๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday October 14, 2019 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday October 11 will go out Tuesday October 15 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Changing 47 ohm resistors to a lower value?
by Rotary Rasp on Mon Jan 28, 2008 5:49 pm
Since these IR leds run at 1.5 volts, what is the reason for using 3 AA's? (4.5 volts).
Couldn't the 47 ohm resistor be replaced with a lower value to increase brightness without raising the source voltage?
Rotary Rasp
by adafruit on Mon Jan 28, 2008 11:19 pm
because the Vce of the transistor is one of the major factors, thus a higher Vcc allows more breathing room...the base current into the transistor is already maxed out.
