TV B Gone not making it by first test
by mgalimbe on Wed Mar 13, 2013 2:53 pm
hello,
I've gone as far as inserting the microprocessor and testing by inserting 2aa batteries and checking that the green led light flashes, well it doesn't... chip is in right (socket was soldered in place using the outline on the board)triangle is on the side with the indentation on the socket, led was soldered with longer pin in the + terminal and i know the batteries are good.
I also pushed the button just in case i had an older version.
any ideas on whats going on. all my solders look good....
Mike
mgalimbe
Re: TV B Gone not making it by first test
by adafruit_support_bill on Wed Mar 13, 2013 4:51 pm
If you post photos, front & back we'll check over your build.
by mgalimbe on Wed Mar 13, 2013 7:11 pm
I'm not able to post images from my computer to this forum....
mgalimbe
by adafruit_support_bill on Wed Mar 13, 2013 7:18 pm
Try re-sizing them to about 800x600.
by mgalimbe on Thu Mar 14, 2013 5:19 am
ok attachments below
Thank you
bottom view tv b gone
Top View TV B Gone
mgalimbe
by adafruit_support_bill on Thu Mar 14, 2013 7:00 am
It could be the lighting, but the solder joints on the chip socket look a bit "frosty" like a cold joint. Re-touch those with a hot iron so they are smooth and shiny. If it still doesn't work, contact [email protected] with a link to this thread and ask for a replacement TV-B-Gone processor.
by mgalimbe on Wed Mar 27, 2013 5:27 pm
hello,
just updating this post per the request of support. I was shipped a new chip and installed it but it still wont work. I'm wondering if it may be the board.
mgalimbe
by adafruit_support_bill on Thu Mar 28, 2013 6:42 am
Can you post photos of your re-worked solder joints?
by mgalimbe on Thu Mar 28, 2013 7:28 am
I will. I'm at work for the next 48 hours so ill send it to you Saturday. Thank you for your help. Mike
mgalimbe
by Adam_tlllls on Sat Aug 24, 2013 12:01 am
You installed the oscillator where the PNP transistor should go. Install it right next to the micro-controller. Do that, and it should work.
Adam_tlllls
