Anything like a trinket that can natively charge a lipo
by MikeDubbz on Fri Feb 08, 2019 2:48 pm
Like the title says? I'm very pleased with a product I've put together utilizing a Trinket and lipo battery for portable use. However, charging the lipo battery with lipo chargers is not ideal. I'd like to be able to charge the attached lipo battery with the trinket's micro-usb, but I understand that can't be done natively. I've seen the little backpack addon, which would suffice, but it adds a little extra bulk for what I'm trying to make, is there any other microcontroller that is essentially the same as a Trinket, but the micro-usb port can be used to charge an attached lipo battery?
MikeDubbz
Re: Anything like a trinket that can natively charge a lipo
by franklin97355 on Fri Feb 08, 2019 2:56 pm
I don't know of anything but you could create a board that would include the charger or go with one of the Feathers.
franklin97355
by 42volts on Thu Mar 28, 2019 3:15 pm
Feather.
But they're a little bigger -- 0.3 inches wider and 0.8 inches longer.
42volts
by franklin97355 on Thu Mar 28, 2019 7:06 pm
Then you will have to design your own.
franklin97355
by westfw on Fri Mar 29, 2019 1:30 am
Are you sure? I think I see 0.2 wider and 0.6 longer.
ItsyBitsy: 1.4" x 0.7"
Feather: 2.0" x 0.9"
Edit: oops! Trinket: 1.2" x 0.6"
westfw
by 42volts on Fri Mar 29, 2019 8:25 am
Yes, I can subtract :)
42volts
