on my manjaro raspi3 b+ (Linux-5.1.5-1-MANJARO-ARM-aarch64-with-arch) after installation I always get
[..]Adafruit_DHT/common.py", line 63, in get_platform
raise RuntimeError('Unknown platform.')
is adafruit not made for manjaro ARM ?
If so .. Why ?
BR,
A.Emm
unknown Platform with adafruit_python_dht
- aemm2019
Re: unknown Platform with adafruit_python_dht
in platform_detect.py I can see the following lines:
in my case cpuinfo is expected to contain a line with "BCM2837".. on my manjaro arm cpuinfo looks like that:
this is strange. and I mean the detection mechanism. It works only on special distributions ?
with open('/proc/cpuinfo', 'r') as infile:
cpuinfo = infile.read()
# Match a line like 'Hardware : BCM2709'
match = re.search('^Hardware\s+:\s+(\w+)$', cpuinfo,
flags=re.MULTILINE | re.IGNORECASE)
if not match:
# Couldn't find the hardware, assume it isn't a pi.
return None
if match.group(1) == 'BCM2708':
# Pi 1
return 1
elif match.group(1) == 'BCM2709':
# Pi 2
return 2
elif match.group(1) == 'BCM2835':
# Pi 3
return 3
elif match.group(1) == 'BCM2837':
# Pi 3b+
return 3
[root@rasp3 examples]# cat /proc/cpuinfo
processor : 0
BogoMIPS : 38.40
Features : fp asimd evtstrm crc32 cpuid
CPU implementer : 0x41
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
- Franklin97355
Try downloading Raspbian from the Pi foundation site and see if that works. Our code works with Raspbian, other distro may be reporting differently and you may need to modify the code to accommodate that.
