ok ...sorry im french so i try to make me understandable :P
i got the v1.2 tv b gone ...i follow the instruction FROM THIS PAGE :
https://learn.adafruit.com/tv-b-gone-kit/solder-it
then at the first test...the green led..it failed ! so i dont bother and keep goind..i tought maybe the led was broken but maybe the device will work anyways...no
it didnt...i complete all ..i think i dont solder that bad...i RESPECT POLARITY..far as i know !
finnaly it just doesnt work ...!
What is it ? why ? what can i do ?
first green led test : failed...i complete the solder and fa
- Hellvis
- Franklin97355
Re: first green led test : failed...i complete the solder an
Not sure what the problem could be but you should dress up your solder joints. The green arrows show good joints and the red are bad ones but there are also some marginal that could use some work. Take a look at this Soldering Guide for help.
- 2015-04-21_20h12_24.png (1.37 MiB) Viewed 1044 times
- Hellvis
ok so i remake some solder..now i got the blinking green led working and i see with a camera the 4 IR led working...
let see..cause i cant make my TV go off..
so i put batterie IN...the green led flash couple time then stop...
then i try the button...while point at my TV..make it flash 3 time again butTV dont go off !
what could it be ?
its setup for US tv and my TV is the cheapest BestBuy TV call INSIGNIA so maybe that explain it dont work ! i try at my gym there plenty of tv there i cmoe back with some news! cause i read all the info here on the site and it look like my device work ...so i will try some different model
what could it be ?
- hypersonic500
The tv-b-gone flashes 3 times to signal start then continues to flash. The codes can take awhile so maybe your tv is at the back of the list. try it again and wait for the 3 flashes a second time.
