Can't put NRF52 Feather board into Low Power mode
Re: Can't put NRF52 Feather board into Low Power mode
by hathach on Thu Jan 03, 2019 9:50 pm
@vegarwe thanks for detail posts. The beacon example is written before other power improvement, there is no surprise if some of it is outdated. For waitForEvent(), it is discussed in the github issue. It is advisable to do so when you have nothing to do. That will cause cpu to sleep until the next tick event of freeRTOS (1 ms) or other hw/ble event. To put cpu into sleep mode more than freeRTOS tick (1ms), you should use delay() which will sleep as long as the delay ( freeRTOS tickless mode).
Thanks for the avatar comment, I don't own an 40 series LC, but 100 series. Though the 40 look much nicer in the picture :)
hathach
by wb8wka on Sun Jan 06, 2019 3:52 am
Well for completeness here is the before and after, you can see the 1ms RTOS ticks in the later. This is the stock beacon code with 100ms beacon time, before and after the power mods. I'm using a uCurrent gold with 1mv per uA on the vertical scale. Any thoughts if things can get lower then this? I'll replace the regulator with some that has lower quiescent current.
200mv/20ms div, stock beacon code
200mv/20ms div, stock beacon code, avg current 976ua
200mv/20ms div, power saved beacon code
200mv/20ms div, power saved beacon code, avg current 343 ua
200mv/2ms div, power saved beacon code
wb8wka
by wb8wka on Sat Jan 12, 2019 6:02 am
hathach wrote: For waitForEvent(), it is discussed in the github issue. It is advisable to do so when you have nothing to do. That will cause cpu to sleep until the next tick event of freeRTOS (1 ms) or other hw/ble event. To put cpu into sleep mode more than freeRTOS tick (1ms), you should use delay() which will sleep as long as the delay ( freeRTOS tickless mode).
@hathach
Greetings. Per your suggestion I removed waitForEvent(); and instead inserted delay() using 10, 100 or 1000 values. The current goes from ~70ua up to around ~410ua and it appears to now be waking up every ~20usec. Instead of going to sleep it appears to be just going into a blocking mode. I'm using the beacon code as modified by vegarwe with my own board here (no USB serial) with the BLE beacon at 1000ms.
Was there a include or define I may have missed? I see the delay() being mentioned by others so I'm at a loss here at the point. Any suggestions welcome.
wb8wka
by wb8wka on Sat Jan 12, 2019 5:46 pm
@hathach
One other comment, I did check FreeRTOSConfig.h and
#define configUSE_TICKLESS_IDLE 1
is set to 1
wb8wka
by wb8wka on Sat Jan 12, 2019 5:59 pm
vegarwe wrote:To get even lower would require more investigation/trial-and-measure. There might be some pins that should/should-not be floating. Or maybe some other tuning can be done.
I added:
sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
to your example code and saved another ~10ua. I'm using the uCurrent gold with the averaging mode of a FLUKE 179
I'm hoping someone can chime in regarding waitForEvent() vs. delay() which is supposed to cut things even more... but I got sizable increase when I used delay instead of waitFor Event (see my post a few up).
wb8wka
by elangel on Wed Jan 16, 2019 5:25 am
some Measurements with my NRF52832 module:
void loop()
// some other stuff to do...
sd_power_mode_set(NRF_POWER_MODE_LOWPWR);
waitForEvent();
i get arround 7µA current consumption (BLE advertising). This is the same value when i used RedBear Lib.
Settings:
2 sec advertise interval
4HZ RTOS Tick Rate (cant get lower)
no LED, no Serial, No I2C, No GPIOs
with delay(1000) in loop() i get arround 2000µA!
suspendLoop() i get arround 1000µA!
elangel
by 42volts on Sat Jan 19, 2019 12:03 pm
hathach wrote:It is not a low power library, just a few helper functions such as systemOff(). It is more about software discipline, and how you write/design your code. We only test out and provide a how-to guideline that we think could save most of power. We are waiting for next revision board to test out the code and number. However, we are currently focusing on the nrf52840 board. So it may takes some time.
