Crickit Not Responding to Makecode
by sriggs on Sun Jun 10, 2018 1:08 am
I have two Crickit(s). When coding with motors, servos, one of the crickits do not seem to respond. I switched out 3 CPX with that particular Crickit, but it still does not respond to motors or servos. I've used the same power supply and CPX with the CricKit that does work, but the second crickit does not respond.
sriggs
Re: Crickit Not Responding to Makecode
by adafruit_support_mike on Sun Jun 10, 2018 11:12 pm
Post a photo showing the non-working one as you have it connected to the Circuit Playground and we'll see if we can spot anything. 800x600 images usually work best.
by sriggs on Mon Jun 11, 2018 6:58 am
Attached is a photo of the front and back.
Spark_Crickit - 1 (1).jpg (182.14 KiB) Viewed 226 times
Spark_Crickit - 1.jpg (186.96 KiB) Viewed 226 times
sriggs
by sriggs on Mon Jun 11, 2018 7:14 am
Attached are more photos.
CK_ - 1.jpg (197.95 KiB) Viewed 225 times
CrickitSide - 2.jpg (182.13 KiB) Viewed 225 times
CrickitSide - 1.jpg (187.4 KiB) Viewed 225 times
sriggs
by sriggs on Mon Jun 11, 2018 7:17 am
I hope the photos help. Attached is one last photo.
CK_photo - 1.jpg (204.69 KiB) Viewed 224 times
sriggs
by sriggs on Mon Jun 11, 2018 7:40 am
I forgot a picture with the Crickit powered up.
picture attached.
CK_Pwr - 1.jpg (174.57 KiB) Viewed 219 times
sriggs
by sriggs on Mon Jun 11, 2018 9:56 am
CricKit without CPX
CK_CPXx - 1.jpg (217.58 KiB) Viewed 206 times
sriggs
by adafruit_support_mike on Tue Jun 12, 2018 11:17 pm
It looks like everything is in order, thank you.
Does the Crickit respond to any other kind of signals? Can you get the GPIO pins to toggle up and down, for instance?
by sriggs on Wed Jun 13, 2018 6:36 am
No. It does not respond to the on board neopixel.
sriggs
by adafruit_support_mike on Wed Jun 13, 2018 11:21 pm
How have you connected power to the Crickit?
by sriggs on Thu Jun 14, 2018 8:01 am
Ok, Yes, I have connected power to the CricKit. Upon power up the lights come on the CricKit(power led, on board NeoPixel and the led by the seesaw usb port)Then all the lights go out except for the power led.
When the CPX is connected to the Cricket, Everything above happens, On the CPX all the NeoPixels come on including the CPX power led. The CPX NeoPixels go out but the CPX power led stays on.
So, I know the at least the Crickit on board NeoPixel works, but through software, the onboard NeoPixel does not respond, in addition to the motors' etc. does not respond through code (makecode).
sriggs
by adafruit_support_mike on Thu Jun 14, 2018 11:19 pm
It sounds like something is wrong with the Crickit's microcontroller. Send a note containing a link to this page and your order number to support@adafruit.com. The folks there will get you a replacement.
by sriggs on Fri Jun 15, 2018 6:36 am
Ok. Thank you.
sriggs
