My TV-B-Gone does not work :-(
by ProjectBuilder on Mon Feb 17, 2014 6:41 pm
I built my TV B-Gone but nothing is working. We followed the directions to a 'T' (except testing half-way through) but no results. We went back and measured the battery pack- it is OK. I have attached images of the front and back (with the one connection un-soldered). Please let me what to do next.
back of build
front side
ProjectBuilder
Re: My TV-B-Gone does not work :-(
by adafruit_support_rick on Tue Feb 18, 2014 11:53 am
Why is R1 unsoldered? It simply won't work without that resistor in the circuit.
by ProjectBuilder on Tue Feb 18, 2014 9:27 pm
We were testing the LED- an earlier post said if we de-soldered that joint then it would be as if we hadn't completed the build. But alas, no lights went on. I tested and the batteries are supplying more than enough voltage, but no lights. I also viewed this through my iPad camera and no lights.
And no, it did not work when that end of the resistor was soldered.
ProjectBuilder
by adafruit_support_rick on Wed Feb 19, 2014 10:59 am
Check that you have the PN2907 in Q5.
Also, you might want to re-do these solders - they look a little iffy in the picture:
