Trouble compiling firmware
by zimmerleut on Sat Apr 14, 2012 1:49 pm
Hi, I tried to compile firmware 1.2 on my system (set up according to instructions here: http://www.nongnu.org/avr-libc/user-manual/install_tools.html, with gcc 4.6.3 (also tested: 4.7.0), avr-libc 1.8.0, binutils 2.22).
Running make, I get this error message:
avr-gcc (GCC) 4.6.3
Compiling: main.c
avr-gcc -c -mmcu=attiny85 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -DF_CPU=8000000 -Wa,-adhlns=main.lst  -std=gnu99 -DEU_CODES -DNA_CODES main.c -o main.o
main.c:82:21: error: variable 'NApowerCodes' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
main.c:83:21: error: variable 'EUpowerCodes' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
main.c: In function 'main':
main.c:271:7: warning: passing argument 1 of 'putnum_uh' makes integer from pointer without a cast [enabled by default]
util.h:11:6: note: expected 'uint16_t' but argument is of type 'const char *'
make: *** [main.o] Error 1
What configuration did you use to compile the firmware, and do you have hints how to fix this?
Thanks,
Jonas
zimmerleut
Re: Trouble compiling firmware
by zimmerleut on Fri Apr 20, 2012 4:44 am
So .. Can anyone confirm a set up under which the firmware will compile?
zimmerleut
by adafruit_support_bill on Fri Apr 20, 2012 6:07 am
I don't know the configuration under which it was originally built, but from the error messages, it appears that your environment is applying more strict rules with respect to const variables in read-only memeory. You could figure out what compiler option is controlling that, or just add the const attribute to the places it is complaining about.
by kscharf on Sat Dec 29, 2012 2:16 pm
Just saw this, same problem I'm having.
OK it now works.
I am running Linux Mint version 13 with KDE.
I had installed the avr toolset from Atmel, and had compile issues.
I unzipped a fresh copy of the TVBGone firmware and installed the version(s) of avr-tools from the Mint package repository with GCC version 4.6.2.
I then ran the makefile and the previous problems were gone.
If you are trying to compile on a 'buntu based Linux distro just get the latest versions of the avr tools from the repository with synatpic.
If you are on windows, try the 2010 version of Winavr. Ohterwise you are stuck with using either the toolset from arduino, or from Atmel. Those are the ones I have had issues with (but on Linux).
kscharf
by Aleks on Tue Jan 15, 2013 3:56 pm
zimmerleut wrote:Hi, I tried to compile firmware 1.2 on my system (set up according to instructions here: http://www.nongnu.org/avr-libc/user-manual/install_tools.html, with gcc 4.6.3 (also tested: 4.7.0), avr-libc 1.8.0, binutils 2.22).
Thanks,
Jonas
This is cos' of the new way that GCC-4.6 (and later) interpret the PROGMEM variables, it's documented here : http://gcc.gnu.org/gcc-4.6/changes.html#avr
I made a small patch that fixes this *bug* on gcc-4.7.2, binutils-2.23 :
firmware_v1.2_gcc-4.7.2.patch :
Regards,
Aleks
diff -Naur fw_v1.2-old/main.c fw_v1.2-new/main.c
--- fw_v1.2-old/main.c   2009-08-16 21:48:34.000000000 +0200
+++ fw_v1.2-new/main.c   2013-01-15 20:45:52.479525370 +0100
@@ -79,8 +79,8 @@
-extern const PGM_P *NApowerCodes[] PROGMEM;
-extern const PGM_P *EUpowerCodes[] PROGMEM;
+extern const PGM_P * const NApowerCodes[] PROGMEM;
+extern const PGM_P * const EUpowerCodes[] PROGMEM;
 extern const uint8_t num_NAcodes, num_EUcodes;
diff -Naur fw_v1.2-old/WORLDcodes.c fw_v1.2-new/WORLDcodes.c
--- fw_v1.2-old/WORLDcodes.c   2009-08-16 21:50:24.000000000 +0200
+++ fw_v1.2-new/WORLDcodes.c   2013-01-15 20:47:04.919538679 +0100
@@ -8226,7 +8226,7 @@
-const struct IrCode *NApowerCodes[] PROGMEM = {
+const struct IrCode * const NApowerCodes[] PROGMEM = {
 #ifdef NA_CODES
    &code_na000Code,
    &code_na001Code,
@@ -8370,7 +8370,7 @@
 #endif
-const struct IrCode *EUpowerCodes[] PROGMEM = {
+const struct IrCode * const EUpowerCodes[] PROGMEM = {
 #ifdef EU_CODES
         &code_eu000Code,
    &code_eu001Code,
Regards,
Aleks
Aleks
by davidbradway on Thu Sep 26, 2013 5:01 pm
Aleks when I try your patch, I get:
FloraTVB2.ino:84:1: error: duplicate ‘const’
FloraTVB2.ino:85:1: error: duplicate ‘const’
It doesn't seem to like the two 'const' definitions on these lines I edited:
Thanks in advance.
davidbradway
by LightningStalker on Thu Dec 26, 2013 7:13 am
Trying to cut and paste the above code was a major pain in my ass.
Here is a new patch done the right way, in binary form.
If you want to do something right, you have to do it yourself.
TVBGone.tar.bz2
(560 Bytes) Downloaded 175 times
TVBGone.zip
(541 Bytes) Downloaded 276 times
LightningStalker
by i.gavriljev on Tue Jan 07, 2014 9:29 am
Hello.
I'm trying to write a firmware to Attiny with my arduino uno. So I added libraries : "caitsith_firmwarev12' and 'include' from avr-libc-1.8.0. and added them to the sketch.
 #include <alloca.h>
#include <assert.h>
#include <ctype.h>
#include <errno.h>
#include <inttypes.h>
#include <math.h>
#include <setjmp.h>
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <main.h>
#include <util.h>
I receive an error :
main.c:338: error: 'for' loop initial declaration used outside C99 mode
I'm a very beginner in programming. Can you help me with step-by-step what to do, where to download, where to put, what to write etc?
i.gavriljev
