HELP!
by montag on Sat Nov 03, 2007 5:22 am
Max collector current for a Fairchild 2222A is 1A. Did the batteries get hot too?
montag
by scifipirate on Sat Nov 03, 2007 7:33 am
no just the transistors
scifipirate
by scifipirate on Sat Nov 03, 2007 8:32 pm
So is this thing just a lost cause now, or does anyone have anything else I could try?
scifipirate
by adafruit on Sat Nov 03, 2007 10:45 pm
you could return it for analysis to adafruit and this one time we'll send a replacement kit...but it could theoretically happen again so its up to you.
by scifipirate on Sat Nov 03, 2007 10:53 pm
weeeeellll let me think about that
scifipirate
by montag on Sun Nov 04, 2007 5:27 pm
Looked into what I did on my beater perfboard one.
Jump pin 4 to 5 to test the green LED. LED should stay lit while jumped. you did this.
if above works:
Jump pin 7 to pin 5 green led should light when button is pressed. Off when buton is relaesed.
Jump pin 8 to pin 6. This should make the IR leds light, verify with dig camera. Do not leave connected any longer than needed too much voltage. If this does not work your transistors or IR LEDs are bad.
If they do light something is wrong in AVR or Xtal.
Use a resistor to jump with but to lazy to figure out proper voltage drop. Might add that tomorrow. Use a 100 ohm resistor to protect the transistors and LED from to much voltage and current.
Test Power with meter.
black to ground:
Red to:
+ on IR LEDs = battery voltage ~3V
Pin 6 was about .5V Hard to read as it is a pulse.
transistor side of 47 ohm about 2 volts
remove AVR and test all grounds with ohm meter:
Battery ground to:
Emitters of transistors = 0 ohms
Center of crystal resanator = 0 ohms
ground side of switch =0
ground side of green LED =0
Use the schematic to test all ground points. ( Not an issue with yours it worked once so should be ok Just trying to make a test tutorial in general.
Thats about all you can test with out real test equipment.
When I did this and left the jumper in from pin 8 to pin 6, the transistors started to get hot. Likely your AVR is shorted out. The output of the 6 pin is way lower than the + rail that you are using to jump with.
My suggestion is get another AVR from adafruit and try it out. I think you will find it works. I got my transistors pretty hot and it still works after cooling off and reinserting the AVR.
Might want to make some kind of case for the board or coating it with something so it canot be shorted out or esd damaged again.
Edit to make more clear in red sorry I write like banned. Also see Mitches Post below!!!
Hope that helps to fix the :evil: thing.
montag
by maltman23 on Sun Nov 04, 2007 5:57 pm
We are relying on the IR signal output from the microcontroller (pin 6) to be pulsing at a small duty cycle. When current from this output is applied to the 47 ohm base resistors to the transistors, the transistors are full on, and their is a huge amount of current flowing through both the IR emitters and the transistors (more than either can handle (though I haven't actually calculated how much). So, if somehow your microcontroller got into a funky state where pin 6 remained high, then that could have burned out some or all of the transistors, and/or some or all of the IR emitters. But the microcontroller should still be OK (if the transistors' bases all shorted to ground then there would be too much current being drawn from the micro's pin 6, but these chips are incredibly robust, in my experience).
In any case, if you short out pin 6 to pin 8 for the test that montag suggested (a good test), please be sure to do it quickly to avoid burning out any of the transistors or IR emitters (i.e., get your camera ready before shorting the pins).
Mitch.
maltman23
by scifipirate on Sun Nov 04, 2007 7:52 pm
cool cool cool, thanks for all ur help, I'm gonna go try this stuff now :o
scifipirate
by scifipirate on Sun Nov 04, 2007 11:36 pm
4 and 5 aren't giving me the green now and the springs on the batteries are getting really hot
7 to 5 i get nothin
8 to 6 nothin
this device is crazy
scifipirate
by scifipirate on Sun Nov 04, 2007 11:38 pm
dear god I put the AVR back in and the green LED is going through it's cycle :?: :!: :?: :?: :?: :?: :!: :?: :?: :!: :!: :!: :shock:
lemme see if the IRs are working
scifipirate
by scifipirate on Sun Nov 04, 2007 11:41 pm
hahahaha it turns TVs off now!
scifipirate
by montag on Mon Nov 05, 2007 2:28 am
Just a guess.
AVR was backwards? :wink: If that was the case Mitch is not kidding those are tough little ICs.
montag
by scifipirate on Mon Nov 05, 2007 10:29 am
montag wrote:Just a guess.
nahh
scifipirate
by maltman23 on Mon Nov 05, 2007 7:51 pm
I'm not sure what was wrong. But I'm glad you got it working. Now, go out there and turn off TVs!
Mitch.
maltman23
by scifipirate on Tue Nov 06, 2007 12:01 am
yeah it'll go off and I'll wiggle the thing and it'll come back on. It's cool.
scifipirate
