I have a project that needs a ton of I/O's and I don't want to deal with the nightmare of trying to synchronize several FPGA's to achieve the 100+ I/O's that I need.
Does anyone know of a reasonably priced FPGA that provides that many I/O pins?
Microcontroller with 100+ I/O's?
Re: Microcontroller with 100+ I/O's?
If you have a processor with i2c, you can get hundreds of GPIO pins using these:
https://www.adafruit.com/products/732
https://www.adafruit.com/products/2717
- Gouron73
Thank you sir, you have opened my eyes!
- audiogoose45
There's two options you can look for. Since your title says MCU and the OP says FPGA, I'll post both.
First there's the PIC32MZ from Microchip which is available in a 144-pin surface mount package: http://www.microchip.com/wwwproducts/en ... 1024EFE144
Word of warning: read the errata.
There's also the Spartan 6 from Xilinx, which is a FPGA that starts with 132 IO.
Both options likely have pre-built boards available if you look hard enough; I've seen a Sr. Design student last year use an evaluation board with a Spartan 6 on it to construct his final project.
Hope this helps.
Hope this helps.