For your use case, if it is ok for nrf52 to reboot, re-advertise and re-connect then go with system off (deep sleep). Otherwise, you may only want it sleep and wake up to keep the connection active. Most of peripherals, if you don't use it at all, it default to power down along with the cpu. Though please check the Nordic specs to be sure.
So now that the 840s are in people's hands, can you give a hint about where you are with respect to power management on it? When following all the tricks to get the 832 into reasonably low power (I'm seeing that some have gotten to around 300 uA), I'm seeing at best 620 uA on the 840 when powered by BAT, 800 uA when powered by USB, and confusingly, all the way up at 1000 uA when powered by 3V. From what I understand, the 840 should be more power efficient that the 832, but I'm seeing it use double the power.
42volts
by hathach on Mon Jan 21, 2019 2:25 am
There is still lots of following up work to complete the features for both 840 and BLE5. The API will probably change quite a lot in up coming release. Focusing on low power require stable API and a few weeks of work fine-tuning. There already lots of hints and the power consumed is good enough already, please follow those in discussion, if you figure out anything please let us and other here know.
hathach
by wb8wka on Tue Jan 22, 2019 8:40 pm
hathach wrote:There already lots of hints and the power consumed is good enough already, please follow those in discussion, if you figure out anything please let us and other here know.
i do and others have. I'm quite thankful for that. I do wish however Adafruit would take a bigger role here and followup on some of the questions.... sometimes 'hints' aren't enough. This question I'd like a answer on relative to the hint you gave on delays and power savings I couldn't duplicate.
viewtopic.php?f=57&t=146147
Also the one last night if you know how to identify the bootloaders. I have two identical boards, with different bootloaders. The newest bootloader with identical code draws more then double the current compared to a board with a older bootloader. If I knew how to ID the bootloader it might be useful information for a github issue.
viewtopic.php?f=57&t=146537
Sorry to not be entirely positive , but I've gotten current consumption on the beacon code down to 5ua on my board but need to wrap up a few things to make sure I can duplicate things... as well as do something useful (I need to read a SHT31 sensor). I'm happy to make up a sheet in more detail. But your knowledge here is invaluable.
wb8wka
by hathach on Wed Jan 23, 2019 1:59 am
low power requires a few weeks of works to get it right, last time it took me ~ a month. Furthermore, the API is changing to adopt new SD features. If you find anything useful, please post it here, the next time I work on this I do re-read every post in this topic. I told all I know already, I couldn't provide anything more without actually working/analyzing it with the hw, which I don't have time now.
hathach
by wb8wka on Wed Jan 23, 2019 3:39 am
hathach wrote:low power requires a few weeks of works to get it right, last time it took me ~ a month. Furthermore, the API is changing to adopt new SD features. If you find anything useful, please post it here, the next time I work on this I do re-read every post in this topic. I told all I know already, I couldn't provide anything more without actually working/analyzing it with the hw, which I don't have time now.
Note I said 'Adafruit', and I said it because they are referring customers here for support. I know 10 months ago in this thread there was mention of a soon to be produced low power guide. Adafruit obviously needs to get you some help.
In the meantime, are you aware of a way to determine what version of bootloader is in a particular NRF52? I may have discovered a power bug in one of them.
wb8wka
by hathach on Wed Jan 23, 2019 4:28 am
Either you said 'Adafruit' or me is the same, arduino core for nrf52 is not the only repo we are working on. If you are not happy with the current code, just grab the sdk, there is a whole team of Nordic developer support that. I don't want to get into a fight, please be patient and excellent to others.
For bootloader version, put feather into OTA mode, the BLE DIS should give the correct bootloader version. If you are sure it is bootloader bug, please file an issue here https://github.com/adafruit/Adafruit_nRF52_Bootloader
hathach
by wb8wka on Wed Jan 23, 2019 4:44 am
hathach wrote:Either you said 'Adafruit' or me is the same, arduino core for nrf52 is not the only repo we are working on. If you are not happy with the current code, just grab the sdk, there is a whole team of Nordic developer support that. I don't want to get into a fight, please be patient and excellent to others.
