Shrinked TV b gone
Get help and show off your TV-B-Gone kit!
lyczewskiand
Shrinked TV b gone
Post by lyczewskiand »
Hello and welcome.
I wonder if I could shrink this tv-b-gone v1.2 https://learn.adafruit.com/tv-b-gone-kit/parts-list
to make it as small as possible to fit inside keychain flashlight http://www.clickonway.com/wp-content/up ... hain-0.jpg
I would like to use SMD transistor.
only 2 IR LEDs driven by one transistor (what should i do with unconnected pins? connect them to ground?)
no indicator green LED (leave unconnected pin or connect to GND?)
Use internal uC oscillator which is quite accurate?
Regards
Re: Shrinked TV b gone
You should be able to shrink it considerably with just a 2-led output.. Leave the unused pins unconnected. Don't connect them to ground.
lyczewskiand
Maybe i will find way to disable those pins in source code ;)
Franklin97355
Post by Franklin97355 »
You don't need to do anything with the pins, just don't use them and make your board smaller.
lyczewskiand
Thanks a lot for your respond.
Now i need to collect all items and probably I will post my device here.
lyczewskiand
franklin97355 wrote: You don't need to do anything with the pins, just don't use them and make your board smaller.
Do you know how to change source code to use internal uC oscillator? Or it is only a matter of leaving fusebits to use internal clock oscillator because maybe (i don't know) program already has a "#define #define F_CPU 8000000UL" ?
lyczewskiand
Nice build! I don't think I've ever seen one quite that small.
lyczewskiand
I used this 3 led keychain
http://imgur.com/a/khotS
I designed a pcb to match with button placement.
relaxing
Post by relaxing »
lyczewskiand
Didn't know that someone would pay 200$ for that.
Thread is 3 years old :D
And i cannot post a comment that I've made one :D
Your build in featured on the blog: https://blog.adafruit.com/2015/09/04/fr ... -keychain/
lyczewskiand
adafruit_support_bill wrote:Your build in featured on the blog: https://blog.adafruit.com/2015/09/04/fr ... -keychain/
WOW. Thanks ;) Can i get some promo or free items for featured project :D ?
I posted it on Instructables. If you don't mind I'll post link here http://www.instructables.com/id/TV-B-Gone-Keychain/ It's featured :)
It's almost 5k views and over 100+ favourites
EDIT___________________
Look at my friends' project http://mdiy.pl/latarkowy-tv-b-gone-duzej-mocy/?lang=en
This is INSANE!!!
Return to “TV-B-Gone Kit”
