List of used codes
peteromega
List of used codes
Post by peteromega »
I need a help with identify used codes in firmware v1.2.
In version 1.0 or 1.1 the codes are named in the source code, for example SHARP:
// Code 003 -- Sharp
const struct powercode sharpCode PROGMEM =
In version 1.2 are codes unlabelled, for example:
const struct IrCode code_na004Code PROGMEM =
The codes have a different structure and cannot be easily identified.
Is there any way to identify them? Or some list used codes?
I need to adjust their order.
Thank very much
adafruit_support_mike
Re: List of used codes
What device are you using?
peteromega
I built my device according to pcb v1.2
https://raw.githubusercontent.com/adafr ... ne3sch.png
That would be a TV-B-Gone
The v1.2 codes have the same numbers as the v1.1 ones. Code 000 in the v1.1 firmware becomes code_na000Code in the v1.2 firmware.
peteromega
Are you sure?
Codes with the same numbers as the v1.1 and v1.2 have different freq_to_timerval
For example
v1.1 Code 000 - freq_to_timerval(37470)
v1.2Code 000 - freq_to_timerval(38400)
v1.1 Code 001 - freq_to_timerval(55600)
v1.2 Code 001 - freq_to_timerval(57143)
Return to “TV-B-Gone Kit”