I don't either, just making an observation. It's obvious your plate is full and I savor your responses. I went with the AdaFruit Feather because I wanted an arduino platform for what I am working on so going with the nordic SDK would be counterproductive and I wanted to avoid that. BTW, I've already mentioned once if I could pay you for support, I'm still interested so get with me if so.
That was the plan and if I can confirm what I am seeing, will do
Thank you for everything you do. I am planning on condensing all I've found so far with low power operations, I was just trying to close the loop on a few open issues. Most of the hints I've been able to flesh out, a few like the delay() hint you gave above I've not been able to. Give that a look if you could.
wb8wka
by 42volts on Wed Jan 30, 2019 10:33 am
wb8wka wrote:I went with the AdaFruit Feather because I wanted an arduino platform for what I am working on so going with the nordic SDK would be counterproductive and I wanted to avoid that.
Any particular reason why you think that going the nordic SDK route would be counterproductive as compared to arduino? My observation with arduino is that "the" big thing it really offers is that its easy to set up and get going. Some of the vendor SDK's can be quite challenging to figure out, and indeed, the nordic documentation, at first glance, makes the process seem quite daunting.
But it isn't. Not really.
1) Grab the GNU Arm Embedded Toolchain: https://developer.arm.com/open-source/g ... /downloads
2) Grab the Nordic SDK: https://www.nordicsemi.com/Software-and ... K/Download
3) Extract them both to somewhere that you find convenient.
4) Edit the file at SDKroot/components/toolchain/gcc/Makefile.posix so that GNU_INSTALL_ROOT is the path to the gnu toolchain bin/ directory
5) install nrfutil: "pip install nrfutil"
And that's it. You're ready to go. Go into the examples directory and pick one. For example, go into the directory;
examples/ble_peripheral/ble_app_blinky/pca10059/s140/armgcc/
Type "make".
It will create a directory _build/ in which you will find a file nrf52840_xxaa.hex
That's the one that you need to install.
Package it up and install as;
NON BLUETOOTH PROGRAM:
nrfutil pkg generate --hw-version 52 --sd-req 0x00 --application-version 1 --application ./nrf52840_xxaa.hex zip.zip
BLUETOOTH PROGRAM WITH SOFTDEVICE:
nrfutil pkg generate --hw-version 52 --sd-req 0x00 --sd-id 0xAE --softdevice {nRF_SDK_root}/components/softdevice/s140/hex/s140_nrf52_6.1.0_softdevice.hex --application-version 1 --application ./nrf52840_xxaa.hex zip.zip
BLUETOOTH PROGRAM WITHOUT SOFTDEVICE (softdevice already installed):
nrfutil pkg generate --hw-version 52 --sd-req 0xAE --application-version 1 --application ./nrf52840_xxaa.hex zip.zip
INSTALL TO nRF:
nrfutil dfu usb-serial -pkg zip.zip -p /dev/ttyACM0 -b 115200
Note: I'm actually using the pca10059 dongle now instead of the feather. I'm really aiming for lowest power consumption possible, and because of the way the feather is set up with the 3.3 volt linear and a few other components that aren't chosen to optimize power consumption, its never going to be super efficient. The pca10059 uses the nRF's much more efficient internal regulators. I'm told that the reason they maintain the 3.3v linear is because they need to provide a certain minimum of power to stackable peripherals, which makes sense, but its still too bad that they didn't provide a way to bypass it if lower power consumption is needed. I even looked into modifying the board, but unfortunately, they choose to tie VDD to VDDH directly within the MDBT50 (nRF52840 module) footprint.
42volts
by hathach on Thu Jan 31, 2019 1:44 am
@wb8wka Since I am working on bootloader now, I could run power analyze to see if there is a power bug. Could you tell me which example sketch you use that show the more power consumed !!!
Update: just run power profile on 0.9.1 bootloader and 0.9.3 bootloader, these bootloader are different in term LED pattern. The test sketch is bleuart and I don't see any power difference.
hathach
