Tv b gone wont work
Tv b gone wont work
by Mish12mish12 on Mon Jul 31, 2017 7:36 pm
Hi i soldered every thing on my tv b gone and it wouldn't work the green led doesn't flash nor does the ir what should i do ?
Mish12mish12
Re: Tv b gone wont work
by Mish12mish12 on Mon Jul 31, 2017 10:00 pm
i have checked everything with a multimeter for shorts and also put in new batteries and that did not help
Mish12mish12
by franklin97355 on Tue Aug 01, 2017 2:37 am
Could you post large (less than 1meg), clear, detailed pictures of both sides of your board showing any soldering you have done and the connections to it?
franklin97355
by Mish12mish12 on Wed Aug 02, 2017 4:19 pm
Although the solder joints are really bad looking i tested everything for continuity with my multimeter and there was no shorts and everything was fine
Mish12mish12
by Mish12mish12 on Sat Aug 05, 2017 2:27 am
ill fix all the solder joints when my new soldering iron arrives because my old one had a broken tip and was pretty cheap from the first place ill be sure to update on if it works or not
Thank you
Mish12mish12
by Mish12mish12 on Tue Aug 08, 2017 7:50 pm
Hi I fixed all the solder joints made sure again with the multimeter that nothing is shorting and it still won't work should I just return it to where I got it from ?
Mish12mish12
by imhavoc on Thu Oct 05, 2017 10:37 pm
I ordered two TV-B-Gone kits from Amazon.com
One works. One does not. Testing showed that one of the microprocessors is defective.
Is there a way to get a replacement microprocessors for this kit?
imhavoc
by franklin97355 on Thu Oct 05, 2017 11:01 pm
Contact the Amazon seller and ask them.
franklin97355
by imhavoc on Fri Oct 06, 2017 12:47 pm
Amazon will replace the complete item. I will have to return the complete, assembled and tested unit. I would MUCH rather just purchase a replacement microcontroller if possible.... Oh, wait....
I requested a refund from Amazon, then placed a new order for a new, kit. AFTER the new kit arrives, I can return the defective microprocessor with the unassembled kit and I'll be in business!
Thank you!
imhavoc
