๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday October 14, 2019 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday October 11 will go out Tuesday October 15 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
High power IR leds - what are you using?
by Probedude on Sun Dec 23, 2007 3:23 am
I bought the V1.0 kit a while ago, just sourced the components to build up some more for friends.
About a year ago I was making some IR stuff and was using TSAL6100 LED's due to a particular website saying these were the most powerful (940nm).
Looking at the datasheet the TSAL6100's have a typical 1000mW output at 1.0A vs the 750mW for the IR333-A.
Anyone else have any even more powerful IR led's that you're using?
Probedude
by Probedude on Wed Dec 26, 2007 10:00 pm
I tried out my self built TVB-gone using one TSAL6100 LED and one of the IR333C/H0/L10 wide angle LED's. Turned off a neighbor's tv, through their window, from across the street standing on my lawn!
GREAT distance! Now I just need to add some more of these TSAL6100's in an array.
Probedude
by magician13134 on Thu Dec 27, 2007 7:21 pm
For those of you wanting to make homemade ones, www.vishay.com ships out samples of those LEDs (TSAL6100V), I asked for 15 and had them shipped the same day, no questions asked
magician13134
by bluestar on Thu Feb 07, 2008 4:17 pm
Be careful: The TSAL6100 is rated to have 1000mW/Sr, this does not mean it has an output power of 1000mW: mW/Sr means a radiometric power, a power per solid angle. In fact the TSAL6100 has an absolut optical power of 35mW @ 100mA as the TSAL5300, but concentrated to a half angle of 10ยฐ. So if you want to turn off TVs at a long distance, take that one, but if you want a wide spread beam, then choose the TSAL5300 with a half angle of 22ยฐ.
I don't have the specifications at hand for the IR333-A to compare them.
Achim
bluestar
by oPossum on Thu Feb 07, 2008 4:55 pm
IR333A 20 degrees
TSAL6100 20 degrees
TSAL5100 20 degrees
TSAL6200 35 degrees
TSAL7200 35 degrees
IR333C/H0/L10 40 degrees
TSAL5300 45 degrees
TSAL7300 45 degrees
TSAL6400 50 degrees
TSAL7400 50 degrees
TSAL7600 60 degrees
oPossum
