having trouble
having trouble
by scottiegfftv on Fri Nov 15, 2013 12:45 am
I put my tv be gone together with out testing it (a bad idea, I now know) as soon as I plug the batteries in it heats up and the ir leds stay on no matter what, but the green one doesn't. I did take my time to put things in the right place and solder it and nothing looks out of place is there a way to test anything without taking it apart and starting over?
scottiegfftv
Re: having trouble
by adafruit_support_bill on Fri Nov 15, 2013 7:41 am
What parts are getting hot?
Check the labels on the transistors. Q5 should be different from Q1-Q4.
A clearer shot of the back of the board would be helpful. Try near a window or even outside for better light.
Re: having trouble
by scottiegfftv on Fri Nov 15, 2013 11:05 am
the transistors leds and micro controller get warm to the touch
Q1-4 have a 2222a part number-- Q5 has a 2907a number
scottiegfftv
Re: having trouble
by adafruit_support_bill on Fri Nov 15, 2013 11:16 am
Warm is OK. The IR leds draw a lot of current. If you press the button, do you see any interruption in the output of the IR LEDs?
Re: having trouble
by scottiegfftv on Fri Nov 15, 2013 11:19 am
Warm is OK.
that's what i figured
nope
scottiegfftv
Re: having trouble
by adafruit_support_bill on Fri Nov 15, 2013 12:04 pm
Do the IR leds appear to be flickering at all, or are they just steady-on?
Re: having trouble
by scottiegfftv on Fri Nov 15, 2013 2:26 pm
steady on when I look at it with a camera
scottiegfftv
Re: having trouble
by adafruit_support_bill on Fri Nov 15, 2013 3:09 pm
Let's see if we can back up a bit. No need to de-solder everything. Start by removing R1 (that will effectively disconnect all the transistors and IR LEDs) and see if the green LED blinks as it should.
Re: having trouble
by scottiegfftv on Fri Nov 15, 2013 11:34 pm
got the R1 lifted--when I put the batteries in the green led now blinks constantly until I press the button as soon as it is released it starts blinking again
scottiegfftv
Re: having trouble
by scottiegfftv on Sat Nov 16, 2013 1:47 am
well I'm not sure what changed but I got to playing around and noticed the green led started blinking to pattern and finally stop after about a minute where as before it blinked nonstop until i pressed the button(the walk from my shop to my house is about 5 minutes so around that much blinking until i pulled the batteries the first time) so I reconnected the R1 and it turned off my tv, seems to be working fine now :?: thanks for the help I'll be stopping and doing the test on future kits
scottiegfftv
Re: having trouble
by adafruit_support_bill on Sat Nov 16, 2013 8:26 am
Glad you got that working. Still a bit of a mystery why it didn't before.
Re: having trouble
by scottiegfftv on Sat Nov 16, 2013 8:16 pm
it is odd, I had searched through before posting and thought maybe I had a short somewhere because that's the only other post I have seen that matches my first problem but I didn't notice anything touching or anything out of place. Then when the R1 was removed I knew the green led was supposed to blink for a little over a minute but when it kept blinking still didn't make since and then it just started working like nothing was wrong to start with :? now it works no problem and has turned every tv off I have pointed it at so far :D
scottiegfftv
