IR LEDS NOT WORKING
IR LEDS NOT WORKING
by Samuel95950 on Fri Jan 13, 2017 9:08 pm
Hello!! I ran out the first test and the green led worked well. But when I finished the soldering the entire tv-b-gone the ir leds didn't work. I tried switching the one leds position (the one on the right) in case i put the positive one in the wrong socket but it didn't work. I attach some pictures so you can see the assembly. Sorry for my bad english. Thank you!
Samuel95950
Re: IR LEDS NOT WORKING
by adafruit_support_bill on Sat Jan 14, 2017 8:03 am
Check the markings on the transistors. Q1 through Q4 should all be the same. Q5 should have different markings.
by Samuel95950 on Sat Jan 14, 2017 9:48 am
I have just checked it and i put them in the correct place. Could there be any other thing wrong?
Samuel95950
by adafruit_support_bill on Sat Jan 14, 2017 11:01 am
What are you using to see if the LEDs are working? As I understand it, some of the more recent iPhone cameras have IR filters, so they won't show up.
by Samuel95950 on Sat Jan 14, 2017 11:13 am
I have tried with an iPad 2 and Also with an other phone. I tried pointing with that phone's camera to a common tv remote and i could see the lights
Samuel95950
by adafruit_support_bill on Sat Jan 14, 2017 12:40 pm
If the green light is flashing, then the processor is running. Not much else to the circuit besides the output transistors and leds. Other than the one reversed LED, the assembly looks OK. Maybe a bad transistor?
If you contact support@adafruit.com with a link to this thread we can send a replacement kit.
by Samuel95950 on Sun Jan 15, 2017 6:51 pm
Samuel95950
