RPi3B+ & ADS 1115 input fluctuations & sampling rate issues
by mjana on Fri Aug 02, 2019 6:38 am
Hi guys,
I've been suddenly experiencing values fluctuations from A0 (ads1115).
I've tried from other pins too, same result. Rebooted, no change. Re-wired, no change.
The values are like
26299
    -7
    -6
    -5
  6043
 26309
    -2
    -3
  6848
 26304
    -3
    -7
    -4
  3905
    -3
    -5
    -6
  4387
 26304
    -5
    -4
    -4
 26307
 12342
    -1
    -4
    -3
 26307
    -2
    -6
    -4
  3292
 26305
  6231
    -3
    -5
  1742
 26305
    -6
    -5
    -3
  6785
 26310
 16396
    -6
    -7
  7661
and the code is
import RPi.GPIO as GPIO
import datetime
import csv
import time
from time import sleep
# Import the ADS1x15 module.
import Adafruit_ADS1x15
adc = Adafruit_ADS1x15.ADS1115()
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)
GPIO.setup(5,GPIO.IN,pull_up_down=GPIO.PUD_UP)
#2/3=+/-6.144V #1=+/-4.096V #2=+/-2.048V #4=+/-1.024V #8 = +/-0.512V #16=+/-0.256V
GAIN = 1
count = 0
results = ""
# Main loop.
while True:
   while GPIO.input(5) == 1:
       sleep(0.2)
   count = count + 1
   if count == 1:
   while GPIO.input(5) == 0:
       sleep(1)
   print(count)
   if count == 3:
       values = [0]
              values[0] = adc.read_adc(0, gain=GAIN, data_rate=860)
              print('{0:>6}'.format(*values))
              time.sleep(0.00000000001)  # Pause for half a secon
   if count == 4:
       count = 0
Also, I'm trying to get sampling rate of 1000samples/sec, but ads1115 maximum rate is 860. I've chosen data_rate=860. Still I get just 250samples/sec, I even tried varying time.sleep() , no change in samples.
Any help, highly appreciated.
Thanks in advance.
mjana
Re: RPi3B+ & ADS 1115 input fluctuations & sampling rate iss
by mjana on Fri Aug 02, 2019 7:53 am
https://plux.info/cables/390-arduino-sensor-cable.html
https://plux.info/cables/226-3-lead-ele ... cable.html
These are input sensors. Input voltage to sensor is 3.3v from RPi
mjana
by adafruit_support_bill on Fri Aug 02, 2019 8:09 am
Based on that sample rate, the fluctuations look like they have a frequency of roughly 50Hz. If you post some photos of your wiring and connections we can take a look.
by mjana on Fri Aug 02, 2019 12:33 pm
Thanks for the response. Here are my connections... sorry for the bad quality.
mjana
by mjana on Fri Aug 02, 2019 12:37 pm
How to increase sampling rate to 1000 samples/sec or 860/sec.
And just letting you know that the base of RPi, ADS1115 module and breadboard aren't touching the PCB board. They are fixed using BluTack (thick reusable adhesives)
mjana
by adafruit_support_bill on Fri Aug 02, 2019 2:48 pm
We can't see what the blue wire is connected to. That is most likely where the noise is entering the system.
by mjana on Fri Aug 02, 2019 9:29 pm
Blue wire is connected to the signal wire of sensor(violet). It was all good till yesterday. Something wrong with sensor ?
And again how to increase sampling rate to 1000/sec. the samples I’ve been getting isn’t 50hz, but it’s 250hz.
mjana
by adafruit_support_bill on Sat Aug 03, 2019 5:53 am
We can't diagnose the noise without understanding the complete circuit. The 50Hz noise is typical of an open circuit or a grounding problem. Your photos do not show the complete circuit.
The sensor's maximum rate is 860/sec. But you have a noise problem with your current circuit and it is best to focus on one problem at a time.
But the noise is periodic and appears to be about 50 Hz.
by mjana on Sun Aug 04, 2019 6:36 am
Your support and response rate is impressive.
Good news is that I rewired the whole thing again and the problem was with one of the wires. There is no noise now. Thanks alot.
Now, how do I increase sampling rate to 860/sec ?
If you can go through my code, and after testing I get sampling around 250hz (So, for 10sec it's 2579samples). Can you please help me to get 860hz, how do I do that ?
I am beginner to this electronics and python. Thanks for the help in advance.
mjana
by adafruit_support_bill on Sun Aug 04, 2019 7:10 am
Good to hear you have eliminated the noise problem.
There are a couple of things that affect sample rate. One is the default operating mode of the ADS1115 is 'single-shot'. That means the conversions only occur when requested. You can try setting the mode to continuous, instead of the default single shot. That eliminates some of the overhead.
adc.mode = 0
The other possible issue is with Python execution overhead. Since it is an interpreted language, there is some sacrifice in speed. So your maximum read rate may be limited.
by mjana on Sun Aug 04, 2019 7:32 am
adafruit_support_bill wrote:Good to hear you have eliminated the noise problem.
adc.mode = 0
Unfortunately, I couldn't find a way to make it continuous from
adc.mode = 0
Have you any tips/suggestions for algorithm or functions ?
If figured out something, I will definitely respond with code.
Thank you :)
mjana
by adafruit_support_bill on Sun Aug 04, 2019 8:02 am
Which library are you using? There was an issue related to continuous mode, but it was fixed recently here.
https://github.com/adafruit/Adafruit_Ci ... on_ADS1x15
https://github.com/adafruit/Adafruit_Ci ... /issues/26
cron
