_support_rick on Mon Jan 02, 2017 12:39 pm
The solder on your ground (black) wire isn't very good. Re-flow that one, and make sure the solder flows completely over the pad.
by AudreyA on Tue Jan 03, 2017 8:51 pm
Okay. Thanks!
AudreyA
