Burning the firmware using an arduino
by spacedementia87 on Mon Jul 11, 2016 4:19 am
I am trying to complete this project from scratch and I have successfully turned my arduino into an ISP programmer and have confirmed that it is working by uploading the LED blink sketch.
However now I need to upload the TV-B-Gone firmware. However it is a hex file and I cannot see a way of uploading that through the arduino IDE.
So i tried avrdude directly:
/usr/bin/avrdude -c arduino -p attiny85 -P /dev/ttyUSB0
and I get this:
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: Expected signature for ATtiny85 is 1E 93 0B
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
This seems like it is trying to talk to the arduino chip rather than the attiny. How do I fix this?
Also as a side note:
The v1.2 kit can be configured for either N.A. and EU zone which avoids this problem!
How do I configure it to use one or the other?
spacedementia87
Re: Burning the firmware using an arduino
by hiduino on Fri Aug 05, 2016 1:07 am
If you are using the ArduinoISP sketch, you need to specify the serial baud rate to 19200 on the avrdude option, -b 19200. Otherwise it will initiate the Uno bootloader instead.
hiduino
by claytoncamilleri100 on Sat Aug 06, 2016 5:22 am
Sorry to interrupt but I have the same problem I mean what about the other files to upload? Or I just need to install the hex file.
claytoncamilleri100
by spacedementia87 on Sun Aug 07, 2016 3:36 am
The way I did it was to use the Arduino IDE to upload a LED blink sketch to the ATtiny and made sure verbose was on.
I then looked at the command issued in the consequences window and used that to upload the hex file!
spacedementia87
by Geekineer on Fri Aug 12, 2016 3:56 pm
thanks for the question - super newbie here - trying to do the same thing - download hex file without IDE
into BLE 32u4. Can you explain - 'consequences window'. Is this a feature of the IDE? Will I see command line
like instrustions to do the hex load directly via avrdude/usb serial....?
Thanks,
Geekineer
