Help needed please Gemma buzzer on delay
by waterdude on Mon May 08, 2017 5:58 am
Hello everyone,
I am very new to this and can't yet code so I'm looking for a jumpstart :)
I have a gemma and neopixel ring and a buzzer that I want to build a circuit with.
What I want it to do is after a closed push switch is opened I want both the buzzer to chirp/buzz and the neopixel ring to show a rotating ring of red pixels after a certain time (60 seconds).
I want it to continue sounding the buzzer and rotating the neopixel ring until the switch is closed again.
Any help would be greatly appreciated :)
Thanks,
Stu.
waterdude
Re: Help needed please Gemma buzzer on delay
by adafruit_support_mike on Wed May 10, 2017 2:00 am
If you're just getting started with programmable hardware, take a look at our Learn Arduino series of tutorials:
https://learn.adafruit.com/adafruit-ard ... on-1-blink
That will help you get familiar with the pieces and process, and most of the information carries over to the Gemma without too much trouble.
Controlling things with a pushbutton starts around tutorial 6, and there are several examples that use control buttons after that. Start with the basics, just lighting an LED in reponse to the button input, then once you know that works the way you want, you can go on to controlling a buzzer and NeoPixel ring.
by waterdude on Wed May 10, 2017 7:55 am
Hey thanks Mike ;)
waterdude
by waterdude on Wed May 10, 2017 8:00 am
So this as far as i have got now. Something is not right though as it's not working
Screen Shot 2017-05-10 at 12.55.06.png (660.68 KiB) Viewed 336 times
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library
#ifdef __AVR__
#include <avr/power.h>
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1
#define PIN 1
//Switch will be connected to Pin-0 and Buzzer to Pin-2 of Gemma board
#define Switch 0
#define Buzz 2
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 12
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
void Start_Ring_Buz();// declaring prototype
//int delayval = 500; // delay for half a second
void setup()
// This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
// End of trinket special code
pinMode(Switch,INPUT);
pinMode(Buzz,OUTPUT);
//Switch=LOW;
//Buzz=LOW;
pixels.begin(); // This initializes the NeoPixel library.
void loop()
if (Switch)
Wait(5000);//wait for 53 seconds
Start_Ring_Buz();
else if (!Switch)
digitalWrite(Buzz,LOW);//Turn OFF Buzzer O/P Transistor
Stop_Ringing();
else ;
void Start_Ring_Buz(void)
digitalWrite(Buzz,HIGH);//Turn ON Buzzer O/P Transistor
// For a set of NeoPixels the first NeoPixel is 0, second is 1, all the way up to the count of pixels minus one.
for(int i=0;i<NUMPIXELS;i++)
// pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
pixels.setPixelColor(i, pixels.Color(255,0,0)); // Full bright Red color.
pixels.show(); // This sends the updated pixel color to the hardware.
delay(500); // Delay for a period of time (in milliseconds).
pixels.setPixelColor(i, pixels.Color(0,0,0)); // Fully Off All color..
void Stop_Ringing(void)
pixels.setPixelColor(12, pixels.Color(0,0,0)); // Moderately bright green color.
void Wait(unsigned int x)
for (int i=0; i<=x; i++)
delay(1000);
waterdude
by adafruit_support_mike on Thu May 11, 2017 1:34 am
What's the last thing that works as expected before the first thing that doesn't do what you expect?
by waterdude on Thu May 18, 2017 6:33 am
Woo Hoo!! I got it working!!! Now i am trying to work how to make the buzzer sort of chirp instead of buzz.
waterdude
by adafruit_support_mike on Thu May 18, 2017 11:40 pm
Glad to hear it's working for you.
A chirp usually involves an increasing frequency:
#define BUZZER  5
    pinMode( 5, OUTPUT );
    beep( 2000, 20 );
    beep( 5000, 30 );
    delay( 1000 );
//  parameter 'f' is the frequency in Hertz
//  parameter 't' is how long the beep should last in milliseconds
void beep ( uint32_t f, int t ) {
    uint32_t now = millis();
    int tau = 500000 / f;
    while (( millis() - now ) < t ) {
        digitalWrite( BUZZER, HIGH );
        delayMicroseconds( tau );
        digitalWrite( BUZZER, LOW );
by waterdude on Fri May 19, 2017 7:55 am
Whoop, chirp, beep! Cheers Mike.
waterdude
