Mini 2-axis analog thumbstick doesn't act as an analog stick
Re: Mini 2-axis analog thumbstick doesn't act as an analog s
// Arduino pin numbers
const int SW_pin = 2; // digital pin connected to switch output
const int X_pin = A0; // analog pin connected to X output
const int Y_pin = A1; // analog pin connected to Y output
pinMode(SW_pin, INPUT);
digitalWrite(SW_pin, HIGH);
Serial.begin(115200);
Serial.print("Switch: ");
Serial.print(digitalRead(SW_pin));
Serial.print("\n");
Serial.print("X-axis: ");
Serial.print(analogRead(X_pin));
Serial.print("\n");
Serial.print("Y-axis: ");
Serial.println(analogRead(Y_pin));
Serial.print("\n\n");
delay(500);
1. a previous code (see my previous post) that works but the Leonardo Pro Micro is not recognized as a gamepad
2. a code with makes the Leonardo Pro mini recognized as a gamepad but the analog thumbstick is not recognized itself
#define ENABLE_ANALOG1 false
#define ENABLE_ANALOG1 true
