๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday October 14, 2019 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday October 11 will go out Tuesday October 15 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Custom TV-B-Gone (pics)
by Rotary Rasp on Fri Jan 25, 2008 4:54 am
Here is my design. I added two additional transistors for a total of six leds. The green led comes on when the red power switch is flipped and the red led is for the status.
I'm using 3 AAA's. I planned on using 3 AA's but it didn't fit with the case I wanted to use.
Hope you enjoy!
Rotary Rasp
by jasonx on Fri Jan 25, 2008 8:36 am
excellent work :D
did you use the kit components and add extra led's ect: with your own board ?
or did you build it from scratch
jasonx
impressive
by drewgolden on Fri Jan 25, 2008 2:12 pm
Very impressive build!
I should have switched to AAA as well, it would have fit much better.
Just got another kit and waiting for my tri-wing screwdriver to arrive.
Next case? Game Boy Color. AA Battery compartment already on case, and I plan on hacking a game cartridge so the IRs shine out the top. Should be very nice when done. Will use the existing power switch to bypass the battery and of course A will "fire" in real life :-)
drewgolden
by Rotary Rasp on Fri Jan 25, 2008 2:22 pm
jasonx wrote:excellent work :D
both, I bought a kit and built it. After seeing just how simple it was, I decided to build my own. I bought the parts from mouser. I ordered an extra micro controller when I bought my kit just in case.
Rotary Rasp
by Rotary Rasp on Sat Jan 26, 2008 8:47 pm
I changed the toggle switch with a slide switch and added to more leds. I also ordered some TSAL6100 leds. I'll install them when they arrive.
Rotary Rasp
by magician13134 on Sat Jan 26, 2008 11:09 pm
How did you get the little rings around all the LEDs?
magician13134
by jasonx on Sun Jan 27, 2008 8:01 am
magician13134 wrote:How did you get the little rings around all the LEDs?
I believe he used led panel mounting clips similar to these
http://cgi.ebay.co.uk/50-X-5mm-black-pl ... p1638.m122
jasonx
by Rotary Rasp on Sun Jan 27, 2008 11:35 am
thats correct
Rotary Rasp
by Rotary Rasp on Tue Feb 05, 2008 1:48 pm
update: I replaced the two middle leds with TSAL6100's for better long range.
Rotary Rasp
by jasonx on Tue Feb 05, 2008 2:33 pm
Rotary Rasp wrote:update: I replaced the two middle leds with TSAL6100's for better long range.
Are they any better ?
I have some but have not tested them yet
jasonx
by Rotary Rasp on Wed Feb 06, 2008 5:23 pm
I took it to circuit city last night. It worked from all the way across the store. I had no way of measuring the distance but it was pretty far. (at least 150 feet)
Rotary Rasp
by magician13134 on Tue Feb 12, 2008 5:28 pm
Is your pushbutton attached as an input or just directly to power?
magician13134
by Rotary Rasp on Fri Feb 15, 2008 4:23 am
It's attached to the reset pin on the IC.
Rotary Rasp
by magician13134 on Fri Feb 15, 2008 7:33 am
I see. Cool, thanks
magician13134
