Using PWM to control L298n driver
by chizzly on Sun Feb 03, 2019 2:44 am
I am building an inspection robot and have a raspberry pi 3+ with a Adafruit 16-Channel PWM / Servo HAT for Raspberry Pi. I have got servos working however can't seem to be able to control the pwm without ServoKit. when i attempt pwm=PWM(0X40) I get "NameError: name 'PWM' is not defined" I have tried updating the library's and don't have a large programming knowledge base to trouble shoot.
I also I don't know how I would change the direction of the motor because i can't controll the hi and low pins to the L298
chizzly
Re: Using PWM to control L298n driver
by adafruit_support_mike on Sun Feb 03, 2019 3:59 am
Post the exact code you're using now (between CODE tags please) and we'll take a look.
by chizzly on Sun Feb 03, 2019 2:29 pm
from adafruit_servokit import ServoKit
pwm = PWM(0x40)
pwm.setPWMFreq(1000)
pwm.setPWM(2, 1024, 3072)
chizzly
by adafruit_support_mike on Mon Feb 04, 2019 1:35 am
Ah.. you're using a library that won't really help you. If you want to control the basic PWM features, you can use the Adafruit_CircuitPython_PCA9685 library:
https://github.com/adafruit/Adafruit_Ci ... on_PCA9685
The folder named 'examples' has sample code that shows how to create the object, set the PWM frequency, and control various channels:
https://github.com/adafruit/Adafruit_Ci ... r/examples
