Can Someone To Capture A Few Codes For Me Please...
by oPossum on Sun Dec 23, 2007 7:09 pm
DIY IR capture that measures pulse time and carrier frequency.
Most DIY and many commercial solutions can not measure carrier frequency and often suffer from poor resolution and jitter.
oPossum
by maltman23 on Sun Dec 23, 2007 10:41 pm
Thanks for the IR Widget info. That looks really nice! I'm going to have to try building one.
Mitch.
maltman23
by nutt318 on Tue Feb 12, 2008 3:25 pm
oPossum wrote:DIY IR capture that measures pulse time and carrier frequency.
Is there a parts list for this project? I download the zip file and it had 4 schematics, I am confused on which one to use. Thanks.
nutt318
by caitsith2 on Tue Feb 12, 2008 6:10 pm
There may be 4 schematics, but there is only one with a matching board file. Use that one.
Your part list for this would be: (note, for this project, I ordered all the parts other than the demodulator through digikey, so I will be referencing those part numbers.)
Part                    x Quantity      - Digikey part number
QSE157                  x 1             - QSE157
1N4148 Diode            x 2             - 1N4148DICT-ND
1N5231 Zener Diode      x 1             - 1N5231BDICT-ND
10K resistor            x 1             - 10KQBK-ND (min quantity 5 from digikey)
2.2uF ceramic cap       x 1             - 399-4403-ND
Serial port connector   x 1             - 3209FE-ND
8 Pin DIP socket        x 1             - A24807-ND
PIC 12F629 or 12F675    x 1             - PIC12F675-I/P-ND
If you plan on having this PCB made, to run into the same pitfall I did. I didn't expect the holes for the QSE157 to be too small. Also, I couldn't find IR demodulators on digikey, which is why I don't have a part number to list. You can get them from mouser, or if your lucky like I was, anything remote controlled, that is dead, is likely to have one you can salvage.
caitsith2
by nutt318 on Tue Feb 12, 2008 6:17 pm
Thanks for the info caitsith2. I may play around with a breadboard first and see if I can get it working one of these days.
nutt318
